GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Android based Phones / Tablets (https://forum.gsmhosting.com/vbb/f606/)
-   -   [MT6575/6577/MT6572/MT6582/6589]MTK Android Based Phone IMEI Write Tool (https://forum.gsmhosting.com/vbb/f606/mt6575-6577-mt6572-mt6582-6589-mtk-android-based-phone-imei-write-tool-1708731/)
..::Nokian CareŽ::.. 09-02-2013 15:20
IMEI&SN Writer
100000% Working & Tested With MT6572 & MT6582
http://img189.imageshack.us/img189/3584/9puv.png
Download DB File for MT6572, MT6575, MT657 & MT6589
Download from here 4shared folder - DB file
MT6582 DB File Is Here
Warning
Only For Repair Original IMEI
Br,
azam
akhil_bbsr 09-02-2013 16:12
where is db file can share that also
ASSANDHCDMA 09-16-2013 16:08
bro select db from set is og flash file.......
Umesh_Arora 09-23-2013 13:24
scr file not work in this tool
this solution not work in mt 6572
..::Nokian CareŽ::.. 09-23-2013 13:30
i have 6572 100% solution
10000% tested over 100pcs,
If any one face any problem post here with screenshot.
Br,
azam
oum2 09-23-2013 13:48
sir i need hlp for micromax a67 pattern lock problem!
pls hlp me sir thanks in advance!
sunil1670 09-23-2013 14:00
Steps:
1,Please power off the phone
2,Then plug in the USB cable
USB Bootup
Meta_DB Init Start:
Meta_DB Init PASS
Enter to ModemMeta Start:
Enter to ModemMeta PASS
Start Write IMEI:
WriteIMEI_1: 911202151313301
WriteIMEI is OK !!!
From ModemMeta to APMeta Start:
From APMeta to ModemMeta PASS
It is over !!
sir after write ok , phone restart again and imei goes same as old one ,mt6572
sunil1670 09-23-2013 15:09
nokia care plzz help up the thread
Br,
azam
messiaah 09-25-2013 17:30
works for mt 6572 100 %
sonualok 09-26-2013 10:41
Post your screenshot....help others
guide other also
mahesh712 09-26-2013 14:47
Steps:
USB Bootup
Meta_DB Init Start:
Meta_DB Init PASS
Enter to ModemMeta Fail:
It is over !!
MT 6589 imei write failed
lamloanmobile 09-28-2013 06:05
Br,
azam
I9500 MT6572 wirte ok but imei no chage
ivanrommel 09-28-2013 11:30
works perfect for mtk 6577 model: skk a5
Steps:
USB Bootup
Meta_DB Init Start:
Meta_DB Init PASS
Start Write IMEI:
WriteIMEI_1: 359310045241189
WriteIMEI_2: 359310045241197
WriteIMEI is OK !!!
It is over !!
thanks man!!!.....
unlocker_786 09-29-2013 10:37
hi
thanx for reply all of u guys my s4 i9500 mt6572 problem is solved and my imei is repaired by dis tool and thanx to dat who give me solution this not possible yet on volcano but dis tool make my problem solve so i give dat linkhttp://forum.gsmhosting.com/vbb/f606/mt6572-6575-6577-6589-mtk-android-based-phone-imei-write-tool-1708731/#thisthis tool repaired imei successfully as u see in below pic even serial no an etc
i thanks to nokian care
http://img89.imageshack.us/img89/6910/zed1.jpg
http://img820.imageshack.us/img820/2941/tvs6.jpg
ashakaass 09-30-2013 11:46
1 Attachment(s)
mito tab t520 mtk 6577
http://forum.gsmhosting.com/vbb/atta...1&d=1380538289
Steps:
USB Bootup
Meta_DB Init Start:
Meta_DB Init PASS
Start Read SN:
ReadSN: MT012345678901234567
Read SN is OK !!!
Start Write IMEI:
WriteIMEI_1: 111111111111111
WriteIMEI_2: 222222222222222
WriteIMEI is OK !!!
Start Read IMEI:
ReadIMEI_1: 111111111111111
ReadIMEI_2: 222222222222222
ReadIMEI is OK !!!
Read BT Address Start:
ReadBT: de1246662867
Read BT is OK !!!
Read WIFI Address Start:
ReadWIFIAddr: 000000000000
Read WIFI Address is OK !!!
Read SW Version Start:
GetSWVer: ALPS.JB.MP.V1.22
Read SW Version is OK !!!
Read Internal SW Version Start:
GetSWVer_Internal: GM1503_M10_V1.1
Read Internal SW Version is OK !!!
It is over !!
Page generated in 0.15114 seconds with 6 queries
