Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
09-17-2023, 00:48 | #1 (permalink) |
Insane Poster Join Date: May 2008 Location: Nueva Ecija, Philippines
Member: 767256 Status: Offline Thanks Meter: 48 | MXQ Pro 4k 5G(fake) board ZQ01F-v2.1 Maskrom mode problem ps: I tried all those rockchip bootloader posted on github one by one. but only the following bootloader was accepted but after flashing it always appeared maskrom mode, not loader mode. rk312XMiniLoaderAll(L)_V2.17.bin rk312XMiniLoaderAll(L)_V2.19.bin rk3126MiniLoaderAll(L)_V2.19.bin RK3128MiniLoaderAll_V2.25.bin |
09-25-2023, 09:38 | #2 (permalink) |
Member: 767256 Status: Offline Thanks Meter: 48 | I have MXQ Pro 4k 5G fake. the original firmware is not rooted. But I backup the original firmware using rkdump. then for assurance I tried to install my original backup, the it was success on booting. after that I tried to install new firmware image format. then it wont boot anymore, and it is on maskrom mode. I tried to install my original firmware but test device failed. I tried to flash loader but the same, always in maskrom mode. my chipset is rockchip rk3128A. wifi chip ESP8285. board ZQ01F-V2.1 all bootloader posted here: https://forum.xda-developers.com/t/r...ction.3739510/ ps: I tried all those bootloader one by one. but only the following bootloader was accepted but after flashing it always appeared maskrom mode, not loader mode. rk312XMiniLoaderAll(L)_V2.17.bin rk312XMiniLoaderAll(L)_V2.19.bin rk3128MiniLoaderAll(L)_V2.20.bin RK3128MiniLoaderAll_V2.25.bin RK3128MiniLoaderAll(L)_V2.27.bin RK3128MiniLoaderAll_V2.31.bin RK3128MiniLoaderAll_V2.32.bin RK3128MiniLoaderAll_V2.40.bin RK3128MiniLoaderAll_V2.47.bin RK3128MiniLoaderAll_V2.52.bin I tried using UART serial console, but no info when I tried to turn on, except if I flash the bootloader, there some info during flashing, but I dont have an idea how to use those info printed on console. here is the info Code: DDR Version 2.06 20170316 In 1A1A292B 0 1A1A292A 3 LPDDR2 292A292A F Bus Width=32 Col=10 Bank=8 Row=14 CS=2 Die Bus-Width=32 Size=1024MB mach:14 OUT Boot1 Release Time: Nov 27 2017 10:55:24, version: 2.47 ...FlashInit enter... FtlMallocOffset = 8040 8000 FtlMallocOffset = 10040 8000 FtlMallocOffset = 11040 1000 FtlMallocOffset = 19040 8000 FtlMallocOffset = 1a040 1000 ...NandcInit enter... 0:1200 0 7f7f05 22 200 FtlMallocOffset = 23040 9000 gNandcVer = 6 56363232 mmc Ext_csd, ret=0 , Ext[226]=20, bootSize=2000, Ext[215]=0, Ext[214]=74, Ext[213]=80, Ext[212]=0,cap =748000 REL=1f SdmmcInit=2 0 BootCapSize=2000 UserCapSize=3728MB FwPartOffset=2000 , 2000 UsbHook 746161 powerOn 746200 [/QUOTE] |
10-30-2023, 11:30 | #3 (permalink) | |
Junior Member Join Date: Jan 2003 Age: 42
Member: 19953 Status: Offline Thanks Meter: 0 | Have you solved this? I have exaclty the same issue with the same board Quote:
12-01-2023, 05:53 | #4 (permalink) |
Member: 767256 Status: Offline Thanks Meter: 48 | finally almost 3 months looking for solution, I finally solved the maskrom mode problem. ZQ01F v2.1 2022.09.09 RK3128A maskrom problem, follow the video https://*********/Gf3WXTOYLnM |
12-01-2023, 09:28 | #5 (permalink) | |
Member: 767256 Status: Offline Thanks Meter: 48 | Quote:
join on telegram: https://t.me/+etNXrMZE2vliMDVl | |
12-02-2023, 20:59 | #6 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
I reposted here whole process w/ tools and download links. Code: - Download all needed tools and firmware - Extract Downloaded folder - Install Rockchip_DriverAssitant_v4.5 (uninstall all other versions before) - Connect your device with PC using USB-A-to-USB-A (male to male) cable - Make sure your device is in "MaskROM" mode * If your device was fully erased - run restore_idb.bat from RKDevTools folder , if not - skip this step - Start RKDevTool from RKDevTool_Release_v2.86 folder, click "Upgrade Firmware" tab, click "Firmware" button, select image file - Click "Upgrade" button and wait to finish Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
