11-17-2013, 11:16 | #16 (permalink) |
No Life Poster Join Date: Dec 2010 Location: algeria
Member: 1480336 Status: Offline Sonork: 100.1606959 Thanks Meter: 76 | EROM_AID : 0001 LOADER_AID : 0004 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 SIMLOCK STATE: "NOT TAMPERED" DEVICE ID: 957D83B0D6DF3563E16331F1328984C0028C150B FLASH ID: "00EC/0040" LOADER VERSION: "R4A048" PHONE IMEI : 01233200654846 MODEL (from GDFS): U5i |
11-17-2013, 11:20 | #17 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: jamshedpur Age: 38
Member: 59185 Status: Offline Sonork: 100.1593175 Thanks Meter: 4,911 | Quote:
hi , did you see vivaz in above thread title ?????? | |
The Following User Says Thank You to lalitjsraks For This Useful Post: |
11-18-2013, 20:08 | #19 (permalink) |
Freak Poster Join Date: Aug 2012 Location: LC
Member: 1793281 Status: Offline Thanks Meter: 167 | C1505 unlock done, but can't read TA Code: SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 DEVICE ID: 744166CB33EADA15D4A7854380100169FA0FF005 FLASH ID: "0003/00000015" LOADER VERSION: "R5D030" PHONE IMEI : 35742105532992 MODEL (from GDFS): C1505 SOFTWARE VERSION: 1267-9537_11.3.A.2.13 CUSTOM VERSION: 1271-7587_R7E FILESYSTEM VERSION: ORANGE_11.3.A.2.13 Network LOCK : 26003-* MINOR ERROR [ read_TA_unit_fail, err: 0013 ] Elapsed: 27 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 DEVICE ID: 744166CB33EADA15D4A7854380100169FA0FF005 FLASH ID: "0003/00000015" LOADER VERSION: "R5D030" PHONE IMEI : 35742105532992 Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1520] REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED WARMING UP ... CHECKING ROOT ACCESS ... GETTING ROOT ACCESS ... PROCESSING ... C1505 [27dc1c8e] FINALIZING ... Unlock DONE Elapsed: 104 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "r10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 DEVICE ID: 744166CB33EADA15D4A7854380100169FA0FF005 FLASH ID: "0003/00000015" LOADER VERSION: "r5D030" PHONE IMEI : 35742105532992 MODEL (from GDFS): C1505 SOFTWARE VERSION: 1267-9537_11.3.A.2.13 CUSTOM VERSION: 1271-7587_R7E FILESYSTEM VERSION: ORANGE_11.3.A.2.13 MINOR ERROR [ read_TA_unit_fail, err: 0013 ] Elapsed: 14 secs. |
11-19-2013, 16:23 | #20 (permalink) |
No Life Poster Join Date: Feb 2008 Location: turkey
Member: 706822 Status: Offline Thanks Meter: 647 | ST21İ UNLOCK FAİLED. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 DEVICE ID: B988087D69892CEB9772A805D19E056D5A05EDDF FLASH ID: "0003/00000015" LOADER VERSION: "R5D030" PHONE IMEI : 3 Checking for signature ... Waiting for calculation process ... recv error [10054] signature calculation not done,err: 144 Unlock FAILED Elapsed: 17 secs. |
11-24-2013, 14:58 | #25 (permalink) |
Freak Poster Join Date: Mar 2011
Member: 1527517 Status: Offline Sonork: 100.1607096 Thanks Meter: 9 | pleass hilp me st21i PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 DEVICE ID: 086F03F147CDD5ED9DA8FE8698C1C09665A45BA2 FLASH ID: "0003/00000015" LOADER VERSION: "R5D030" PHONE IMEI : 35587505086543 Checking for signature ... signature found, skipping calculation REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED WARMING UP ... USING ADB v1.0.26 RecvANSW(): failed to recv status, got: FFFFFFFF (code: 10054 / Connection reset by peer) Unlock FAILED Elapsed: 47 secs. |
11-24-2013, 15:29 | #26 (permalink) |
Product Manager Join Date: Sep 2009 Location: Pakistan Age: 36
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | askjour IF U r Using Latest Version & u Facing same Problem then download this executable and replace with it original from v1.1403 test and report here again |
11-24-2013, 15:46 | #27 (permalink) | |
Freak Poster Join Date: Feb 2011 Location: P-h
Member: 1507600 Status: Offline Thanks Meter: 33 | from the_laser word Quote:
11-24-2013, 16:51 | #28 (permalink) |
Member: 1527517 Status: Offline Sonork: 100.1607096 Thanks Meter: 9 | hi thak you? lalitjsraks CFG:110011000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "R10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 DEVICE ID: 086F03F147CDD5ED9DA8FE8698C1C09665A45BA2 FLASH ID: "0003/00000015" LOADER VERSION: "R5D030" PHONE IMEI : 35587505086543 Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1520] REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED WARMING UP ... USING ADB v1.0.26 CHECKING ROOT ACCESS ... GETTING ROOT ACCESS ... PROCESSING ... ST21i [YT90064FF5] FINALIZING ... Unlock DONE Elapsed: 281 secs. |
