Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets
Android based Phones / Tablets For all of your questions relating to the android mobile phones.
Old 04-15-2013, 12:06   #1 (permalink)
mobilehelper's Avatar
Member: 1696653
Sonork: 100.1638410
Thanks Meter: 809
Chinese Tablet Android Rom
A10
IRULU AL003
DOWNLOADS
http://image.pigpony.com/image/table...012-007-27.rar
http://image.pigpony.com/image/table..._t02a_0524.rar
http://image.pigpony.com/image/table...6_20120302.rar
(3 files are there: AL003 Flash sofeware2012-007-27.rar / IRULU_Reboot Software sun4i_crane_t02a_0524.rar / Reboot Tool TF card reboot tool PhoenixCardV306_20120302.rar)
Then you have (what I believe are) the instructions for these tools:
Old 04-15-2013, 12:26   #2 (permalink)
Member: 1696653
Sonork: 100.1638410
Thanks Meter: 809
next post other tool and firmware
Old 04-15-2013, 12:38   #3 (permalink)
Member: 1696653
Sonork: 100.1638410
Thanks Meter: 809
[ROM] JellyBean for Advent Vega / PoV Mobii Tegra and other P10AN01 clone
[INSTALLATION]
There are 2 methods of installation. There is a CWM recovery flashable ZIP and a NVFlash file.
I realy recommend flashing VegaBean the first time with the NVFlash version.
Before installing any version, you have to make sure that you have a SDCard that has the correct partition layout:
- First partition is a primary partition formatted as FAT32
- Second partition is a primary partition formatted as EXT4
EXT4 is a linux filesystem so you will need a program that can handle Linux filesystems when you are using Windows.
Before installing the ZIP file make sure that:
- You have the correct partition layout (if you have Vega***** installed, you have the correct layout, if not then use the NVFlash installer. This will repartition your internal memory))
- Copy the ZIP file to your SD-Card
- Boot into Recovery
- Do a FULL WIPE / FACTORY RESET
- Install the ZIP file from your SDCard
- After installing reboot the tablet.
[WORKING]
- WiFi
- Bluetooth (Tested with a A2DP headset)
- Camera
- HDMI including audio
- 3G (only fro the Huawei internal modem, usb modems may work)
- GPS not tested by me, but some say it kind of works.
[DOWNLOADS]
Please do *NOT* use Link2SD anymore. You do not need it. With the INT2EXT script, your apps will install on SDCard by default. Just make sure you have 2 primary partition. First partition *MUST* be a FAT32 partition. The second partition *SHOULD* be EXT4. When upgrading from a previous version, make sure your EXT partition is empty / reformatted. Also when using the NVflash version !!!
[RC2]
CWM-ZIP: VegaBean-RC2-Update.zip
[Beta 6]
CWM-version: VegaBean-Beta6-120dpi-Apex.zip
NVFlash-version: VegaBean-Beta6-NVFlash.exe
[Beta 5]
CWM-version: VegaBean-Beta5-120dpi-Apex.zip
NVFlash version: VegaBean-Beta5-NVFlash.exe
[Test Beta 3-1]
CWM-version:
Stripped version: VegaBean-Beta3-1-stripped.zip
NVFlash versions by legionnaire: *************** - upload your files to multiple file hosting sites!
[Beta 3]
CWM versions:
Full version : VegaBean-Beta3-120dpi-Apex.zip
Stripped version : VegaBean-Beta3-stripped.zip
[Beta 2.2]
CWM versions:
Full version : VegaBean-Beta2.2-120dpi-Apex.zip
Stripped version : VegaBean-Beta2.2-stripped.zip
NVFlash versions:
Full version: removed
Stripped version: removed
[Beta 2]
CWM zip file: VegaBean-Beta2-120dpi-Apex.zip
[Beta 1]
CWM zip file: VegaBean-Beta1-120dpi-Apex.zip
[Alpha 3]
CWM zip file : Link removed
Here is alpha 2: VegaBean-Alpha2-120dpi-Apex.zip
Old 04-15-2013, 12:42   #4 (permalink)
Member: 1696653
Sonork: 100.1638410
Thanks Meter: 809
Flexiview FV-1 Android 2.2 TV Box - Uberoid Alpha
Baserom: 154801_FW_U110781_1203161.zip
Download: Flexiview_FV-1_Uberoid_Alpha.7z 98MB
Specs:
- CORTEX A8 core, Samsung S5PV210, frequency up to 1GHz
- VI6131
- 512MB RAM
- Built-in 2G memory space
- Android2.2 operating system
- Built-in WiFi module, can be do a wireless network connection
- RJ45 interface for wired network connection
- Support 1080P video playback
- HDMI video output, connect to Hi-definition television through the interface, and to play high-definition video
- USBinterface for connecting high-capacity mobile hard disk
- USBinterface for connecting a mouse and keyboard to operate the box
- Support weather, calendar and desktop clock tool
- Support wireless Bluetooth keyboard
- Bluetooth File Transfer
- Support for 2.4G wireless remote control operation
- Support FLASH PLAYER 10.1, available online play video
- Support for music playback, photo browsing, and enjoy more family entertainment
- SD card expansion
Changelog:
- added Google Play Store 3.5.15 (formerly known as the Google Market)
- added su bin
- modified build.prop to spoof a Samsung Galaxy S II
- disabled auto updates
- changed boottext
- removed facebook
- removed google maps 5.5.0
- updated youtube to 2.3.4
- removed air control lite
- removed streetview for google maps
- removed quickoffice trail
HowTo flash:
- Extract the OSK from the 7z
- Copy it to a SD:\UpdateKit\ (so you will have SD:\UpdateKit\android.osk)
NOTE: UpdateKit has a capitol "U" and capitol "K"!
- On the FV-1 box, go to "Settings"
- Once in "Settings", go to "Update System"
- Confirm the next screen by pressing "Next"
- You are asked if you would like to perform a backup, if you would like to do so press "continue", else just "skip"
- Before starting the update, you are instructed not to disconnect the power supply or remove the memory card during the update. Press "Start" to begin the upgrade.
- At this stage the update (android.osk) will be processed, after a while, you are prompted to restart the box, confirm with "OK".
- The FV-1 will restart and the update will be installed, after a few minutes the green LED ready indicator flashes, the update is then complete!
- Disconnect the power supply and remove the SD.
- Connect the power supply, the first boot will take a few mins, then the upgrade is complete.
Old 05-06-2013, 13:56   #5 (permalink)
Member: 1919494
Sonork: baraka
boss baka may firmware tayo dyn n Pang A10 Pa share nmn boss,,,,,,,,
Old 05-07-2013, 09:19   #6 (permalink)
Member: 1919494
Sonork: baraka
thanks for sharing filse,,,,,,,,,,
Old 05-07-2013, 09:29   #7 (permalink)
Member: 1898520
Sonork: 100.1627833
Thanks Meter: 5
I Need Apply Copy Chaina Teblet I Pad4 Config...... 3G, 16 GB, Wcdma, 1 GB ram, Rom File Need Plz Help Me
Old 05-16-2013, 07:59   #8 (permalink)
Member: 1863459
Sonork: 6253
Thanks Meter: 10
I need hel.
Is the headphone input of the U30GT2 the TRRS kind, so that I can input a microphone?
What I want to know is can I also input an external microphone in the the
earphone socket?
In other words, is it the TRS type (headphone only) or the TRRS type
(headphone and microphone) type?
Thank you
Old 07-28-2013, 16:17   #9 (permalink)
Member: 1804907
deadlink please re up thanks and more power
Old 07-31-2015, 21:59   #10 (permalink)
Member: 1888608
Hi
Any body has anything for Digital2 Chinese tablet...
Page generated in 0.18672 seconds with 8 queries
