Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UCT (Universal China Tool) by ET
Old 03-26-2011, 11:32   #1 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Thanks Meter: 2,252
Tutorial: Fix "Conjunction Box" error while UpGrading firmware of UCT Box
Easy intructions on: How to Solve "Conjunction Box" error while UpGrading firmware of your UCT Box
You may get "Conjunction Box" error while upgrading the firmware of your UCT Box. This can be due to many reasons. Can be due to incomplete upgrade of firmware, bad voltage spikes can corrupt the firmware inside UCT Box, can be due to some bugs too.
But this can be solved easy with the UCT Box Fiwmare UpGrade Utility.
To fix this. you need to fix the complete firmware by using "Emmergency UpGrade" feature.
  1. Disconnect UCT Box from USB, connect the main cable to UCT Box.
  2. Now short the "+" and "-" wires of the main cable
  3. Connect computer with USB to UCT Box.
  4. Open the latest Update software for UCT Box. Press "ScanPort", Select your UCT Box comm port number, tick the "Exigency UpGrade" and press "UpGrade-BOX"
All should be ok now.
If still any problem, then try repeat it 2-3 times.
If still not help, then your box have a hardware problem, please contact your reseller.
Br.
Naman
The Following 5 Users Say Thank You to nonu_don For This Useful Post:
Old 03-26-2011, 11:34   #2 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Nice
This will help lot of user
br,
vijay-gsm
Old 07-27-2012, 05:45   #3 (permalink)
tavo_unlock's Avatar
Member: 817412
Sonork: 1618066
Thanks Meter: 69
plizz is possibl convert uct in gpg dragon
http://forum.gsmhosting.com/vbb/f83/...-02-a-1510664/
Old 08-01-2012, 13:42   #4 (permalink)
mohideen77752's Avatar
Member: 1772238
Sonork: 100.1617698
Thanks Meter: 126
http://forum.gsmhosting.com/vbb/f596...-here-1514443/
Old 08-11-2012, 08:29   #5 (permalink)
p.k510's Avatar
Member: 1778370
Sonork: sujan_goa
Thanks Meter: 66
wel come uct team.............................
The Following User Says Thank You to p.k510 For This Useful Post:
Old 08-12-2012, 10:11   #6 (permalink)
MUKESH RAJ's Avatar
Member: 1084080
Thanks Meter: 8,243
Nice opfretion man .......................
Old 08-31-2012, 19:32   #7 (permalink)
Member: 1733110
sir i convert my uct box to dragon but dragon not work i want to back how can i do this pls guide me
Old 09-11-2012, 14:56   #8 (permalink)
solitaire09's Avatar
Member: 1687184
Sonork: 100.1621473
Thanks Meter: 24
just upgrade firmware again using latest UCT firmware ...
Solitaire09
Old 07-29-2013, 08:45   #9 (permalink)
venusmobilecare's Avatar
Member: 572808
Thanks Meter: 607
sir please upload uct firmware upgrade software
Old 10-30-2013, 08:26   #10 (permalink)
Member: 2055456
Sonork: 568122
uct is athirdclass softwear
Old 11-30-2013, 13:24   #11 (permalink)
Registered User
Member: 256504
Thanks Meter: 6
sir i converted my uct box to dragon box by tool but i want to change it to uct back again and now uct upgrade tool is in congenction box error please help i am w8ing for ur help
Old 05-05-2014, 16:08   #12 (permalink)
gsm-mobi's Avatar
Member: 931237
Sonork: 51812884
Thanks Meter: 98
bro my box is china king do u want to convert china king to gpg dragon plz hilp
The Following User Says Thank You to gsm-mobi For This Useful Post:
Old 07-25-2014, 23:44   #13 (permalink)
Member: 2177978
Sonork: 100.1614120
Thanks Meter: 6
All who want to convert back on uct again just do simple process write uct box firmware again on box
all other steps same which you use when convert in dragon
Naksh
Old 06-21-2015, 06:16   #14 (permalink)
Member: 1917408
plz help me
i do everything
Page generated in 0.24005 seconds with 8 queries
