Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
09-10-2016, 19:08 | #1 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2615803 Status: Offline Thanks Meter: 0 | Double sided tape or UV gel i see there is two solution avaible for changing front glass, first one is only using double sided adhesive tape and other one is using UV gel what is difference between these two operation i mean advantages and disadvantages.. |
09-11-2016, 08:32 | #2 (permalink) | |
Freak Poster Join Date: Sep 2014 Location: I . N . D . I . A Age: 45
Member: 2255989 Status: Offline Sonork: 1001675246 Thanks Meter: 47 | Quote:
Both are the best. Tape is good because its a tape not a liquid so you can use it easy but if you use tape for fixing touch pad its not for log time and not permanent And gel is also good . And fixing is permanent but its liquid so do its carefuly | |
The Following User Says Thank You to Hamid memon786 For This Useful Post: |
09-11-2016, 11:16 | #3 (permalink) | |
Member: 2615803 Status: Offline Thanks Meter: 0 | Quote:
Thank you, then we can say: double sided tape is easy to use but not permanent solution uv gel is hard to use but permanent solution | |
