[Guide] Android Phones: Hard Reset Android Phones - Hard Reset Please post here only Hard Reset of Android Phones No question or how to please. Help me to keep this thread clean A big thanks to www.hard-reset.eu for their resource "Performing a factory data reset deletes all data, including downloaded applications, and resets the device back to its initial state—the state before you turned on the device for the first time. Important Make sure to back up important data you have on the device before you perform a factory data reset." HTC Dream 1. Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit. 2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle. Now to wipe the device clean: 3. Press Alt+L. 4. Press Alt+W for a factory reset. 5. Press the Home and Back keys again for about 25 seconds. The device should then reset again and the hard reset is complete. ++++++++++++++++++++++++++++++++++++++++++++++++++ 1. With the phone turned off, press and hold the HOME and BACK 2. Briefly press the END CALL/POWER button while continuing to pressHOME and BACK buttons. 3. When you see the screen with the 3 Android images, release the HOME and BACK buttons, and then press the TRACKBALL. Tip : If your phone hangs or freezes, remove the battery then wait for a few seconds, and then re-install it. After re-installing the battery, turn on the phone. http://www.hardreset.eu/images/htc_m...soft_reset.jpg ++++++++++++++++++++++++++++++++++++++++++++++++++ HTC Hero 1. With the phone turned off, press and hold the HOME and BACKand then briefly press the END CALL/POWER button. The reset process will start after a few seconds. 2. Wait for the phone to finish the reset process and then press MENU. Tip : If your phone hangs or freezes, remove the battery then wait for a few seconds, and then re-install it. After re-installing the battery, turn on the phone. ++++++++++++++++++++++++++++++++++++++++++++++++++ HTC Tattoo 1. With the phone turned off, press and hold the HOME and BACKand then briefly press the END CALL/POWER button. 2. Press the ENTER button to begin the reset process. Tip If your phone hangs or freezes, remove the battery then wait for a few seconds, and then re-install it. After re-installing the battery, turn on the phone. ++++++++++++++++++++++++++++++++++++++++++++++++++ HTC Desire : reserved ++++++++++++++++++++++++++++++++++++++++++++++++++ HTC Whitestone : reserved ++++++++++++++++++++++++++++++++++++++++++++++++++ |
Motorola Droid To reset your phone to factory settings and erase all the data on your phone, Touch Menu > Settings > Privacy > Factory data reset > Reset phone. Warning: All data on your phone will be deleted. Motorola Droid Hard reset with keys Power off device. Press X key on hard keyboard + power button, then release both buttons. With D pad go to data / factory reset, then press CENTER D Pad, then choose Yes. ++++++++++++++++++++++++++++++++++++++++++++++++++ Motorola Dext : Reserved ++++++++++++++++++++++++++++++++++++++++++++++++++ |
;) you forgot the good one to add here Hard reset for Nexus One 1. With the phone off, hold the Volume Down button and press and release the Power button. 2. You'll boot into the menu you see above with the little skateboard guys. Select Clear Storage from the list by pressing the Volume Down button. 3. Press the Power button, and confirm by pressing Volume Up. 4. Sit back while your phone reboots in its virgin state. |
LG GW620 [Eve] Hard Reset LG GW620 [Eve] Hard Reset To do a hard reset or data reset in LG GW620 aka EVE Enter using Dial pad 3845#*620# From menu select factory reset or whatever you want. ++++++++++++++++++++++++++++++++++++++++++++++++++ |
good post, very usefull post hi subrata, if you also post soft reset that will more power in thread. like this, HTC Dream Soft reset A soft reset clears the device memory and closes running applications. Perform a soft reset when your device hangs or freezes, is running slower than normal, or an application is not performing properly. If a soft reset is performed when applications are running, unsaved information will be lost. To perform a soft reset 1. Remove the back cover. 2. Remove the battery for a few seconds. 3. Re-install the battery, replace the back cover, then turn on the device To remove the back cover 1. Make sure the device is turned off. 2. Hold the device sideways with the control buttons on the right. 3. Slide the screen panel up to reveal the keyboard and the back cover release tab. 4. Gently push down the release tab with your finger until the back cover disengages from the device. 5. Pull the back cover out then set it aside. thanks your great work |
Motorola Dext factory reset 1. Holding the Camera button while turning on your phone, 2. When prompted hit the Volume-Down rocker button to go into Recovery Mode. 3. After you get into Recovery Mode, 4. Press ALT+L to reset, then Menu+Back to reboot. Best Regards Delower |
HTC Droid Eris Hard Reset Perform a hard reset on your HTC Droid Eris. These steps will clear all data and settings off the device. 1. With the phone turned off, press and hold the Volume Down and Send buttons. 2. Press the Power button. 3. Follow the instructions to complete the hard reset. Best Regards Delower |
HARD RESET SAPP300 aka TMobile MYTouch My Touch Hi... These steps will help someone Wipe and Hard Reset the TMobile My Touch (no keyboard) 1) Press and hold the HOME button and the POWER button together. 2) Keep holding HOME and POWER together for at least 25 seconds, even if the "Startup" screen appears. 3) Release the keys when you see a black screen with a warning sign. 4) At the above warning sign screen, press the HOME and POWER buttons again simultaineously...(10 secs).. and then let them go. 5) Use the trackball to scroll to wipe data/factory reset. 6) Press the trackball in on wipe data/factory reset. 7) When the bottom of the screen displays [DATA WIPE COMPLETED].... roll the trackball to [REBOOT SYSTEM NOW]. Press the trackball in on [REBOOT SYSTEM NOW] Await for the reboot....Full factory reset completed. :smokin |
hard reste HTC desire nice collection I will add this for desire 1. press and hold back & home buttons 2. press for a second power button 3. now a white screen will appear and with 4 options very easy to follow them you would use volume buttons to make a choice then power button to confirm a choice have fun |
gw620 can´t do hard rest hi there i have gw620 always asking me to put gmail account and pass but always wrong , is blocked i tried this 3845#*620# but nothing happend please helpme i cant find the solution. regards |
how to make hard reset huawei u8100 adroid |
Motorola MB501 Quench How can I make a hard reset on this model? I have done the following: 1. Holding the Camera button while turning on your phone, 2. When prompted hit the Volume-Down rocker button to go into Recovery Mode. 3. After you get into Recovery Mode, But I cannot do the following, because this model does not have a keyboard. 4. Press ALT+L to reset, then Menu+Back to reboot. I need to hard reset this phone because it is not reading the sim card anymore. The client tried the wrong subsidy code many times. |
not work Quote:
android model ta1 master reset i cant use menu if anybody have a idea thanks |
Motorola CLIQ XT (MB501) Hard Reset: 1. Turn the power off. If your Motorola CLIQ XT is frozen, pull the battery out and reinsert it 2. Press and hold the Power and Camera buttons 3. Release the Camera button when prompted 4. Press and hold the Volume Down key 5. A yellow exclamation will appear on the display. Wait until a menu with options will appear. 6. Using the touch screen select Factory Reset and press OK. That's all. |
