Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets
Android based Phones / Tablets For all of your questions relating to the android mobile phones.
Old 11-11-2013, 22:03   #1 (permalink)
akh84's Avatar
Member: 1733938
Sonork: 100.1617311
Thanks Meter: 34
Wiko repair IMEI null {Guide}
First I want to clarify that it is forbidden to use this method on a phone " blacklisted " by the operators, then note the IMEI numbers that are on the label under the battery or on the packaging box your phone .
Here's how to repair IMEI on your Android phone.
This method was used to redefine the IMEI on a phone WIKO Dual Sim .
Indeed, after an update " lousy " the phone had no more IMEI .
STEP 1
We will switch the phone to " engineer mode " phone so on, call the following number:
* # * # 3646633 # * # *
STEP 2
Your telephone engineer mode, go to "CDS Information" and in " Information Radio "
STEP 3
Now you see is the "Phone 1" and " Phone 2 " screen, press " Phone 1 " to edit the IMEI 1
STEP 4
Click the field that is already registered "AT + " and enter instead :
AT + EGMR = 1.7 , " "
STEP 5
Then between the quotes " " enter your IMEI number
EGMR AT + = 1.7 , " XXXXXXXXXXXXXXX "
STEP 6
Check the number and press SEND AT COMMAND
This is the IMEI number for your first SIM slot is changed, repeat for the second slot (" Phone 2") and restart the phone for the changes to take effect.
I hope this tutorial has been helpful and that you can now enjoy your WIKO
work with many other Android phones
Last edited by ...:::SHAMIM:::...; 08-22-2018 at 20:20. Reason: Removed None English Language Text!
Old 02-03-2018, 11:18   #2 (permalink)
Member: 2807158
not work on wiko harry, please help alternative solution
Old 11-24-2022, 09:31   #3 (permalink)
Member: 2229851
Thanks Meter: 54
Wiko View2 not working
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.10932 seconds with 7 queries
