Joe Suarez | 02-28-2023 11:13 | FRP or Factory Reset Protection is a security feature on Android devices that requires you to enter the Google account username and password that was previously synced on the device to unlock it after a factory reset. If you have forgotten your Google account credentials or are unable to access your device after a factory reset due to FRP lock, there are a few steps you can try to remove FRP on Infocus VZH with Qualcomm MSM8917 chip:
Perform a soft reset: First, try performing a soft reset on your device by pressing and holding the power button for about 10 seconds until the device turns off and then turns back on. This may help in removing the FRP lock.
Use an FRP removal tool: There are several third-party FRP removal tools available online that can help you bypass the FRP lock on your Infocus VZH device. However, be cautious when downloading and using these tools as some of them may be unsafe and may damage your device.
Contact the manufacturer or a professional repair service: If the above steps do not work, you can contact the manufacturer or a professional repair service to help you remove the FRP lock on your Infocus VZH device. They may be able to provide you with additional steps or tools to remove the FRP lock on your device.
It is important to note that removing the FRP lock without proper authorization may be illegal and may void the warranty on your device. Therefore, it is recommended to contact the manufacturer or a professional repair service to ensure that the FRP lock is removed safely and legally. |
