03-02-2010, 20:55 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: here
Member: 20953 Status: Offline Thanks Meter: 94 | S5230 unlock error !!! [ANSWERED] detecting. . . found! phone mode : #NORMAL# model : GT-S5230 imei no. : 357952-03-32xxxx-1 fw version : S5230BBIG unique id : 55190000378283 patience, BOOTmode sequence activating. . . [!] NANO-DBG.UART.Error* receive[] missing A5_resp |
03-03-2010, 01:30 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | check if phone code is activated, if yes, desable it also try to reinstall drivers, it's possible they cause this error br <= The_Gorr => |
03-03-2010, 06:22 | #3 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Hello, Reading Simlock Codes Should install broadcom2 drivers When BootMode Sequence Try to be Engaged if it fails ...Such error will come Retry Should Work Fine.. I saw encounter this error but was Ok in second TRY |
03-03-2010, 10:36 | #4 (permalink) |
Member: 20953 Status: Offline Thanks Meter: 94 | thanks for the answers... will try again next time i get this model! I tried a few times and I made sure the drivers were downloaded from nanobox support and installed but I was always getting that error... maybe resetting the phone was going to fix this but the customer did not want to lose the info on the phone so I had to use another tool to unlock it. |
03-04-2010, 06:11 | #5 (permalink) |
Member: 91045 Status: Offline Thanks Meter: 8,696 | No the Problem ONly was When phone changes it Mode to bootloader for its final Step for unlocking through server Due to some communication timing prob etc it fails phone gets ON and u will recieve such error as above... here i personally tested today ...got same issue for first time...secondly gets OK http://forum.gsmhosting.com/vbb/show...5&postcount=42 Last edited by Amir-SkillZ; 03-04-2010 at 06:18. |
vodafone sagem 231 unlock error[ANSWERED] | anam120 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 11 | 01-02-2011 13:50 |
S5230 Unlocking ERROR | equinoks | Easy-Unlocker | 5 | 10-01-2010 21:05 |
samsung s5230 again error [ANSWERED] | lusomaco | PolarBox 3 | 10 | 03-22-2010 18:05 |
Error lg tu720 unlock error[ANSWERED] | baooshe2 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 3 | 03-02-2010 23:59 |
s5230 unlock error | cejer | UST Pro II | 2 | 08-21-2009 18:44 |
