09-29-2011, 13:28 | #1 (permalink) |
Product Manager Join Date: Sep 2009 Location: Pakistan Age: 36
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | How To Enter Unlock Codes On LG Phones. Code: LG KG220 press 2945#*1201# LG KG240 press 2945#*3311# LG KG280 press 2945#*7101# LG KS360 press 2945#*71001# LG KS500 press 2945#*500# LG KP270 press 2945#*270# LG KF240 press 2945#*240# or 2945#*2401# LG KG290 press 2945#*7101# LG KU250 press 2945#*250# Enter NCK and press OK. How to Enter Unlock Codes on all other LG cell phones: 1. Switch ON your phone with an allowed SIM card 2. Then compose: 3. 2945#*5101# - (if you have a LG 510w) 4. 1945#*5101# - (if you have a LG 1200 & B1200) 5. 2945#*5221# - (if you have a LG 5200 & 52200) 6. 2945#*5301# - (if you have a LG 5300) 7. 2945#*5401# - (if you have a LG 5400) 8. 2945#*70001# - (if you have a LG 7020) 9. 2945#*7101# - (if you have a LG 7100) 10. 2945#*1201# or 2945#*70001# - (if you have a LG 1100 or 1150) 11. 2945#*70001# - (if you have a LG7250T) 12. 2945#*2201# - (if you have a LG C2200) 13. 2945#*5301# - (if you have a LG T5100) 14. 2945#*3311# - (if you have a LG C3310) 15. Go to "Menu" and then to "Settings" 16. Then select "Security" 17. To finish select "Network Provider" and select "Deactivate" 18. Enter the unlock code |
09-29-2011, 13:31 | #2 (permalink) |
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Code: How to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select “1.Deactivate:” Menu, Display pop up “ SIM Lock Code:”. 7. Input right Unlock code, Display pop up “Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG ***** (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display “Done”. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security > Sim Lock > Network > Deactivate Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG KF700 aka LG VIRGO Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*700# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked How to Enter Unlock Codes on LG U8110: 1. With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2. Select 'Sim Unlock' menu # 3. Enter NCK code, then validate 4. Your phone is now unlocked. How to Enter Unlock Codes on LG U8150, other UMTS models Power on phone with a non-original SIM card inserted Type 277634#*# Go to menu "SIM Lock" Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG U8210: 1. With a not allowed sim card enter Pin code then validate, type: 277634#*# 2. Shows test menu 3. Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4. Handset shows 'Enter NCK' 5. Enter code and then hit OK. How to Enter Unlock Codes on LG U81xx: 1. To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2. Enter the code In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. How to Enter Unlock Codes on LG CU720, TU720, other SHINE series Power on phone with an original (from the locked carrier) SIM card inserted Type *#865625#CODE where CODE is the unlock code provided by LGTooL Select "OK" Your phone is unlocked If this didn't work you can also try to repeat the above steps with a non-original SIM card inserted How to Enter Unlock Codes on LG CE110 Prior to unlocking reset the phone to "Factory Default" Power on phone with a non-accepted SIM card Select "Cancel" - phone will displays "Phone restriction code" Enter supplied unlock code Select "OK" Your phone is unlocked How to Enter Unlock Codes on LG CE500 Power on phone with Cingular SIM card Type 2945#*7101# Select Settings > Security > Sim Lock > Network > Deactivate Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG KG275 Power on phone with non original SIM card Type in the code you received from LGTooL.com Press "Send" key Your phone is unlocked If this didn't work append #*# to the end of the entered code How to Enter Unlock Codes on Cingular AT&T LG CU575 TRAX: 1. Insert non-Cingular SIM card. 2. Power on the handset. Phone will display "Invalid SmartChip" 3. Now enter *#865625# then select option 1 and then again select 1 and enter your code How to Enter Unlock Codes on LG CU400, CU500 Cingular AT&T Power on phone with a non-original SIM card inserted Phone will display "Invalid SmartChip" If the phone doesn't display "Invalid SmartChip" power off and on, then try again Type 159753#*# Select "1 Unlock USIM", then "1 network lock" Phone will display "Enter NCK, Remaining 5" Enter the 8 digit unlock code Select "OK" Your phone is unlocked How to Enter Unlock Codes on LG CU575, CU515 Trax Cingular AT&T Power on phone with a non-original SIM card inserted Phone will display "Invalid SmartChip" If the phone doesn't display "Invalid SmartChip" power off and on, then try again Type *#865625# Select option 1 and then again select 1 Enter the supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG C2000 Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code 5) Select "OK" - the handset is now successfully unlocked |
The Following User Says Thank You to Danish Shafiq For This Useful Post: |
09-29-2011, 13:33 | #3 (permalink) |
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Code: How to Enter Unlock Codes on LG U400 Shine (2 codes needed): 1. Insert the network SIM in the handset which works with the phone (from the lockedcarrier). 2. Enter 2945#*9636#. 3. The phone will then prompt 'Unlock sim'. Press OK. 4. The phone will then prompt 'Network Unlock'. Press OK. 5. The phone will then prompt- 'Input Network Control Key'. Enter the 8 digit unlocking code, Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. If you received a 16 digit code, enter it. The phone will have space for it. 6. It should give you the message: Success. 7. Come back to the main screen and Enter 2945#*9636#. 8. The phone will then prompt unlock sim. Press OK. 9. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code. LG U400 Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*9636# The phone will then prompt "Unlock sim". Press "OK" The phone will then prompt "Network Unlock". Press "OK" Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. he phone will give you message "Succeess" Go back to the main screen and enter 2945#*88110# The phone will then prompt "Unlock sim". Press "OK" The phone will then prompt "Network Unlock/Lock" but if you scroll down you will see a message Enter SP Lock. Enter SP Code Then press "OK" Your phone is unlocked How to Enter Unlock Codes on LG KE970 Shine: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. OR 1. Switch ON your phone with an allowed SIM card 2. Then compose: 2945#*9701# 3. Press CALL. 4. It should you ask you for the code How to Enter Unlock Codes on LG TU720 Shine 1. Put in a non-allowed SIM, phone says invalid SIM card (or insert original SIM and proceed to step 2) 2. Now enter *#865625# then enter your 16 digits code OR 1. Insert the original network SIM 2. Enter 2945#*88110#. 3. The phone will then prompt ' Unlock sim'. Press OK. 4. The phone will then prompt 'Network Unlock'. Press OK. 5. The phone will then prompt- 'Input Network Control Key'. Enter the 8 digit unlocking code. Press OK. 6. If the unlock ing code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. 7. It should give you the message Success. 8. Come back to the main screen and Enter 2945#*88110#. 9. The phone will then prompt unlock sim. Press OK. 10. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code. 11. Then press OK. How to Enter Unlock Codes on LG BL40 Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945#*40# From the menu that pops up select "SIM unlock" Enter unlock code you received from LGTooL and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG BL20 Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945#*20# From the menu that pops up select "SIM unlock" Enter unlock code you received from LGTooL and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GW520, GB250 Insert an original simcard and turn phone on (code can also be entered without SIM card) Enter sim PIN if required Enter 2945#*71001# From the menu that pops up select "SIM unlock" Enter unlock code you received from LGTooL and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG Viewty GW300 Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945#*700# From the menu that pops up select "SIM unlock" Enter unlock code you received from LGTooL and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG G910 Insert a non original simcard and turn phone on Enter sim PIN if required Select "Emergency mode" Enter 2945#*71001# Sim unlock mode pop up Select Netlock Enter unlock code you received from LGTooL and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KC910, KF910 Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945#*910# Sim unlock mode pop up Enter unlock code you received from LGTooL and select Reboot The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for KE850, ME850 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG WATCHPHONE GD810 and GD330 Insert a non original simcard and turn phone on Insert PIN Phone says "Invalid sim card" Select "Emergency calls" Enter 2945#*71001# Sim unlock mode pop up Select netlock Enter your 16-digit unlock code and press ok The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG Invision CB630 Power on phone with a original AT&T SIM card inserted Type *#865625# in the phone menu Press "Call" Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG CU915 Power on phone with a original SIM card inserted Type *#865625#CODE where CODE is the unlock code provided by LGTooL Press "OK" Your phone is unlocked How to Enter Unlock Codes on LG KF750 aka LG SECRET Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*750# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked How to Enter Unlock Codes on LG GC900, GT360, GT810, KC550, KM500, KM900, KP230, KP270, KP500, KP501, KS360, Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*71001# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked How to Enter Unlock Codes on LG KS360 aka QWERTY Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*71001# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked How to Enter Unlock Codes on LG KF755 Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*755# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked How to Enter Unlock Codes on LG KF600 Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*600# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked How to Enter Unlock Codes on LG KS20 Power on phone with an original (from the locked carrier) SIM card inserted Type 2945#*20# and 2945#*990# A menu will pop up. Select "Sim unlock" Enter supplied unlock code and press "OK" The phone will then reboot Your phone is now unlocked How to Enter Unlock Codes on LG KG800 CHOCOLATE, TG800 CHOCOLATE Insert an original (from the locked carrier) SIM card and power on the phone While in standby enter 2945#*5301#. This will activate the extra menu Select "Settings" -> "Security" -> "Sim lock" -> "Network" Select "Deactivate" Enter supplied unlock code and press "OK" Your phone is unlocked How to Enter Unlock Codes on LG G7020 Power on phone with a non-original SIM card inserted Type 2945#*70001# Go to "Menu" and then to "Settings" Select "Security" Select "Network Provider" and then "Deactivate" Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on U880 Use this code with non-accepted sim card: 277634#*# The Test Mode menu will display. Select SIM test menu Type 2945#*# Select SIM Unlock menu Phone will display "Enter NCK" Enter your NCK and OK If above given dont work ......... Insert the accepted network SIM in the handset Enter 2945#*9636#. The phone will then prompt 'Unlock sim'. Press OK. The phone will then prompt 'Network Unlock'. Press OK. The phone will then prompt- 'Input Network Control Key'. Enter the 8 digit unlocking code, Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. If you received a 16 digit code, enter it. The phone will have space for it. It should give you the message: Success. Come back to the main screen and Enter 2945#*9636#. The phone will then prompt unlock sim. Press OK. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code. |
09-29-2011, 13:33 | #4 (permalink) |
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Code: How to Enter Unlock Codes on LG T5100 Power on phone with a non-original SIM card inserted Type 2945#*5301# Go to "Menu" and then to "Settings" Select "Security" Select "Network Provider" and then "Deactivate" Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG C2200 Power on phone with a non-original SIM card inserted Type 2945#*2201# Go to "Menu" and then to "Settings" Select "Security" Select "Network Provider" and then "Deactivate" Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes for LG GM360 Viewty Snap 1. Power on your LG Viewty GM360 with the original SIM card in. 2. Enter 2945#*360# 3. A menu will pop up, select SIM Unlock. 4. Enter your unlock code and hit OK. How to Enter Unlock Codes for LG GS290 Cookie Fresh 1. Power phone ON with original SIM 2. Type 2945#*290# to enter unlock menu 3. Enter the unlocking code How to Enter Unlock Codes for Optimus One P500 1. Switch the phone with no sim card inserted. 2. Dial 2945#*500# to enter unlock menu 3. Enter the unlocking code How to Enter Unlock Codes for LG GT400 1. Turn phone on without simcard 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*400# 4. A menu will pop up, select network unlock 5. Enter your unlock code and press ok 6. The phone will then reboot and the unlock is complete How to Enter Unlock Codes for LG GT450 1. Turn phone on without simcard 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*450# 4. A menu will pop up, select network unlock 5. Enter your unlock code and press ok 6. The phone will then reboot and the unlock is complete How to Enter Unlock Codes for LG GT540 1. Turn phone on without simcard 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*540# 4. A menu will pop up, select network unlock 5. Enter your unlock code and press ok 6. The phone will then reboot and the unlock is complete How to Enter Unlock Codes for LG GW620 1. power phone ON with original SIM 2. type 2945#*620# to enter unlock menu 3. Enter the unlocking code How to Enter Unlock Codes for LG GM205 1. switch on your phone with original working simcard 2. enter code 2495#71001# .. nothing will show in the screen. 3. now go to menu > setting > security > simlock > network lock > deactivate: enter your unlock code in it How to Enter Unlock Codes for LG GW820 eXpo 1. Power on your LG GW820 eXpo with the original SIM card in. 2. Enter 2945#*700# 3. A menu will pop up, select SIM Unlock. 4. Enter your unlock code and hit OK. 5. Your LG GW820 eXpo may automatically reboot. How to Enter Unlock Codes for LG GM205 1. Power phone ON with original SIM 2. Type 2945#*71001# to enter unlock menu 3. Enter the unlocking code How to Enter Unlock Codes for LG GB250, GB220 1. Power on your phone without SIM card 2. Enter 2945#*71001# 3. From the menu that pops up select "SIM unlock" 4. Enter unlock code you received from us and press OK 5. The phone will then reboot and the unlock is complete How to Enter Unlock Codes for LG C1100 - First you must put in an allowed simcard, then : - type 2945#*1201#. - Goto Menu/Settings/Security Settings/Sim Locks - Select 'Locktype'/Deactivate and Enter the code. How to Enter Unlock Codes for LG KP170 1 - Switch ON your phone with a T Mobile Sim inserted 2 - Press telephone icon at bottom of screen to bring up the phone keypad 3 - Then compose : 2945#*170# 4 - A menu will pop up, select Unlock Usim 5 - Then Select Network Lock 6 - Enter your unlock code and press ok (you only have 10 attempts) 7 - The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG TE365 1. Power on phone with original SIM card 2. Type *#0001#code# 3. Your phone is unlocked How to Enter Unlock Codes for LG CB630 (Invision) 1) Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2) Dial this into the LG Incite's phone menu 3) *#865625# 4) Press CALL. 5) It should you ask you for the code. How to Enter Unlock Codes for LG U830 1. Have your unlock code handy. 2. InserI a 3 SIM card in the phone and switch power on. 3. Enter the following key sequence 94471877#*# 4. Select the option ‘unlock USIM’. 5. Select the option ‘network unlock’ 6. Enter your unlock code. 7. Handset should now display ‘network unlock success’. 8. Handset will now restart. How to Enter Unlock Codes for LG KF300 1. Put wrong simcard 2. Phone alert 'insert correct card' 3. Right under in screen you see deblokkeren (dutch) 4. Click on it en click 'Network lock off' 5. Insert code! How to Enter Unlock Codes for LG KF755d 1. Insert original sim card and turn phone on 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*755# (or 2945#*750# if 1st option doesn't work) 4. A menu will pop up, select sim unlock 5. Enter your unlock code and press ok 6. The phone will then reboot and the unlock is complete How to Enter Unlock Codes for LG Incite CT-810 - Insert a SIM from the original network - 2945#*810# will show the unlock menu - Enter unlock code How to Enter Unlock Codes for LG KP265 1 - Use Original SIM to switch ON the Phone. 2 - Compose 2945#*265# 3 - Then go to MENU > SETTINGS > SECURITY 4 - Then go to SIM LOCKS > NETWORK > DESACTIVATE 5 - ENTER NCK (your Unlock Code) How to Enter Unlock Codes for LG ME550 1 - Use Original SIM to switch ON the Phone. 2 - Compose 2945#*71101#. 3 - Menu will appear, go to settings > security > sim lock 4 - Enter NCK ( Unlock Code ) and press OK. How to Enter Unlock Codes for LG TU915 - Switch ON your phone with an allowed SIM Card - Then compose: 2945#*9701# - It should you ask you for the code. OR - Enter *#865625# then enter your 16 digits code. |
09-29-2011, 13:34 | #5 (permalink) |
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Code: How to Enter Unlock Codes for LG VU CU915 & CU920 (Vu) 1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked ! How to Enter Unlock Codes for LG iQ 1 - Switch ON mobile with a not Allowed SIM Card, 2 - If phone ask, enter the PIN code of your SIM Card 3 - Now phone will ask you to enter the unlocking code ! How to Enter Unlock Codes for LG U310 1. Turn ON the phone without SIM Card : 2. Enter 815118#*# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG KC550, KS360, KP230, KP500, KP501, KP270, KM900, KM500, GT810, GC900, GT360 1. Insert original sim card and turn phone on. 2. Enter 2945#*71001# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG KF700 (aka LG Virgo) 1. insert original sim card and turn phone on. 2. Enter 2945#*700# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG KC910, KF910 (aka LG *****) 1. insert original sim card and turn phone on. 2. Enter 2945#*910# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG KF750 1. insert original sim card and turn phone on. 2. Enter 2945#*750# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG KF600 1. Insert original sim card and turn phone on. 2. Enter 2945#*71001# 3. Sim unlock mode pop up . 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes for LG U970 1. Insert original sim card and turn phone on. 2. Enter 2945#*970# 3. A menu will pop up, select Unlock Usim. 4. Select Network Lock. 5. Enter the unlock code and ok. How to Enter Unlock Codes for LG U300 1 - Switch ON the phone with Accepted SIM Card (from Original Network Provider) 2 - Enter Code : 815118#*# 3 - then phone will ask to enter NCK How to Enter Unlock Codes for LG KU990 Viewty & KE990 1. insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*990# 4. A menu will pop up, select sim unlock 5. Enter your unlock code and press ok 6. The phone will then reboot and the unlock is complete. or 1. Without sim phone power "ON" 2. Hold "camera" + "lock" button 3. You will get key pad write 2945#*990#. 4. Press active code. 5. Your cellphone will be restart 6. Turn off cellphone and insert your sim (internation sim) 7. Enjoy your unlocked phone ! How to Enter Unlock Codes for LG TU720 - LG CU720 (Shine) 1) Power ON your phone with not allowed sim card (one that didn't come with the phone) 2) Type *#865625# 3) the phone will ask you to input the unlock code twice, just input the unlock code 4) Device is now unlocked How to Enter Unlock Codes for LG CE110 1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK’" - the handset is successfully unlocked How to Enter Unlock Codes for LG GR500 (Xenon) 1) Insert not-allowed SIM card 2) Power on the handset- phone will display "phone restricted" 3) Select "Cancel" - phone will display "phone restriction code" 4) Enter the SIM unlock code 5) Select "OK" - the handset is now successfully unlocked or 1. insert original sim card and turn phone on. 2. Enter 2945#*9701# 3. A menu will pop up, select sim unlock 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. or After turning on your mobile phone, press: *#865625# Press Yes to continue. Enter the 16 digit Subsidy Unlock Code Enter the 16 digit Subsidy Unlock Code, again. Device should say: “Network Lock Deactivated” Phone may automatically reboot How to Enter Unlock Codes for LG CU320 1) Power on the handset 2) In Idle screen, input the special code "277634#*#". 3) Enter the SIM Unlock code 4) Access the submenu "SIM Test" in Phone Test Mode. 5) Input the special code "2945#*#". 6) Access the submenu "SIM Unlock" which is just activated after the special code. 7) Input the 8-digit Unlock code in the "Enter unlock code" input screen. 8) It will be unlocked. How to Enter Unlock Codes for LG CU400 & CU405 1) Insert non-Cingular SIM card" 2) Power on the handset - Phone will display "Invalid SmartChip". 3) Enter 159753#*# 4) Enter the 8 digit SIM Unlock code 5) Select "OK". 6) The handset will be unlocked. How to Enter Unlock Codes for LG CU500 1) Insert non-Cingular SIM card. 2) Power on the handset. Phone will display "Invalid SmartChip" 3) (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 4) In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 5) Enter the 8 digit SIM unlock code 6) Select "OK" 7) The handset is now successfully unlocked. How to Enter Unlock Codes for LG CU515, CU575 (Trax) 1) Put a non-Cingular sim in the phone 2) Phone says invalid smart chip 3) Now enter *#865625# then select option 1 and then again select 1 4) Enter your 16 digits code 5) Device should say: Network Lock Deactivated 6) The handset is unlocked. How to Unlock LG (other models not listed in the above guide): 1. Insert not-allowed SIM card 2. Power on the handset- phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM unlock code 5. Select "OK" - the handset is now successfully unlocked |
The Following 2 Users Say Thank You to Danish Shafiq For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
