Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
10-01-2020, 17:33 | #1 (permalink) |
Junior Member Join Date: Oct 2017 Location: ::_::Earth::_::
Member: 2767059 Status: Offline Thanks Meter: 1 | Software for recovery data from broken device Greetings to all the professional software and hardware engineers in here, thanks for all your help and support. Please am requesting for a computer software that can copy or backup complete data from a broken device or device which is stucked at bootloop due to user modifications of system files or some software problems. Thanks in anticipation... |
10-12-2020, 06:33 | #2 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2783028 Status: Offline Thanks Meter: 6 | As I know, coolmuster broken android data extraction can help us extract data from broken Android devices. But not all data are supported. About the details, you can check online. Good luck to you. |
The Following User Says Thank You to Imradeser For This Useful Post: |
10-12-2020, 17:38 | #3 (permalink) | |
No Life Poster Join Date: Apr 2012 Location: bahrain.
Member: 1742913 Status: Offline Sonork: 100.1604070 Thanks Meter: 328 | Quote:
The Following User Says Thank You to android unbrik For This Useful Post: |
10-26-2020, 18:53 | #4 (permalink) |
Junior Member Join Date: Apr 2018
Member: 2832748 Status: Offline Thanks Meter: 6 | jtaging and chipoffing can help only on devices that did not update to android 7 nougat and higer. For nowday devices, I think there's no easy and cheap solution and software because of encrypting data partition. Every cypher is unique for the device, and so the partition. If you would like to recover any data, you need to contact some special forensic service that is usually very expensive. in most cases they physicaly need the phone by them and it takes some weeks. The second method is putting the CPU and internal memory from one board to the other, so its only for advanced hardware technicians. what is the phone model that you want to recover? maybe you can flash only firmware with system on the same security patch. Last edited by Evilhate; 10-26-2020 at 19:00. |
The Following User Says Thank You to Evilhate For This Useful Post: |
11-10-2020, 15:14 | #5 (permalink) |
Member: 2767059 Status: Offline Thanks Meter: 1 | Thanks for all your help, I successfully recovered the data by Updating the stock firmware in the " android recovery mode". then i use 'ADB COMMANDS' to check for disabled apps, and then enabled them back. After that the phone boots successfully. |
