Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > MXKEY (by Alim Hape) > MXKEY Blackberry Flasher and Unlocker (by Alim Hape)
Old 12-03-2012, 18:52   #1 (permalink)
alfred_smd's Avatar
Member: 271133
Thanks Meter: 37
Help BB 9800 code error / code not accept
i tried unlocking a bb 9800 the code reads but
code not accept .
need ur solution. here is mx-key log below
IMEI: 35349004681xxxx
MEP: MEP-04598-005
Factory Lock State: CLOSED
MXKEY Serial: C086FE32
MEP2(Network,Active,6,10): 2463395740033777
MEP3(Network Subset): 1435689882305031
MEP4(Service Provider): 4264771909741929
MEP5(Corporate): 5603075057903398
Unlock instructions:
1. Insert SIM card
2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0)
3. Select "Advanced options" or "Advanced system settings" -> "SIM Card"
4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard
5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and "2"
NOTE: You will not see any text appear on the screen while typing on step 3 and 4.
6. You should be presented with a prompt "Enter Network MEP Code"
7. Enter the Unlock Code(2463395740033777) and press in the enter/track ball/track pad to confirm
8. Device is now unlocked.
NOTE: Make sure you follow these or the instructions correctly.
If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded.
Page generated in 0.10359 seconds with 8 queries
