Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets
Android based Phones / Tablets For all of your questions relating to the android mobile phones.
Old 05-24-2014, 07:33   #1 (permalink)
Member: 2079868
Invalid IMEI FIX solved %100 works ;) MTKxx
first format using SP flash tool then flash again after flash has done do not start the phone i repeat DO NOT TURN ON THE PHONE!!!!now unplug the usb cable then run any imei writer like IMEI&SN Writer V1.5.3 or maui meta then just write your imei that's it now boot the phone there you go and this will work %100 i'm sure if it doesn't work then it means you are doing something wrong also i have been trying to figure how to fix this imei invalid problem for 1 week but nothing worked i have tried the several tools and ways like IMEI&SN Writer V1.5.3, Maui meta, engineering mode and SN_Station nothing worked and then i tried this AND IT WORKED LIKE A CHARM
my device: Symphony W85 (MTK6572)
if it helped don't forget to hit the "thanks" button
Old 07-23-2014, 23:34   #2 (permalink)
Member: 2222943
Pls am i going to need any flash files or not if yes pls specify and the link
Old 07-24-2014, 05:30   #3 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,006
MTK IMEI Repair without cable !
If you have still working unit -> tablet or smartphone -> you do not need ANY flashing - just install via GooglePlay MobileUncle MTK Tools - and use nice explanation in this thread how to correct your problem.
WBR, DebeliaMark, BG
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.11059 seconds with 7 queries
