Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > MXKEY (by Alim Hape) > MXKEY Blackberry Flasher and Unlocker (by Alim Hape)
Old 03-03-2012, 06:17   #1 (permalink)
mohit_kripalu01's Avatar
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
here is 2 USB 3 driver , install & report here new v3.5_rev1.8 problem solved or not
usb 3 driver
Also try update your motherboard Chipset driver
The Following 2 Users Say Thank You to mohit_kripalu01 For This Useful Post:
Old 03-03-2012, 10:58   #2 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
any member check it's working or not plz report here
Old 03-03-2012, 11:15   #3 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 831
bro we ahve now but sam problem
Connection status: UHCI:HUB:USB 2.00 Full-speed
WARNING: Device drivers might not work properly !
[err0] required OHCI(1.1)/EHCI(2.0)/xHCI(3.0) controller !
Interface: MXBOX/HTI (Powered by MXKEY)
OTP ID: 351B0E01680C5053820D414C070000F5
Boot ver: 00.07, Box SN: 00013C0C
FW version: 00.50
HTI Flasher Interface (WinUSB) ready.
Old 03-03-2012, 11:24   #4 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
FW version: 00.50
can you install usb 3 driver , also update new ver chipset driver ur motherboard
Old 03-03-2012, 11:44   #5 (permalink)
Member: 642467
Exclamation
[QUOTE=mohit_kripalu01;8200242]can you install usb 3 driver , also update new ver chipset driver ur motherboard[/QUOTE
after install usb 3 driver same problem devvice not detect:con fused:
Old 03-24-2012, 21:11   #6 (permalink)
loop2009's Avatar
Member: 957625
Thanks Meter: 30
if on usb2, loading usb drivers wont sort it, get a new motherboard with usb3 built on board then will be ok
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
Page generated in 0.14343 seconds with 9 queries
