Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
10-24-2021, 13:49 | #1 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 455842 Status: Offline Thanks Meter: 97 | Most Advanced Frp Tool of the year SAMFIRM AIO V2 LATEST Version |Frp bypass no1 Tool https://www.youtube.com/watch?v=inSB4ui8jSA |
The Following User Says Thank You to shamasgsmm For This Useful Post: |
10-24-2021, 14:00 | #2 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | direct download link is here ****************************/file/d8041...aller.zip/file vivo 1901 Read Device info Code: SamFirm A.i.O (v2.0) By Mahmoud Salah Opreation : Read Device info Checking internet Connection : Connected Checking server authorization : Done Loading Data >> Done Waiting for PreLoader VCOM, please connect mobile Port Power off the phone before connecting. For brom mode, press and hold vol up, vol dwn, or all hw buttons and connect usb. Port Device detected :) CPU:MT6765(Helio P35/G35) HW version:0x0 WDT:0x10007000 Uart:0x11002000 Brom payload addr:0x100a00 DA payload addr:0x201000 CQ_DMA addr:0x10212000 Var1:0x25 Disabling Watchdog... HW code:0x766 Target config:0xe5 SBC enabled:True SLA enabled:False DAA enabled:True SWJTAG enabled:True EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT:False Root cert required:False Mem read auth:True Mem write auth:True Cmd 0xC8 blocked:True HW subcode:0x8a00 HW Ver:0xca00 SW Ver:0x0 ME_ID:9F11EBB3F1683D766C991DE3E5B77995 SOC_ID:1971411E42834A8DD6FBFEDF8419080A12DFFAC7CA1780AFF2DE889140B2253F Loading payload from \payloads\mt6765_payload.bin, 0x264 bytes / DA Run Trying kamakiri2.. Done sending payload... Successfully sent payload: \payloads\mt6765_payload.bin Port Device detected :) Device is protected. Device is in BROM mode. Trying to dump preloader. Uploading stage 1... Successfully uploaded stage 1, jumping .. Jumping to 0x200000 Jumping to 0x200000: ok. Successfully received DA sync DRAM config needed for : 90014a6843396150 Sending emi data ... Sending emi data succeeded. Uploading stage 2... Successfully uploaded stage 2 EMMC FWVer: 0x0 EMMC ID: hC9aP3 EMMC CID: 90014a68433961503301c345a912b61f EMMC Boot1 Size: 0x400000 EMMC Boot2 Size: 0x400000 EMMC GP1 Size: 0x0 EMMC GP2 Size: 0x0 EMMC GP3 Size: 0x0 EMMC GP4 Size: 0x0 EMMC RPMB Size: 0x1000000 EMMC USER Size: 0xe8f800000 DACODE : 0x666D0 DA Extensions successfully added Requesting available partitions .... Reading Device info : Done Firmware info :->> Manfuactor : vivo Brand : vivo Product : k62v1_64_bsp Name : 1901 Model : vivo 1901 k62v1_64_bsp Device : 1901 Android Os : Android (11) Build ID : RP1A.200720.012 Security Patch : 2020-03-05 Description : full_k62v1_64_bsp-user 11 RP1A.200720.012 eng.compil.20210828.215254 CPU : Mediatek( MTK ) MT6765 CPU API : arm64-v8a,armeabi-v7a,armeabi Operation Done. One Click Format + Reset FRP Code: Opreation : One Click Format + Reset FRP Checking internet Connection : Connected Checking server authorization : Done Loading Data >> Operation Done. Opreation : One Click Format + Reset FRP Checking internet Connection : Connected Checking server authorization : Done Loading Data >> Done Waiting for PreLoader VCOM, please connect mobile Port Power off the phone before connecting. For brom mode, press and hold vol up, vol dwn, or all hw buttons and connect usb. Port Device detected :) CPU:MT6765(Helio P35/G35) HW version:0x0 WDT:0x10007000 Uart:0x11002000 Brom payload addr:0x100a00 DA payload addr:0x201000 CQ_DMA addr:0x10212000 Var1:0x25 Disabling Watchdog... HW code:0x766 Target config:0xe5 SBC enabled:True SLA enabled:False DAA enabled:True SWJTAG enabled:True EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT:False Root cert required:False Mem read auth:True Mem write auth:True Cmd 0xC8 blocked:True HW subcode:0x8a00 HW Ver:0xca00 SW Ver:0x0 ME_ID:9F11EBB3F1683D766C991DE3E5B77995 SOC_ID:1971411E42834A8DD6FBFEDF8419080A12DFFAC7CA1780AFF2DE889140B2253F Loading payload from \payloads\mt6765_payload.bin, 0x264 bytes / DA Run Trying kamakiri2.. Done sending payload... Successfully sent payload: \payloads\mt6765_payload.bin Port Device detected :) Device is protected. Device is in BROM mode. Trying to dump preloader. Uploading stage 1... Successfully uploaded stage 1, jumping .. Jumping to 0x200000 Jumping to 0x200000: ok. Successfully received DA sync DRAM config needed for : 90014a6843396150 Sending emi data ... Sending emi data succeeded. Uploading stage 2... Successfully uploaded stage 2 EMMC FWVer: 0x0 EMMC ID: hC9aP3 EMMC CID: 90014a68433961503301c345a912b61f EMMC Boot1 Size: 0x400000 EMMC Boot2 Size: 0x400000 EMMC GP1 Size: 0x0 EMMC GP2 Size: 0x0 EMMC GP3 Size: 0x0 EMMC GP4 Size: 0x0 EMMC RPMB Size: 0x1000000 EMMC USER Size: 0xe8f800000 DACODE : 0x666D0 DA Extensions successfully added Formatting addr 0x5588000 with length 0x100000, please standby.... Successsfully formatted addr 0x5588000 with length 1048576. Formatted sector 175168 with sector count 2048. Formatting addr 0x17f800000 with length 0xd0c4fbe00, please standby.... Successsfully formatted addr 0x17f800000 with length 56041127424. Formatted sector 12566528 with sector count 109455327. Operation Done. Opreation : Reset FRP (MTK) Checking internet Connection : Connected Checking server authorization : Done Loading Data >> Done Waiting for PreLoader VCOM, please connect mobile Port Power off the phone before connecting. For brom mode, press and hold vol up, vol dwn, or all hw buttons and connect usb. Port Device detected :) CPU:MT6785(Helio G90) HW version:0x0 WDT:0x10007000 Uart:0x11002000 Brom payload addr:0x100a00 DA payload addr:0x201000 CQ_DMA addr:0x10212000 Var1:0xa Disabling Watchdog... HW code:0x813 Target config:0xe7 SBC enabled:True SLA enabled:True DAA enabled:True SWJTAG enabled:True EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT:False Root cert required:False Mem read auth:True Mem write auth:True Cmd 0xC8 blocked:True HW subcode:0x8a00 HW Ver:0xca00 SW Ver:0x0 ME_ID:90EFB20754766D0167A177E5492D3210 SOC_ID:48BC2FE06190301FD56D53FC56238298E26D5746F0FA0C9D2AA5AADFEBEF1E87 Loading payload from \payloads\mt6785_payload.bin, 0x264 bytes / DA Run Trying kamakiri2.. Done sending payload... Successfully sent payload: \payloads\mt6785_payload.bin Port Device detected :) Device is protected. Device is in BROM mode. Trying to dump preloader. Successfully extracted preloader for this device to: \Loader\\preloader_k85v1_64.bin Uploading stage 1... Successfully uploaded stage 1, jumping .. Jumping to 0x200000 Jumping to 0x200000: ok. Successfully received DA sync UFS FWVer: 0x0 UFS Blocksize:0x1000 UFS ID: H9HQ15AECMBDAR UFS CID: ad014839485131354145434d42444152 UFS LU0 Size: 0x1dcac00000 UFS LU1 Size: 0x400000 UFS LU2 Size: 0x400000 DRAM config needed for : ad014839485131354145434d42444152 Sending emi data ... Sending emi data succeeded. Uploading stage 2... Successfully uploaded stage 2 UFS FWVer: 0x0 UFS Blocksize:0x1000 UFS ID: H9HQ15AECMBDAR UFS CID: ad014839485131354145434d42444152 UFS LU0 Size: 0x1dcac00000 UFS LU1 Size: 0x400000 UFS LU2 Size: 0x400000 DACODE : 0x131B0 DA Extensions successfully added Formatting addr 0x4b708000 with length 0x100000, please standby.... Successsfully formatted addr 0x4b708000 with length 1048576. Formatted sector 309000 with sector count 256. Operation Done. Last edited by malka4u; 10-24-2021 at 14:07. |
10-25-2021, 10:32 | #3 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Bucharest-Romania Age: 51
Member: 14200 Status: Offline Sonork: Sonork id Thanks Meter: 117 | For me not work SamFirm A.i.O (v2.0) By Mahmoud Salah Opreation : Reset FRP Checking internet Connection : Connected Checking server authorization : Fail PC is not Activate Operation Done. What is this? its a pay tool? |
