Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > PolarBox 3 > 3GKey / BB-Box
Old 03-12-2013, 15:29   #1 (permalink)
Member: 581508
Thanks Meter: 5
Plz help I cant certifacte my box always time out [SOLVED]
hello there
iam using last update but every time i try to certifacte my dongle
i get always error time out
iam using sat tool 1.4.2
and 3gkey 1.33
my serial is A00002ABC00
tyhanx in advance
Old 03-13-2013, 16:43   #2 (permalink)
wendigo's Avatar
Member: 10286
Sonork: 100.90962
Thanks Meter: 4,353
Im checking this problem now ...
Sorry for the inconvenience.
Old 03-13-2013, 17:52   #3 (permalink)
wendigo's Avatar
Member: 10286
Sonork: 100.90962
Thanks Meter: 4,353
Problem solved.
Try again
Old 03-31-2013, 04:31   #4 (permalink)
anrmobile's Avatar
Member: 1680232
Sonork: 100.1611221
Thanks Meter: 227
10:29:35 PM Requesting certificates to server...
A01
Check Connection
cant seem to get the certificate to use this project
box serial : A00001e7300
Help Needed Urgently
Regards
Old 04-30-2013, 17:27   #5 (permalink)
Member: 542837
Thanks Meter: 6
Hi to all, have same problem:
18.24.13 Connecting with Main Server...
A01
Check Connection
box serial A0000743000
Thanx
Old 04-30-2013, 17:37   #6 (permalink)
Member: 542837
Thanks Meter: 6
Have requested certified and now the box serial is changed...now is different.
Old 05-02-2013, 11:25   #7 (permalink)
wendigo's Avatar
Member: 10286
Sonork: 100.90962
Thanks Meter: 4,353
Hi, so finally box is working or not ???
Are you using last 3g-key version ???
Download here : http://www.3g-key.com/downloads/3GKe...Setup_v134.zip
Old 06-21-2013, 03:30   #8 (permalink)
Member: 861422
Smile 3gkey
hi my box always socket error and at bottom unregister not configured please help a00002dd000
Old 06-21-2013, 11:04   #9 (permalink)
The_Gorr's Avatar
Member: 145648
Sonork: 100.100487 The_Gorr
Thanks Meter: 23,034
please install last update http://www.3g-key.com/downloads/3GKe...Setup_v135.zip
Old 06-22-2013, 02:10   #10 (permalink)
Member: 861422
socket error
did not work i installed new version .. which i already had .. deleted and reinstalled it does it on all my computers...saids unregistered or not configured.. socket error connection refused
Old 06-22-2013, 14:07   #11 (permalink)
The_Gorr's Avatar
Member: 145648
then check from ur side, somthing should bloc ur access to polar server (firewell or antivirus)
Old 06-22-2013, 17:52   #12 (permalink)
Member: 861422
my box does the same on all three computers socket error 10061 my firewall is turned off and antivirus can you check my serial numero please a00002dd000
Old 06-22-2013, 18:16   #13 (permalink)
Member: 861422
12:14:30 p.m. -- System scan for drivers --
Driver: e-gate Smart Card
Disabled: "false"
Install-Failed: "false"
Removed: "false"
InstallState: "Error"
Config-Flags: "0"
Description: "e-gate Smart Card"
Hardware ID: "USB\VID_0973&PID_0001&REV_0100"
GUID: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0003"
UpperFilters: ""
LowerFilters: ""
Driver: PolarBox Ftdi
Disabled: "false"
Removed: "false"
InstallState: "0"
Config-Flags: "0"
Description: "PolarBox Ftdi"
Hardware ID: "USB\VID_0999&PID_6028&REV_0400"
GUID: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}"
Driver: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}\0006"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0023"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0004"
UpperFilters: ""
LowerFilters: ""
Driver: USB Token Device
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Description: "USB Token Device"
Hardware ID: "USB\VID_096E&PID_0005&REV_0260"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0013"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0019"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0033"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0005"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0029"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}\0000"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0001"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}\0005"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0015"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}\0004"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0011"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}\0003"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0028"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}\0001"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0026"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{990a2bd7-e738-46c7-b26f-1cf8fb9f0a90}\0002"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0027"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0018"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
InstallState: "0"
Config-Flags: "0"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0041"
UpperFilters: ""
LowerFilters: ""
Disabled: "false"
Removed: "false"
Config-Flags: "0"
Driver: "{50dd5230-ba8a-11d1-bf5d-0000f805f530}\0040"
UpperFilters: ""
LowerFilters: ""
[3] 12:14:33 p.m. SmartCard Driver (OK)
[4] 12:14:33 p.m. Certificates (OK)
[5] 12:14:34 p.m. Box integrity (OK)
[5] 12:14:55 p.m. Server account (ERR)
Page generated in 0.24173 seconds with 8 queries
