05-23-2009, 11:41 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: India
Member: 291400 Status: Offline Thanks Meter: 61 | Connect any USB supported phone through USB PINFINDER whose cable is not available... Things you need to connect the phone :- 1. SPIDERMAN with USB PINFINDER connected.. 2. SPIDERMAN cable Which matches with your phone port.. 3. Phone with battery connected and switched on (no need to pwr phone with spiderman's pwr pins + & -) 4. USB pinouts of your phone.. Below is an example for connecting your nokia DKU5 cable supported phone.. STEP 1... Find and get USB pinout of the phone u want to connect through USB.. STEP 2... Connect SPIDERMAN box and click on CUSTOM CABLE.. STEP 3... The DEFINE CABLE window opens.. Then click on NEW.. STEP 4... The CREATE NEW CABLE DEFINE window opens.. Write JET-NAME & CABLE-NAME as u want to.. Then click on DEFINE CABLE AND SAVE IT.. STEP 5... A new custom cable is set, then by the dropdown menu select the pins as your phone's USB pinouts... ( GND, USB-, USB+, PWR).. STEP 6... Then click on SEND, your pinouts will be set as defined.. Now ur phone will be detected... Then install correct drivers of your phone.. Last edited by joy4u; 05-23-2009 at 11:48. |
The Following 47 Users Say Thank You to joy4u For This Useful Post: |
05-23-2009, 17:41 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Riyadh, KSA Age: 43
Member: 894719 Status: Offline Sonork: 100.1580092 Thanks Meter: 905 | thank you brother really good thread .... added to the sticky section |
The Following 9 Users Say Thank You to gsm2start For This Useful Post: |
06-21-2009, 23:38 | #11 (permalink) |
Junior Member Join Date: Feb 2009 Location: Brasil,paraiba,pombal
Member: 963269 Status: Offline Thanks Meter: 10 | AMy friends bought spiderman and now has difficulties with p what cable to use on phones has many PORQ conctou that are similar to the other, the friend wanted ajunda p Encinar me as I choose the cable serti po serti phone since iPhone? |
The Following User Says Thank You to ronysat For This Useful Post: |
06-23-2009, 03:21 | #13 (permalink) | |
Member: 291400 Status: Offline Thanks Meter: 61 | Quote:
Can u explain ur problem a little in brief plz.... I cannot understand u... | |
DCT4Plus service is not available at the moment ... Any Update?? | airos_8 | Universalbox | 1 | 06-23-2008 11:44 |
another dead phone through usb smart | boxman | SonyEricsson (USB-Smart) | 19 | 08-21-2006 09:45 |
@@ v545 flash file is not available in support area@@ | rajabrotherscom | Smart-Clip | 2 | 04-25-2006 12:36 |
IMEI Change option is not available FOr Sony Ericsson T39m with DIV USB 4.0 PLz HElp. | cellexpress | Old Ericsson Phones & Sony Phones | 1 | 09-04-2004 16:19 |
