Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
05-03-2013, 18:16 | #1 (permalink) |
Junior Member Join Date: Jul 2007 Location: West Africa
Member: 538192 Status: Offline Thanks Meter: 0 | Tecno n3 custom rom: Gingerbean regardless....the pros(successes) are better than the cons (risks)...soooo...lets get modding Nowwww, with that being said, you must follow these steps one by one Guide to installation of Ginger-bean: Prelude: STOP! ANSWER YES TO ALL THESE QUESTIONS B4 YOU PROCEED FUTHER!!!!!! ask yourself the following: a. Have you backed up all your data to your SD or PC? if not, you must do so immediately especially your contacts (goto contacts menu, import/export, backup to SD) b. Have you done a nandroid backup of your present rom? easiest way out of a Brick? if not, you must go to google play and download "online nandroid backup". when youve done so, run online nandroid backup, you will need an internet connection to update the nandroid scripts. select CWRM mode, then click "start backup" (note : have atlest 512MB on your SD card). the backup should take about 20 mins c. do you have ADB driver for N3 installed? if no go here to find out how to do so:Solution To Your Boot Loop, Bricked TECHNO Android Phones - Phones - Nairaland d. seriously know what your doing ???? d. Are you human yet are utterly into living on the edge 8)? step 1-download the modded boot image (get here https://www.dropbox.com/s/k52ryk51nn...ot.img?v=0mcng) step 2-download tools needed (get here https://www.dropbox.com/s/g1nkd5bthu...ed.zip?v=0mcng) step 3-download N3 system img, its uploaded in split file (10 in all), here are the links: 1. https://www.dropbox.com/s/dlru2mnwc8...7z.001?v=0mcng 2.https://www.dropbox.com/s/egk8d0dv7t...7z.002?v=0mcng 3. https://www.dropbox.com/s/ca3nu4z5hh...7z.003?v=0mcng 4. https://www.dropbox.com/s/9ip531uhq7...7z.004?v=0mcng 5. https://www.dropbox.com/s/58lofogl9f...7z.005?v=0mcng 6. https://www.dropbox.com/s/58lofogl9f...7z.005?v=0mcng 7. https://www.dropbox.com/s/74djkpzpue...7z.007?v=0mcng 8. https://www.dropbox.com/s/ssnwsjer87...7z.008?v=0mcng 9. https://www.dropbox.com/s/4z5fbj0dti...7z.009?v=0mcng and 10.https://www.dropbox.com/s/n95nk52fx6...7z.010?v=0mcng step 4- extract contents of tools_needed folder and install 7zip step 5- use 7zip to extract the 10 split sys.yaffs2.img file (this can be done by copying them to the same folder the right clicking and selecting 7zip, extract archive) step 6- boot your N3 into fast boot mode (this is done easily by removing the battery, and while holding volume-down button on plug in your usb cable, then wait till you see the TECNO logo displayed on the screen, wait for 5 second then release the volume-down button) step 7 FLASHING THE TECNO: At juncture you need to stop every other thing youve been doing while you wer doing this and concerntrate!!! (Girl, allow that boy not to brick his phone o! and O boy, stop that Pinging O. Anyway, we have already said we'er not responsible for casualties) were ready to flash... At this point i'm right to guess we've all installed our ADB drivers using the Android universal ADB installer. if not go here to find out how to do so Solution To Your Boot Loop, Bricked TECHNO Android Phones - Phones - Nairaland now, run Android AIO flasher.exe (found in tools needed folder) next, in the AIO flasher window, the very first menu is what concerns us i.e. where its written fastboot flasher (Nandroid Restorer)(the others we shall explain in later tutorials) click boot click Select file(browse to where you saved the boot.img you downloaded above) click erase click flash YOU MUST wait for the black window below to show "writing boot...OK" before you know its done Congratulations your almost done!! Simply repeat the same process for the sys.yaffs2.img file, only this time, we go: click System click Select file(browse to where you saved the sys.yaffs2.img you downloaded above) click erase click flash once again YOU MUST wait for the black window below to show "writing sys.yaffs2.img OK" before you know its done. it should take about 50 seconds, depending on your system specs. Lastly, unplug the usb cable, now, while holding "volume-up" plug it back keep holding volume up till you enter the Android 3e stock recovery menu. using volume up and down to move select "wipe cache", PRESS power button to select when this is finished select "wipe data/factory reset" when this is done restart your phone these last two steps are important..else you may have boot-loop well..guess thats pretty much it. regarding the memory boost..i will post that momentarily. feel free to post feedback here courtesy..lexsolutionz |
05-04-2013, 00:13 | #2 (permalink) |
Member: 538192 Status: Offline Thanks Meter: 0 | there an error with link number 6 of the split img file: heres the correct link: https://www.dropbox.com/s/3qxcx3wxlr...7z.006?v=0mcng |
05-21-2013, 02:01 | #3 (permalink) |
Junior Member Join Date: May 2007 Location: Ghana
Member: 504712 Status: Offline Thanks Meter: 2 | TECNO P3 flash with TECNO N3 files I was experimenting and flash the tecno n3 file on tecno p3 and my torch light is on when screen light is also on, cannot change to turn usb on when connected to pc, phone model number shows tecno n3 ... any advice |
01-18-2014, 00:58 | #7 (permalink) |
Freak Poster Join Date: Jul 2004 Location: nigeria Age: 41
Member: 73254 Status: Offline Sonork: 100.1583566 Thanks Meter: 13 | OKAY [ 0.047s] C:\Users\GARU\Documents\p3\tools\Android_AIO_Flash er\tools> finished. total time: 0.047s C:\Users\GARU\Documents\p3\tools\Android_AIO_Flash er\tools>fastboot flash boot "C:\Users\GARU\Documents\p3\New folder\sys.yaffs2.img" sending 'boot' (177311 KB)... OKAY [ 44.334s] writing 'boot'... FAILED (remote: image is not a boot image) finished. total time: 44.336s pls help me with solution, i am stuck on tecno logo |
