03-09-2013, 12:16 | #1 (permalink) |
Product Manager Join Date: Sep 2009 Location: Pakistan Age: 36
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Cable set used for MEP0 fix and direct unlock. So called MicroSD cable. To work with blackberry phones you should use Standart USB cable and modified SD card (so called Micro SD cable) with power supply (+ 3.0 V) identical to cable which you use for HTC phones. What is MicroSD cable: You need 1) standart USB cable 2) microSD card (8MB - 4GB, don't use SDHC) with two thin wires (pin4=+3V, pin6=GND) 3) External power supply (+3V or +3.7V, for example 2xAAA battery). 4) Any MicroSD USB card reader: How to work with this set with BLACKBERRY phones: Firstly you put card in external card reader WITHOUT EXTERNAL POWER and make phone image with LGtool and simple USB cable. after this you INSERT modified card to phone, CONNECT EXTERNAL POWER, connect USB cable to phone without battery and follow on-screen instruction. How to work with this set with HTC phones here We recommend you to use quality SD cards like Samsung, Kingston etc. not less than 2 Gb size. Usage: To fix MEP0 you need to click unlock button and follow the on-screen instructions. here is example of program log when you repair IMEI on BB 9900 Code: Connecting with 9900 Searching microSD disk... MicroSD disk found: Volume: F:\ Device: \\.\PhysicalDrive1 Label: Size: 2001403904 Writing image to microSD disk... Writing image to microSD disk: OK Waiting for User's Actions... Searching Phone... Getting Phone Info... Serial Number: 99183bc0 BlackBerry RTAS Server Authorization... Connecting to server... Sending data to server... Receiving data from server... Sending RTAS Certificate to phone... RTAS Authorization: OK Connection With Phone... Searching Phone... Phone Found... Connected Repairing IMEI Repairing IMEI... Please Wait... Repairing IMEI: OK IMEI: 351530-xx-xxxxxx-2 IMEI successfully repaired
The Following 21 Users Say Thank You to Danish Shafiq For This Useful Post: |
04-04-2013, 16:15 | #3 (permalink) |
Freak Poster Join Date: Mar 2013 Location: http://forum.gsmhosting.com
Member: 1892345 Status: Offline Thanks Meter: 12 | Any video? Can someone who tested this upload video? possibly with this method http://img839.imageshack.us/img839/3913/9900testedi.png |
