10-27-2010, 15:59 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Spain
Member: 1134315 Status: Offline Thanks Meter: 51 | Help unlocking E250 [ANSWERED] when I select it in nano soft, it tells me that I have to use nano rj-45 E210. I have one than comes with my nano (from Ip-mart) but the problem is that it doesn't fit! It's a little more big. Then I decided to buy another one to a spanish reseller. I get last day but what is my sorprise that it's the same form ip-mart!!! I don't understand. It's the cable, isn't it? Where can I buy a good E210 cable?? |
10-27-2010, 18:23 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | yes freind, this is a mistake inside cable description, correct cable is D800 br <= The_Gorr => |
The Following User Says Thank You to The_Gorr For This Useful Post: |
10-29-2010, 14:48 | #5 (permalink) |
Member: 1134315 Status: Offline Thanks Meter: 51 | Hi, here I again. I have bought a D800 cable, but now I get this error: push POWER ON key when phone cannot enter TAT searching on = #NANOBox RS232# detecting. . . found! phone mode : #TAT# model : E250 imei no. : 111100-00-001430-0020 fw version : E250JCFL1 # MP 1.705 patience, reading msl. . . MSL address : RV5P857066 patience, calculating MSL code[Method 1]. . . [!] NANO-DBG.Prot.Error* cannot calc.MSL code, give up ###### probably MSL16 repeat in BOOT mode(if available) ###### I have installed XP SP3. Please help! Nano soft 1.03.3 Last edited by piroxi; 10-29-2010 at 14:50. Reason: nano soft |
10-29-2010, 15:29 | #6 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | for e250 u have direct unlock and read code, so u can try both also u can test selecting E250D/E250V br <= The_Gorr => |
10-29-2010, 17:57 | #7 (permalink) |
Member: 1134315 Status: Offline Thanks Meter: 51 | Only in E250V, read simlockcodes, I get this: push POWER ON key when phone cannot enter TAT searching on = #NANOBox RS232# detecting. . . found! phone mode : #TAT# patience, reading msl. . . model : E250 fw version : E250JCFL1 # MP 1.705 imei no. : 111100-00-009335-373 patience, collecting data. . . external task : #contacting server# #=========================================# | Unfreeze code= br_ok_en_ | | Network lock= #7465625*638*br_ok_en_# | | Subset lock= #7465625*782*br_ok_en_# | | SP lock= #7465625*77*br_ok_en_# | | CP lock= #7465625*27*br_ok_en_# | | Activa lock= #7465625*228*br_ok_en_# | | SIM lock= br_ok_en_ / | | Phone lock= br_ok_en_ / | | Private lock= br_ok_en_ / | #=========================================# === = = = = = = = = = = = = = === total time: 00:00:13 (hour:min:sec) |
10-29-2010, 18:08 | #8 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | now is more clear, i think ur phone imei need to be repaired, use repair imei button, write correct imei to phone, then unlock br <= The_Gorr => |
10-29-2010, 18:18 | #9 (permalink) |
Member: 1134315 Status: Offline Thanks Meter: 51 | You are in the way: the imei looks to be wrong. But if I try to repair in 250/250D it gives me the same error. Only it looks to work in 250V, but Repair Imei it's "off" |
10-29-2010, 18:36 | #12 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | try this : start phone without sim and type *2767*3855# phone should restart after resart connect it to box and try to repair imei then unlock (try read code and direct unlock) br <= The_Gorr => |
10-29-2010, 18:50 | #13 (permalink) |
Member: 1134315 Status: Offline Thanks Meter: 51 | Not works bro. Only 250V seems to work something. Maybe if I could change Imei in 250V, it would works. push POWER ON key when phone cannot enter TAT searching on = #NANOBox RS232# detecting. . . found! phone mode : #TAT# model : E250 imei no. : 111100-00-001430-0020 fw version : E250JCFL1 # MP 1.705 patience, reading msl. . . MSL address : RV5P857066 patience, calculating MSL code[Method 1]. . . [!] NANO-DBG.Prot.Error* cannot calc.MSL code, give up ###### probably MSL16 repeat in BOOT mode(if available) ###### |
10-29-2010, 19:05 | #14 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | then u can't unlock this phone using nano for the moment until u fix phone imei (eeprom corrupted) br <= The_Gorr => |
