Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GPG-Setool3
Old 07-15-2016, 01:31   #1 (permalink)
Crazy Poster
Member: 509340
Thanks Meter: 2
problem unlocking lg h815p
here the log, it says phone succesfully unlocked, but after that phone its still locked.
Connecting with H815P
Please Flash Firmware with Android 5.x in order to enable unlock features.
Please type 277634#*# and select "SVC menu" -> "Port Check Test" -> "Enabled".
Please select MTP in USB Connection Dialog on phone.
Connected
Receiving phone info
Getting phone info
Model: H815P
Platform: LG Qualcomm
Software Platform: Android
SDRAM Size: 3 GB
NAND Flash Size: 32 GB
CPU: MSM8992
Firmware Released: Apr 29 2015 09:50:56
Firmware Compiled: Apr 15 2015 21:00:00
Firmware Version: LGH815PAd/MPSS.BO.2.5.c3-00060-M8992FAAAANAZM-1.18275.1
IMEI: 359
Connect mode: Normal
Info received
Getting phone info
Model: H815P
SDRAM Size: 3 GB
CPU: MSM8992
IMEI: 359
Info received
Unlocking phone
Unlock: Start
Backuping NVM to file: Backups\H815P_nvm_359_2016-7-14_18-16-26.sbf
Dump NVM: Start
Getting phone info...
Getting phone info: OK
Switching to NVM mode...
Switching to NVM mode: OK
Dumping NVM...
Dumping NVM: OK
Switching to normal mode...
Switching to normal mode: OK
Dump NVM: Finish
Backuping EFS to file: Backups\H815P_efs_359_2016-7-14_18-22-1.sbf
Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/Algorithm.txt 12 bytes
Downloading file /nv/item_files/CoreCpu/CoreAll/Startup/LogSize.uint 4 bytes
Downloading file /nv/item_files/CoreCpu/Default/Fixed/MIPS.uint 4 bytes
Downloading file /nv/item_files/CoreCpu/Default/Startup/AVSEnable.uint 4 bytes
Downloading file /nv/item_files/CoreCpu/Default/Startup/Algorithm.txt 8 bytes
Downloading file /nv/item_files/CoreCpu/Default/Startup/LogSize.uint 4 bytes
Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/HighThresholdBusyPct.uint 4 bytes
Downloading file /nv/item_files/CoreCpu/Default/qdsp_classic/SamplePeriod.uint 4 bytes
Downloading file /nv/item_files/conf/cgps_common.conf 56 bytes
Downloading file /nv/item_files/conf/cgps_me.conf 3.53 Kb
Downloading file /nv/item_files/conf/cgps_pdcomms.conf 212 bytes
Downloading file /nv/item_files/conf/cgps_pe.conf 478 bytes
Downloading file /nv/item_files/conf/cgps_sdp.conf 53 bytes
Downloading file /nv/item_files/conf/cgps_sm.conf 1.57 Kb
Downloading file /nv/item_files/conf/cgps_tle_tlm.conf 1.00 Kb
Downloading file /nv/item_files/conf/cgps_tle_xtm.conf 1.17 Kb
Downloading file /nv/item_files/conf/data_config_info.conf 5.40 Kb
Downloading file /nv/item_files/conf/data_profile.conf 154 bytes
Downloading file /nv/item_files/conf/dpm_config_info.conf 62 bytes
Downloading file /nv/item_files/conf/geran.conf 1.85 Kb
Downloading file /nv/item_files/conf/hdrcp_config_info.conf 465 bytes
Downloading file /nv/item_files/conf/hdrmac_config_info.conf 41 bytes
Downloading file /nv/item_files/conf/hdrmultirat_config_info.conf 48 bytes
Downloading file /nv/item_files/conf/hdrsrch_config_info.conf 418 bytes
Downloading file /nv/item_files/conf/ims.conf 3.08 Kb
Downloading file /nv/item_files/conf/ipa.conf 424 bytes
Downloading file /nv/item_files/conf/lte_a2.conf 348 bytes
Downloading file /nv/item_files/conf/lte_ml1_ant_switch.conf 45 bytes
Downloading file /nv/item_files/conf/lte_ml1_ant_switch_band.conf 50 bytes
Downloading file /nv/item_files/conf/lte_ml1_ant_switch_dr_dsds.conf 53 bytes
Downloading file /nv/item_files/conf/lte_ml1_ca_dynamic_cfg.conf 49 bytes
Downloading file /nv/item_files/conf/lte_ml1_debug_cfg.conf 47 bytes
Downloading file /nv/item_files/conf/lte_ml1_tput_test_cfg.conf 47 bytes
Downloading file /nv/item_files/conf/lte_rrc.conf 3.60 Kb
Downloading file /nv/item_files/conf/mc.conf 988 bytes
Downloading file /nv/item_files/conf/mcfg.conf 216 bytes
Downloading file /nv/item_files/conf/mcpm.conf 246 bytes
Downloading file /nv/item_files/conf/mcs_as_div.conf 43 bytes
Downloading file /nv/item_files/conf/mcs_cfcm.conf 288 bytes
Downloading file /nv/item_files/conf/mcs_cxm_coex.conf 40 bytes
Downloading file /nv/item_files/conf/mcs_limitsmgr.conf 5.09 Kb
Downloading file /nv/item_files/conf/mcs_pbr_info.conf 32 bytes
Downloading file /nv/item_files/conf/mcs_tcxomgr.conf 547 bytes
Downloading file /nv/item_files/conf/mmgsdi.conf 3.92 Kb
Downloading file /nv/item_files/conf/mmode.conf 2.74 Kb
Downloading file /nv/item_files/conf/nas_mm.conf 1.59 Kb
Downloading file /nv/item_files/conf/onex_mux.conf 47 bytes
Downloading file /nv/item_files/conf/onex_srch.conf 303 bytes
Downloading file /nv/item_files/conf/pbm.conf 278 bytes
Downloading file /nv/item_files/conf/ps_config_info.conf 664 bytes
Downloading file /nv/item_files/conf/qmi_data.conf 135 bytes
Downloading file /nv/item_files/conf/reg.conf 1.68 Kb
Downloading file /nv/item_files/conf/tdscdma_l1.conf 1.96 Kb
Downloading file /nv/item_files/conf/tdscdma_rrc.conf 2.18 Kb
Downloading file /nv/item_files/conf/thin_ui_config.conf 41 bytes
Downloading file /nv/item_files/conf/uimdrv.conf 407 bytes
Downloading file /nv/item_files/conf/wcdma_csg_efs_1.conf 3.63 Kb
Downloading file /nv/item_files/conf/wcdma_csg_efs_2.conf 3.63 Kb
Downloading file /nv/item_files/conf/wcdma_csg_efs_3.conf 3.63 Kb
Downloading file /nv/item_files/conf/wcdma_csg_efs_4.conf 3.63 Kb
Downloading file /nv/item_files/conf/wcdma_csg_efs_5.conf 3.63 Kb
Downloading file /nv/item_files/conf/wcdma_csg_efs_db.conf 54 bytes
Downloading file /nv/item_files/conf/wcdma_rrc_external.conf 2.12 Kb
Downloading file /nv/item_files/conf/wl1_cme.conf 210 bytes
Downloading file /nv/item_files/conf/wl1_rxd.conf 995 bytes
Downloading file /nv/item_files/conf/wms.conf 558 bytes
Downloading file /nv/item_files/mcs/cfcm/cfcm_config_cpu_dne_efs 0 bytes
Downloading file /nv/item_files/mcs/cfcm/cfcm_config_step_timer_efs 0 bytes
Downloading file /nv/item_files/mcs/cfcm/cfcm_cpu_threshold_limits 0 bytes
Downloading file /nv/item_files/mcs/cfcm/cfcm_fc_masks 0 bytes
Downloading file /nv/item_files/mcs/cxm/coex_config_data 4.09 Kb
Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_lte_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_tdscdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/coex_simulation_input 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/1x_victim_gsm_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/1x_victim_lte_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/disable_sw_mitigation 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gps_victim_1x_lte_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm1_victim_gsm2_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm1_victim_gsm3_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm2_victim_gsm1_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm2_victim_gsm3_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm3_victim_gsm1_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm3_victim_gsm2_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_1x_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_hdr_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_lte_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_tdscdma_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_wcdma_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/hdr_victim_gsm_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_1x_victim_hdr_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_1x_victim_lte_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_hdr_victim_1x_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_lte_victim_1x_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/lte_victim_gsm_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/tdscdma_victim_gsm_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense/wcdma_victim_gsm_aggr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/desense_ind_thresholds 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/force_filter_path 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/idle_mode_hopping_rxpwr_limit 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/coex/set_prio_tbl_action 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_hdr_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_lte_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_1x_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_hdr_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_lte_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_tdscdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_wcdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_1x_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_hdr_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_lte_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_tdscdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_wcdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_gpio_settings 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_hdr_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_lte_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_1x_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_hdr_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_lte_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_tdscdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_wcdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_1x_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_hdr_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_lte_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_tdscdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_wcdma_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm1_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm2_low 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sar/sar_qmi_comp_key 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_1x 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_hdr 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_tdscdma 0 bytes
Downloading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_wcdma 0 bytes
Downloading file /nv/item_files/mcs/tcxomgr/ft_table_gps 768 bytes
Downloading file /nv/item_files/mcs/tcxomgr/ft_table_wwan 768 bytes
Downloading file /nv/item_files/modem/lte/rrc/csp/sec_inactive_rlf_recovery 1 bytes
Downloading file /nv/item_files/modem/mmode/sw_version 61 bytes
Downloading file /nv/item_files/modem/tdscdma/rrc/acq_list 992 bytes
Downloading file /nv/item_files/modem/uim/mmgsdi/mmgsdi_diag_support 1 bytes
Downloading file /nv/item_files/modem/uim/uimdrv/uim_hw_config 256 bytes
Downloading file /nv/item_files/rfnv/00022982 484 bytes
Downloading file /nv/item_files/rfnv/00024226 777 bytes
Downloading file /nv/item_files/rfnv/00024227 782 bytes
Downloading file /nv/item_files/rfnv/00024228 768 bytes
Downloading file /nv/item_files/rfnv/00024229 759 bytes
Downloading file /nv/item_files/rfnv/00024230 737 bytes
Downloading file /nv/item_files/rfnv/00024232 765 bytes
Downloading file /nv/item_files/rfnv/00024233 763 bytes
Downloading file /nv/item_files/rfnv/00024240 781 bytes
Downloading file /nv/item_files/rfnv/00024243 727 bytes
Downloading file /nv/item_files/rfnv/00024250 789 bytes
Downloading file /nv/item_files/rfnv/00024252 766 bytes
Downloading file /nv/item_files/rfnv/00024253 779 bytes
Downloading file /nv/item_files/rfnv/00024255 784 bytes
Downloading file /nv/item_files/rfnv/00024256 797 bytes
Downloading file /nv/item_files/rfnv/00024964 193 bytes
Downloading file /nv/item_files/rfnv/00024965 193 bytes
Downloading file /nv/item_files/rfnv/00024966 193 bytes
Downloading file /nv/item_files/rfnv/00024967 193 bytes
Downloading file /nv/item_files/rfnv/00024972 2.97 Kb
Downloading file /nv/item_files/rfnv/00024973 2.97 Kb
Downloading file /nv/item_files/rfnv/00024974 2.49 Kb
Downloading file /nv/item_files/rfnv/00024975 2.49 Kb
Downloading file /nv/item_files/rfnv/00025004 192 bytes
Downloading file /nv/item_files/rfnv/00025005 192 bytes
Downloading file /nv/item_files/rfnv/00025006 192 bytes
Downloading file /nv/item_files/rfnv/00025007 192 bytes
Downloading file /nv/item_files/rfnv/00025044 160 bytes
Downloading file /nv/item_files/rfnv/00025045 160 bytes
Downloading file /nv/item_files/rfnv/00025046 160 bytes
Downloading file /nv/item_files/rfnv/00025047 160 bytes
Downloading file /nv/item_files/rfnv/00025179 384 bytes
Downloading file /nv/item_files/rfnv/00025288 384 bytes
Downloading file /nv/item_files/rfnv/00025394 384 bytes
Downloading file /nv/item_files/rfnv/00025479 1.69 Kb
Downloading file /nv/item_files/rfnv/00025481 737 bytes
Downloading file /nv/item_files/rfnv/00025760 1.67 Kb
Downloading file /nv/item_files/rfnv/00025761 745 bytes
Downloading file /nv/item_files/rfnv/00026584 289 bytes
Downloading file /nv/item_files/rfnv/00026599 289 bytes
Downloading file /nv/item_files/rfnv/00026600 289 bytes
Downloading file /nv/item_files/rfnv/00026603 289 bytes
Downloading file /nv/item_files/rfnv/00026650 1.54 Kb
Downloading file /nv/item_files/rfnv/00026652 1.54 Kb
Downloading file /nv/item_files/rfnv/00026654 1.54 Kb
Downloading file /nv/item_files/rfnv/00026656 1.54 Kb
Downloading file /nv/item_files/rfnv/00026658 805 bytes
Downloading file /nv/item_files/rfnv/00026660 1.54 Kb
Downloading file /nv/item_files/rfnv/00026662 805 bytes
Downloading file /nv/item_files/rfnv/00026666 805 bytes
Downloading file /nv/item_files/rfnv/00026672 805 bytes
Downloading file /nv/item_files/rfnv/00026678 1.54 Kb
Downloading file /nv/item_files/rfnv/00026686 1.54 Kb
Downloading file /nv/item_files/rfnv/00026865 805 bytes
Downloading file /nv/item_files/rfnv/00026867 805 bytes
Downloading file /nv/item_files/rfnv/00026873 805 bytes
Downloading file /nv/item_files/rfnv/00026875 805 bytes
Downloading file /nv/item_files/rfnv/00027157 131 bytes
Downloading file /nv/item_files/rfnv/00027158 131 bytes
Downloading file /nv/item_files/rfnv/00027159 131 bytes
Downloading file /nv/item_files/rfnv/00027193 1.54 Kb
Downloading file /nv/item_files/rfnv/00027293 1.00 Kb
Downloading file /nv/item_files/rfnv/00027294 1.00 Kb
Downloading file /nv/item_files/rfnv/00027345 129 bytes
Downloading file /nv/item_files/rfnv/00027346 129 bytes
Downloading file /nv/item_files/rfnv/00027349 129 bytes
Downloading file /nv/item_files/rfnv/00027350 129 bytes
Downloading file /nv/item_files/rfnv/00027391 129 bytes
Downloading file /nv/item_files/rfnv/00027392 129 bytes
Downloading file /nv/item_files/rfnv/00027393 129 bytes
Downloading file /nv/item_files/rfnv/00027394 129 bytes
Downloading file /nv/item_files/rfnv/00027395 129 bytes
Downloading file /nv/item_files/rfnv/00027397 129 bytes
Downloading file /nv/item_files/rfnv/00027398 129 bytes
Downloading file /nv/item_files/rfnv/00027405 129 bytes
Downloading file /nv/item_files/rfnv/00027408 129 bytes
Downloading file /nv/item_files/rfnv/00027414 129 bytes
Downloading file /nv/item_files/rfnv/00027421 129 bytes
Downloading file /nv/item_files/rfnv/00027426 129 bytes
Downloading file /nv/item_files/rfnv/00027473 131 bytes
Downloading file /nv/item_files/rfnv/00027474 131 bytes
Downloading file /nv/item_files/rfnv/00027475 131 bytes
Downloading file /nv/item_files/rfnv/00027476 131 bytes
Downloading file /nv/item_files/rfnv/00027477 131 bytes
Downloading file /nv/item_files/rfnv/00027478 131 bytes
Downloading file /nv/item_files/rfnv/00027479 131 bytes
Downloading file /nv/item_files/rfnv/00027480 131 bytes
Downloading file /nv/item_files/rfnv/00027481 131 bytes
Downloading file /nv/item_files/rfnv/00027482 131 bytes
Downloading file /nv/item_files/rfnv/00027656 464 bytes
Downloading file /nv/item_files/rfnv/00027657 464 bytes
Downloading file /nv/item_files/rfnv/00027658 464 bytes
Downloading file /nv/item_files/rfnv/00027659 464 bytes
Downloading file /nv/item_files/rfnv/00027675 464 bytes
Downloading file /nv/item_files/rfnv/00027683 464 bytes
Downloading file /nv/item_files/rfnv/00027699 464 bytes
Downloading file /nv/item_files/rfnv/00028049 416 bytes
Downloading file /nv/item_files/rfnv/00028050 384 bytes
Downloading file /nv/item_files/rfnv/00028051 375 bytes
Downloading file /nv/item_files/rfnv/00028052 345 bytes
Downloading file /nv/item_files/rfnv/00028053 393 bytes
Downloading file /nv/item_files/rfnv/00028055 315 bytes
Downloading file /nv/item_files/rfnv/00028056 402 bytes
Downloading file /nv/item_files/rfnv/00028065 273 bytes
Downloading file /nv/item_files/rfnv/00028068 363 bytes
Downloading file /nv/item_files/rfnv/00028076 454 bytes
Downloading file /nv/item_files/rfnv/00028077 454 bytes
Downloading file /nv/item_files/rfnv/00028089 403 bytes
Downloading file /nv/item_files/rfnv/00028148 328 bytes
Downloading file /nv/item_files/rfnv/00028150 354 bytes
Downloading file /nv/item_files/rfnv/00028156 358 bytes
Downloading file /nv/item_files/rfnv/00028158 258 bytes
Downloading file /nv/item_files/rfnv/00028170 348 bytes
Downloading file /nv/item_files/rfnv/00028171 374 bytes
Downloading file /nv/item_files/rfnv/00028172 353 bytes
Downloading file /nv/item_files/rfnv/00028173 355 bytes
Downloading file /nv/item_files/rfnv/00028174 281 bytes
Downloading file /nv/item_files/rfnv/00028176 323 bytes
Downloading file /nv/item_files/rfnv/00028177 305 bytes
Downloading file /nv/item_files/rfnv/00028184 320 bytes
Downloading file /nv/item_files/rfnv/00028187 264 bytes
Downloading file /nv/item_files/rfnv/00028193 329 bytes
Downloading file /nv/item_files/rfnv/00028194 329 bytes
Downloading file /nv/item_files/rfnv/00028202 436 bytes
Downloading file /nv/item_files/rfnv/00028216 201 bytes
Downloading file /nv/item_files/rfnv/00028217 210 bytes
Downloading file /nv/item_files/rfnv/00028220 150 bytes
Downloading file /nv/item_files/rfnv/00028221 175 bytes
Downloading file /nv/item_files/rfnv/00028493 204 bytes
Downloading file /nv/item_files/rfnv/00028494 208 bytes
Downloading file /nv/item_files/rfnv/00028495 211 bytes
Downloading file /nv/item_files/rfnv/00028496 211 bytes
Downloading file /nv/item_files/rfnv/00028499 205 bytes
Downloading file /nv/item_files/rfnv/00028525 204 bytes
Downloading file /nv/item_store/rfnv/rfc.bl 5 bytes
Downloading file /nv/item_store/rfnv/rfnv.bl 20 bytes
Downloading file /nv/reg_files/conf/policyman.conf 197 bytes
Downloading file /nv/reg_files/modem/lte/rrc/csp/acq_db 344 bytes
Backuping SNV [1] to file: Backups\H815P_snv1_359_2016-7-14_18-27-19.sbf
Dump SNV [1]: Start
Switching to SNV mode...
Reading SPC...
Reading SPC: OK
Sending SPC...
Sending SPC: OK
Switching to SNV mode: OK
Dumping SNV [1]...
Dumping SNV [1]: OK
Dump SNV [1]: Finish
Backuping SNV [2] to file: Backups\H815P_snv2_359_2016-7-14_18-30-57.sbf
Dump SNV [2]: Start
Reading SPC...
Reading SPC: OK
Sending SPC...
Sending SPC: OK
Dumping SNV [2]...
Dumping SNV [2]: OK
Dump SNV [2]: Finish
Checking Emergency Mode...
Mode: Normal
Switching to Emergency Mode...
Mode: Emergency
Checking connect in LAF-Emergency Mode...
Checking...
Checking connect in LAF-Emergency Mode: OK
Imei: 359
Pid: YE07S150601001597
ModelName: LG-H815P
BatteryLevel: 44%
DeviceSwVersion: H81510a
DeviceFactoryVersion: LGH815PAT-01-V10a-334-050-APR-29-2015+0
ChipsetPlatform: msm8992
HardwareRevision: rev_10
LafSwVersion: 1.1
DeviceFactoryOutVersion: LGH815PAT-00-V10a-OPT5-SP-APR-29-2015+0
Dumping Security Backup...
Reading modemst1 [58000, c00]
Reading modemst1: OK
Reading modemst2 [58c00, c00]
Reading modemst2: OK
Backuping Security to file: Backups\H815P_security_359_2016-7-14_18-35-21.sbf
Writing security to file...
Writing security to file: OK
Dumping Security Backup: OK
Flashing Patched Security...
Writing modemst1 [58000, c00]
Writing modemst1: OK
Writing modemst2 [58c00, c00]
Writing modemst2: OK
Flashing Patched Security: OK
Writing NVM-Backup from file: Backups\H815P_nvm_359_2016-7-14_18-16-26.sbf
Flash NVM: Start
Flashing NVM...
Flashing NVM: OK
Flash NVM: Finish
Writing EFS-Backup from file: Backups\H815P_efs_359_2016-7-14_18-22-1.sbf
Uploading file /nv/item_files/CoreCpu/CoreAll/Startup/Algorithm.txt 12 bytes
Uploading file /nv/item_files/CoreCpu/CoreAll/Startup/LogSize.uint 4 bytes
Uploading file /nv/item_files/CoreCpu/Default/Fixed/MIPS.uint 4 bytes
Uploading file /nv/item_files/CoreCpu/Default/Startup/AVSEnable.uint 4 bytes
Uploading file /nv/item_files/CoreCpu/Default/Startup/Algorithm.txt 8 bytes
Uploading file /nv/item_files/CoreCpu/Default/Startup/LogSize.uint 4 bytes
Uploading file /nv/item_files/CoreCpu/Default/qdsp_classic/HighThresholdBusyPct.uint 4 bytes
Uploading file /nv/item_files/CoreCpu/Default/qdsp_classic/SamplePeriod.uint 4 bytes
Uploading file /nv/item_files/conf/cgps_common.conf 56 bytes
Uploading file /nv/item_files/conf/cgps_me.conf 3.53 Kb
Uploading file /nv/item_files/conf/cgps_pdcomms.conf 212 bytes
Uploading file /nv/item_files/conf/cgps_pe.conf 478 bytes
Uploading file /nv/item_files/conf/cgps_sdp.conf 53 bytes
Uploading file /nv/item_files/conf/cgps_sm.conf 1.57 Kb
Uploading file /nv/item_files/conf/cgps_tle_tlm.conf 1.00 Kb
Uploading file /nv/item_files/conf/cgps_tle_xtm.conf 1.17 Kb
Uploading file /nv/item_files/conf/data_config_info.conf 5.40 Kb
Uploading file /nv/item_files/conf/data_profile.conf 154 bytes
Uploading file /nv/item_files/conf/dpm_config_info.conf 62 bytes
Uploading file /nv/item_files/conf/geran.conf 1.85 Kb
Uploading file /nv/item_files/conf/hdrcp_config_info.conf 465 bytes
Uploading file /nv/item_files/conf/hdrmac_config_info.conf 41 bytes
Uploading file /nv/item_files/conf/hdrmultirat_config_info.conf 48 bytes
Uploading file /nv/item_files/conf/hdrsrch_config_info.conf 418 bytes
Uploading file /nv/item_files/conf/ims.conf 3.08 Kb
Uploading file /nv/item_files/conf/ipa.conf 424 bytes
Uploading file /nv/item_files/conf/lte_a2.conf 348 bytes
Uploading file /nv/item_files/conf/lte_ml1_ant_switch.conf 45 bytes
Uploading file /nv/item_files/conf/lte_ml1_ant_switch_band.conf 50 bytes
Uploading file /nv/item_files/conf/lte_ml1_ant_switch_dr_dsds.conf 53 bytes
Uploading file /nv/item_files/conf/lte_ml1_ca_dynamic_cfg.conf 49 bytes
Uploading file /nv/item_files/conf/lte_ml1_debug_cfg.conf 47 bytes
Uploading file /nv/item_files/conf/lte_ml1_tput_test_cfg.conf 47 bytes
Uploading file /nv/item_files/conf/lte_rrc.conf 3.60 Kb
Uploading file /nv/item_files/conf/mc.conf 988 bytes
Uploading file /nv/item_files/conf/mcfg.conf 216 bytes
Uploading file /nv/item_files/conf/mcpm.conf 246 bytes
Uploading file /nv/item_files/conf/mcs_as_div.conf 43 bytes
Uploading file /nv/item_files/conf/mcs_cfcm.conf 288 bytes
Uploading file /nv/item_files/conf/mcs_cxm_coex.conf 40 bytes
Uploading file /nv/item_files/conf/mcs_limitsmgr.conf 5.09 Kb
Uploading file /nv/item_files/conf/mcs_pbr_info.conf 32 bytes
Uploading file /nv/item_files/conf/mcs_tcxomgr.conf 547 bytes
Uploading file /nv/item_files/conf/mmgsdi.conf 3.92 Kb
Uploading file /nv/item_files/conf/mmode.conf 2.74 Kb
Uploading file /nv/item_files/conf/nas_mm.conf 1.59 Kb
Uploading file /nv/item_files/conf/onex_mux.conf 47 bytes
Uploading file /nv/item_files/conf/onex_srch.conf 303 bytes
Uploading file /nv/item_files/conf/pbm.conf 278 bytes
Uploading file /nv/item_files/conf/ps_config_info.conf 664 bytes
Uploading file /nv/item_files/conf/qmi_data.conf 135 bytes
Uploading file /nv/item_files/conf/reg.conf 1.68 Kb
Uploading file /nv/item_files/conf/tdscdma_l1.conf 1.96 Kb
Uploading file /nv/item_files/conf/tdscdma_rrc.conf 2.18 Kb
Uploading file /nv/item_files/conf/thin_ui_config.conf 41 bytes
Uploading file /nv/item_files/conf/uimdrv.conf 407 bytes
Uploading file /nv/item_files/conf/wcdma_csg_efs_1.conf 3.63 Kb
Uploading file /nv/item_files/conf/wcdma_csg_efs_2.conf 3.63 Kb
Uploading file /nv/item_files/conf/wcdma_csg_efs_3.conf 3.63 Kb
Uploading file /nv/item_files/conf/wcdma_csg_efs_4.conf 3.63 Kb
Uploading file /nv/item_files/conf/wcdma_csg_efs_5.conf 3.63 Kb
Uploading file /nv/item_files/conf/wcdma_csg_efs_db.conf 54 bytes
Uploading file /nv/item_files/conf/wcdma_rrc_external.conf 2.12 Kb
Uploading file /nv/item_files/conf/wl1_cme.conf 210 bytes
Uploading file /nv/item_files/conf/wl1_rxd.conf 995 bytes
Uploading file /nv/item_files/conf/wms.conf 558 bytes
Uploading file /nv/item_files/mcs/cfcm/cfcm_config_cpu_dne_efs 0 bytes
Uploading file /nv/item_files/mcs/cfcm/cfcm_config_step_timer_efs 0 bytes
Uploading file /nv/item_files/mcs/cfcm/cfcm_cpu_threshold_limits 0 bytes
Uploading file /nv/item_files/mcs/cfcm/cfcm_fc_masks 0 bytes
Uploading file /nv/item_files/mcs/cxm/coex_config_data 4.09 Kb
Uploading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_lte_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/battery/bcl_gsm2_high_tdscdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/coex_simulation_input 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/1x_victim_gsm_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/1x_victim_lte_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/disable_sw_mitigation 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gps_victim_1x_lte_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm1_victim_gsm2_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm1_victim_gsm3_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm2_victim_gsm1_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm2_victim_gsm3_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm3_victim_gsm1_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm3_victim_gsm2_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_1x_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_hdr_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_lte_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_tdscdma_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/gsm_victim_wcdma_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/hdr_victim_gsm_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_1x_victim_hdr_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_1x_victim_lte_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_hdr_victim_1x_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/im_backoff_lte_victim_1x_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/lte_victim_gsm_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/tdscdma_victim_gsm_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense/wcdma_victim_gsm_aggr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/desense_ind_thresholds 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/force_filter_path 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/idle_mode_hopping_rxpwr_limit 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/coex/set_prio_tbl_action 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_hdr_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_1x_high_lte_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_1x_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_hdr_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_lte_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_tdscdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm1_high_wcdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_1x_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_hdr_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_lte_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_tdscdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_gsm2_high_wcdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_hdr_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_lte_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_tdscdma_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_dsi_bias_wcdma_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_gpio_settings 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_hdr_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_1x_high_lte_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_1x_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_hdr_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_lte_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_tdscdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm1_high_wcdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_1x_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_hdr_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_lte_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_tdscdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_gsm2_high_wcdma_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_hdr_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_lte_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_tdscdma_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm1_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_pwr_wcdma_high_gsm2_low 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sar/sar_qmi_comp_key 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_1x 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_hdr 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_tdscdma 0 bytes
Uploading file /nv/item_files/mcs/lmtsmgr/sem/sem_thresh_gsm_wcdma 0 bytes
Uploading file /nv/item_files/mcs/tcxomgr/ft_table_gps 768 bytes
Uploading file /nv/item_files/mcs/tcxomgr/ft_table_wwan 768 bytes
Uploading file /nv/item_files/modem/lte/rrc/csp/sec_inactive_rlf_recovery 1 bytes
Uploading file /nv/item_files/modem/mmode/sw_version 61 bytes
Uploading file /nv/item_files/modem/tdscdma/rrc/acq_list 992 bytes
Uploading file /nv/item_files/modem/uim/mmgsdi/mmgsdi_diag_support 1 bytes
Uploading file /nv/item_files/modem/uim/uimdrv/uim_hw_config 256 bytes
Uploading file /nv/item_files/rfnv/00022982 484 bytes
Uploading file /nv/item_files/rfnv/00024226 777 bytes
Uploading file /nv/item_files/rfnv/00024227 782 bytes
Uploading file /nv/item_files/rfnv/00024228 768 bytes
Uploading file /nv/item_files/rfnv/00024229 759 bytes
Uploading file /nv/item_files/rfnv/00024230 737 bytes
Uploading file /nv/item_files/rfnv/00024232 765 bytes
Uploading file /nv/item_files/rfnv/00024233 763 bytes
Uploading file /nv/item_files/rfnv/00024240 781 bytes
Uploading file /nv/item_files/rfnv/00024243 727 bytes
Uploading file /nv/item_files/rfnv/00024250 789 bytes
Uploading file /nv/item_files/rfnv/00024252 766 bytes
Uploading file /nv/item_files/rfnv/00024253 779 bytes
Uploading file /nv/item_files/rfnv/00024255 784 bytes
Uploading file /nv/item_files/rfnv/00024256 797 bytes
Uploading file /nv/item_files/rfnv/00024964 193 bytes
Uploading file /nv/item_files/rfnv/00024965 193 bytes
Uploading file /nv/item_files/rfnv/00024966 193 bytes
Uploading file /nv/item_files/rfnv/00024967 193 bytes
Uploading file /nv/item_files/rfnv/00024972 2.97 Kb
Uploading file /nv/item_files/rfnv/00024973 2.97 Kb
Uploading file /nv/item_files/rfnv/00024974 2.49 Kb
Uploading file /nv/item_files/rfnv/00024975 2.49 Kb
Uploading file /nv/item_files/rfnv/00025004 192 bytes
Uploading file /nv/item_files/rfnv/00025005 192 bytes
Uploading file /nv/item_files/rfnv/00025006 192 bytes
Uploading file /nv/item_files/rfnv/00025007 192 bytes
Uploading file /nv/item_files/rfnv/00025044 160 bytes
Uploading file /nv/item_files/rfnv/00025045 160 bytes
Uploading file /nv/item_files/rfnv/00025046 160 bytes
Uploading file /nv/item_files/rfnv/00025047 160 bytes
Uploading file /nv/item_files/rfnv/00025179 384 bytes
Uploading file /nv/item_files/rfnv/00025288 384 bytes
Uploading file /nv/item_files/rfnv/00025394 384 bytes
Uploading file /nv/item_files/rfnv/00025479 1.69 Kb
Uploading file /nv/item_files/rfnv/00025481 737 bytes
Uploading file /nv/item_files/rfnv/00025760 1.67 Kb
Uploading file /nv/item_files/rfnv/00025761 745 bytes
Uploading file /nv/item_files/rfnv/00026584 289 bytes
Uploading file /nv/item_files/rfnv/00026599 289 bytes
Uploading file /nv/item_files/rfnv/00026600 289 bytes
Uploading file /nv/item_files/rfnv/00026603 289 bytes
Uploading file /nv/item_files/rfnv/00026650 1.54 Kb
Uploading file /nv/item_files/rfnv/00026652 1.54 Kb
Uploading file /nv/item_files/rfnv/00026654 1.54 Kb
Uploading file /nv/item_files/rfnv/00026656 1.54 Kb
Uploading file /nv/item_files/rfnv/00026658 805 bytes
Uploading file /nv/item_files/rfnv/00026660 1.54 Kb
Uploading file /nv/item_files/rfnv/00026662 805 bytes
Uploading file /nv/item_files/rfnv/00026666 805 bytes
Uploading file /nv/item_files/rfnv/00026672 805 bytes
Uploading file /nv/item_files/rfnv/00026678 1.54 Kb
Uploading file /nv/item_files/rfnv/00026686 1.54 Kb
Uploading file /nv/item_files/rfnv/00026865 805 bytes
Uploading file /nv/item_files/rfnv/00026867 805 bytes
Uploading file /nv/item_files/rfnv/00026873 805 bytes
Uploading file /nv/item_files/rfnv/00026875 805 bytes
Uploading file /nv/item_files/rfnv/00027157 131 bytes
Uploading file /nv/item_files/rfnv/00027158 131 bytes
Uploading file /nv/item_files/rfnv/00027159 131 bytes
Uploading file /nv/item_files/rfnv/00027193 1.54 Kb
Uploading file /nv/item_files/rfnv/00027293 1.00 Kb
Uploading file /nv/item_files/rfnv/00027294 1.00 Kb
Uploading file /nv/item_files/rfnv/00027345 129 bytes
Uploading file /nv/item_files/rfnv/00027346 129 bytes
Uploading file /nv/item_files/rfnv/00027349 129 bytes
Uploading file /nv/item_files/rfnv/00027350 129 bytes
Uploading file /nv/item_files/rfnv/00027391 129 bytes
Uploading file /nv/item_files/rfnv/00027392 129 bytes
Uploading file /nv/item_files/rfnv/00027393 129 bytes
Uploading file /nv/item_files/rfnv/00027394 129 bytes
Uploading file /nv/item_files/rfnv/00027395 129 bytes
Uploading file /nv/item_files/rfnv/00027397 129 bytes
Uploading file /nv/item_files/rfnv/00027398 129 bytes
Uploading file /nv/item_files/rfnv/00027405 129 bytes
Uploading file /nv/item_files/rfnv/00027408 129 bytes
Uploading file /nv/item_files/rfnv/00027414 129 bytes
Uploading file /nv/item_files/rfnv/00027421 129 bytes
Uploading file /nv/item_files/rfnv/00027426 129 bytes
Uploading file /nv/item_files/rfnv/00027473 131 bytes
Uploading file /nv/item_files/rfnv/00027474 131 bytes
Uploading file /nv/item_files/rfnv/00027475 131 bytes
Uploading file /nv/item_files/rfnv/00027476 131 bytes
Uploading file /nv/item_files/rfnv/00027477 131 bytes
Uploading file /nv/item_files/rfnv/00027478 131 bytes
Uploading file /nv/item_files/rfnv/00027479 131 bytes
Uploading file /nv/item_files/rfnv/00027480 131 bytes
Uploading file /nv/item_files/rfnv/00027481 131 bytes
Uploading file /nv/item_files/rfnv/00027482 131 bytes
Uploading file /nv/item_files/rfnv/00027656 464 bytes
Uploading file /nv/item_files/rfnv/00027657 464 bytes
Uploading file /nv/item_files/rfnv/00027658 464 bytes
Uploading file /nv/item_files/rfnv/00027659 464 bytes
Uploading file /nv/item_files/rfnv/00027675 464 bytes
Uploading file /nv/item_files/rfnv/00027683 464 bytes
Uploading file /nv/item_files/rfnv/00027699 464 bytes
Uploading file /nv/item_files/rfnv/00028049 416 bytes
Uploading file /nv/item_files/rfnv/00028050 384 bytes
Uploading file /nv/item_files/rfnv/00028051 375 bytes
Uploading file /nv/item_files/rfnv/00028052 345 bytes
Uploading file /nv/item_files/rfnv/00028053 393 bytes
Uploading file /nv/item_files/rfnv/00028055 315 bytes
Uploading file /nv/item_files/rfnv/00028056 402 bytes
Uploading file /nv/item_files/rfnv/00028065 273 bytes
Uploading file /nv/item_files/rfnv/00028068 363 bytes
Uploading file /nv/item_files/rfnv/00028076 454 bytes
Uploading file /nv/item_files/rfnv/00028077 454 bytes
Uploading file /nv/item_files/rfnv/00028089 403 bytes
Uploading file /nv/item_files/rfnv/00028148 328 bytes
Uploading file /nv/item_files/rfnv/00028150 354 bytes
Uploading file /nv/item_files/rfnv/00028156 358 bytes
Uploading file /nv/item_files/rfnv/00028158 258 bytes
Uploading file /nv/item_files/rfnv/00028170 348 bytes
Uploading file /nv/item_files/rfnv/00028171 374 bytes
Uploading file /nv/item_files/rfnv/00028172 353 bytes
Uploading file /nv/item_files/rfnv/00028173 355 bytes
Uploading file /nv/item_files/rfnv/00028174 281 bytes
Uploading file /nv/item_files/rfnv/00028176 323 bytes
Uploading file /nv/item_files/rfnv/00028177 305 bytes
Uploading file /nv/item_files/rfnv/00028184 320 bytes
Uploading file /nv/item_files/rfnv/00028187 264 bytes
Uploading file /nv/item_files/rfnv/00028193 329 bytes
Uploading file /nv/item_files/rfnv/00028194 329 bytes
Uploading file /nv/item_files/rfnv/00028202 436 bytes
Uploading file /nv/item_files/rfnv/00028216 201 bytes
Uploading file /nv/item_files/rfnv/00028217 210 bytes
Uploading file /nv/item_files/rfnv/00028220 150 bytes
Uploading file /nv/item_files/rfnv/00028221 175 bytes
Uploading file /nv/item_files/rfnv/00028493 204 bytes
Uploading file /nv/item_files/rfnv/00028494 208 bytes
Uploading file /nv/item_files/rfnv/00028495 211 bytes
Uploading file /nv/item_files/rfnv/00028496 211 bytes
Uploading file /nv/item_files/rfnv/00028499 205 bytes
Uploading file /nv/item_files/rfnv/00028525 204 bytes
Uploading file /nv/item_store/rfnv/rfc.bl 5 bytes
Uploading file /nv/item_store/rfnv/rfnv.bl 20 bytes
Uploading file /nv/reg_files/conf/policyman.conf 197 bytes
Uploading file /nv/reg_files/modem/lte/rrc/csp/acq_db 344 bytes
Writing SNV-Backup [1] from file: Backups\H815P_snv1_3_2016-7-14_18-27-19.sbf
Flash SNV [1]: Start
Reading SPC...
Reading SPC: OK
Sending SPC...
Sending SPC: OK
Flashing SNV [1]...
Flashing SNV [1]: OK
Flash SNV [1]: Finish
Writing SNV-Backup [2] from file: Backups\H815P_snv2_35-7-14_18-30-57.sbf
Flash SNV [2]: Start
Reading SPC...
Reading SPC: OK
Sending SPC...
Sending SPC: OK
Flashing SNV [2]...
Flashing SNV [2]: OK
Flash SNV [2]: Finish
Please make Factory Reset manually via Android menu (Settings -> General -> Backup & Reset -> Factory data reset -> Reset phone -> Erase everything).
Unlock: Finish
Phone successfully unlocked
Page generated in 0.34158 seconds with 8 queries
