05-21-2010, 08:52 | #3 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | no way!!! The X3 can't be flashed using the UFC.. just forget about it.. It has a double mbus line and a pinout out of standard. as well it uses an high frequency 1.8V mbus line badly affected by the interference and only short cables can manage it without getting errors every other second. Just buy a good GPG nano to service it. BR Alex |
The Following 3 Users Say Thank You to moulnisky For This Useful Post: |
05-21-2010, 10:11 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Near the sea... Portugal Age: 48
Member: 120120 Status: Offline Sonork: 100.1592092 Thanks Meter: 234 | So you mean only by Fbus cable? You are right because i manage to conect to cyclone i can read info but when i try to flash always get error on getting on reading cyc[ I guess is this]. I can ´t flash by usb because it as a security code and cyclone doesn´t reset the code ether. Always fail message... I already order the cable. Thanks for the hint, Regards, Alex |
05-21-2010, 17:14 | #6 (permalink) |
Member: 120120 Status: Offline Sonork: 100.1592092 Thanks Meter: 234 | Sorry to jump again,but the main problem why this phone came to my shop is that it has a security code enable and *******r forget about it... So i cannot activate USB mode in the phone. What do you mean with refurbish mode? Is there a way to flash with phoenix with enable security code? Regards, Alex |
05-21-2010, 17:25 | #7 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Philippines
Member: 329609 Status: Offline Thanks Meter: 245 | Try factory reset to remove usercode/lockcode.Tick testmode then tick factory set tab. b.r. |
The Following User Says Thank You to kungpaoski For This Useful Post: |
05-21-2010, 18:19 | #8 (permalink) |
Member: 120120 Status: Offline Sonork: 100.1592092 Thanks Meter: 234 | I have tried everything that cyclone allow me to do... Reset code, factory defauts but the code remains on the phone...And i cannot flash via usb because i cannot choose usb mode in phone... I guess i have to wait for the the Fbus cable... Regards, Alex |
The Following User Says Thank You to bauzito For This Useful Post: |
05-21-2010, 18:47 | #9 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Code: 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 3=03 4=07 5=31323334350000000000 6=00 7=00 8=00 9=00000000000000000000000000000000000000000000000000000000000000000000000000000000 [309] sample 5=31323334350000000000=31323334350000000000=12345 If you can read the PM, read the pm308 BR Alex Note: you can get the local mode as well powering the mobile using the tweezers of the ufc on the battery block and setting 10kohm bsi: onvce you press power on the mobile should go direcly in local mode and once connected to the usb cable you can read the PM BR Alex |
05-21-2010, 20:14 | #10 (permalink) |
Member: 120120 Status: Offline Sonork: 100.1592092 Thanks Meter: 234 | Thanks a lot! I finnaly did it with your tip! Any way cable is on the way for better service on Nokia x3... Amazing support from your side even out of cyclone forum...One of the best supporters in this forum... Best regards, Alex Alex |
