Android based Phones / Tablets For all of your questions relating to the android mobile phones. |
09-29-2019, 08:29 | #2 (permalink) |
Freak Poster Join Date: Mar 2015 Location: New Delhi Age: 28
Member: 2355125 Status: Offline Thanks Meter: 52 | You can Use Frp Reset option from Mediatek Tab with any box/Tool. Or you can try this manual method TECNO SPARK Go ( TECNO KC1h ) FRP BYPASS GOOGLE Post results Best Regards Sagar Jaiswal Press Thanks if Helped |
The Following 3 Users Say Thank You to sagarjais For This Useful Post: |
11-13-2019, 19:17 | #3 (permalink) |
Banned Join Date: Jun 2017 Location: India
Member: 2732044 Status: Offline Thanks Meter: 216 | Check here you will get two methods to FRP to unlock from your device. You can bypass frp lock using PC and also Without Using the PC method. just check once. Tecno Spark Go KC1 FRP https://www.bypassfrpfiles.com/2019/...nlock-spark-4/ |
12-09-2019, 15:12 | #5 (permalink) |
Freak Poster Join Date: Nov 2009 Location: okara pakistan
Member: 1158049 Status: Offline Sonork: i have no sonork id Thanks Meter: 22 | working 1000% https://www.youtube.com/watch?v=kwrg5AkIFM4 |
03-14-2020, 06:35 | #7 (permalink) |
Major Poster Join Date: Jul 2012
Member: 1781510 Status: Offline Sonork: [email protected] Thanks Meter: 8 | Miracal box 1-mtk;Custom Setting--Tecno-kc1 2-Format [ok] |
09-25-2020, 14:37 | #8 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Peshawar
Member: 742615 Status: Offline Thanks Meter: 58 | use EFT PRO select spark 3 AND DONE Setting up.....OK Loading files.....OK Waiting for MTK port.....Detected {COM433} Connecting to Brom.....OK Sending DA.....OK Reading partitions.....OK Chip name: MT6761 Reading prop info.....OK Device Firmware: KC1-H6114AL-P-200827V438 Device SDK: 28 Android version: 9 Device Model: TECNO KC1 Device Factory: TECNO Device CPU: armeabi-v7a Device Factory: TECNO MOBILE LIMITED Device Factory: TECNO MOBILE LIMITED Resetting frp.....OK Operation {Reset FRP} ID: 3006F0F66EDA4FDF Elapsed time 00:22 -- Version 3.4.5 |
The Following User Says Thank You to tayyabshah For This Useful Post: |
