Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UCT (Universal China Tool) by ET
Old 03-26-2011, 20:42   #1 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Thanks Meter: 2,252
Tutorial: How to Full Erase a Flash Chip of a MTK as well as a SPD Handset
Easy instructions on: How to Full Erase a Flash Chip of a MTK as well as a SPD Handset
First, most important, why do we need to full erase?
Sometimes writting flash files to chinese phones is a big problem. even if u got everything ok, it might give error at some percentage. sometimes stuck at 10%, sometimes stuck at 15%. As per my personal experience, Full erasing has always been usefull before flashing. Either that be chinese phones or be nokia phones
Step-by-Step Guide on how to erase full flash of your chinese handset:
  1. Read the Information of the handset (Also read full flash backup of handset in case u need it in future)
  2. At the bottom of the information read, you can notice how much size is your flash chip. like in our example SpreadTrum handset, its 64mb
  3. Now select "Format", Uncheck "Auto Format"
  4. Enter the hex size "0x04000000" in the "Size" field, (Leave the Start field as it is)
  5. Press Start and your phone will be full erased in few seconds.
Now most important is to put correct size for formatting.
Depending on your flash size you need to enter the correct format size, the details are as follows:
  • If your handset Flash is 8mb, then enter format size = 0x00800000 for Full Erase
  • If your handset Flash is 16mb, then enter format size = 0x01000000 for Full Erase
  • If your handset Flash is 32mb, then enter format size = 0x02000000 for Full Erase
  • If your handset Flash is 64mb, then enter format size = 0x04000000 for Full Erase
To Prove this, we also made a simple test. We read the flash before formatting a handset.
Now when this readed flash file is opened in a hex editing software we see this:
But after formatting the handset with size "0x04000000" and reading the flash file again. What we see now in Hex editing software is this:
Hence Proved
Br.
Naman
The Following 6 Users Say Thank You to nonu_don For This Useful Post:
Old 10-18-2011, 02:11   #2 (permalink)
zishanm's Avatar
Member: 1535468
Sonork: 100.161922
Thanks Meter: 311
thanks for this sport bro is very nice..................
Old 10-28-2011, 13:11   #3 (permalink)
Member: 1669670
Sonork: 4097
hai iwant to download mtk cpu flash file please gaid me
Old 11-02-2011, 16:06   #4 (permalink)
Member: 258525
Thanks Meter: 44
How to recognize the device it is MTK or Spreadtrum or any other need help plzzz
Old 11-02-2011, 16:29   #5 (permalink)
pocketmar's Avatar
Member: 969337
Sonork: 100.1608846
Thanks Meter: 32
Hence Proved
Br.
Naman
thank you sir very nice and useful post.
The Following User Says Thank You to pocketmar For This Useful Post:
Old 11-03-2011, 19:23   #6 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Thanks Meter: 2,252
Please login to UCT Box official support area, where you can download all mtk handset flash files. for more details please visit : UCT Box - Support
Br.
Naman
Old 11-03-2011, 19:25   #7 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Thanks Meter: 2,252
http://forum.gsmhosting.com/vbb/f596...tware-1250533/
Br.
Naman
Old 01-07-2012, 14:55   #8 (permalink)
Member: 666294
Thanks Meter: 19
how to erase 2mb flash file..?
Old 01-12-2012, 04:24   #9 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Thanks Meter: 2,252
  2. Now select "Format", Uncheck "Auto Format"
  3. Enter the hex size 0x00200000 in the "Size" field, (Leave the Start field as it is)
  4. Press Start and your phone will be full erased in few seconds.
Let me know if still any problem.
Br.
Naman
The Following User Says Thank You to nonu_don For This Useful Post:
Old 03-23-2017, 16:28   #10 (permalink)
Member: 2696548
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164040502A2DC83C10F
Initialize Memory ...
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x20000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x00 , OEM : 0000
[eMMC] : FLASH_INF : [NOT_IN_BASE] ,
[eMMC] : FLASH_CID : 00000000000000000000000000000000
[eMMC] : FLASH_BRT : 0x00000000 , 0x00000000 , 0x00000000
[eMMC] : FLASH_LEN : 0x0000000000000000
[eMMC] : FLASH_UCP : 0 MiB [eMMC BAD_CONN]
DEV RID : 0xF4C7246220FEAE7087E1CA964A130CC0
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : DA_HANDSET_ROM_INFO_NOT_FOUND
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s3511 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 3572 mV
BL : [WARNING] : BatteryLevel LOW!!!
Backup enabled!
Backup Failed : Device memory erased / not initialized!
Continue flashing without backup!
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase Error! Something went wrong!
Operation Failed
Elapsed: 00:00:29
Reconnect Power/Cable!
MTK 6572 flash full erased, how to fix?
solution plz???
Old 03-23-2017, 16:46   #11 (permalink)
Member: 1948608
Thanks Meter: 1,744
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Switching to HSUSB
HSUSB Init Ok
Backup enabled!
Operation Failed
Elapsed: 00:00:29
solution plz???
init preloader [try to write preloader only ] wit CM2...if preloader init success than write full flash.
Old 03-24-2017, 14:27   #12 (permalink)
Member: 2696548
Thanks , But it does't work
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.26814 seconds with 9 queries
