J.A.U - Box (c) Just Another Unlocker by Harald Kubovy 2010 |
03-28-2010, 05:12 | #1 (permalink) |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | How to know if JAF box is DEMAGED or NOT! this is the way how you 100% know if your box is affected from stucking firmware. try to down or upgrade your box firmware with JAU JAF FIRMWARE UPDATER. if firmware is not changed to the selected version, your box is demaged. Last edited by oOXTCOo; 04-08-2010 at 02:53. |
The Following 49 Users Say Thank You to oOXTCOo For This Useful Post: |
03-28-2010, 05:49 | #3 (permalink) |
Product Manager Join Date: Jan 2009 Location: Philippines Pure Pinoy Age: 37
Member: 943187 Status: Offline Thanks Meter: 584 | aftr updATE my jaf box in potato i cantunlock 5000 using mxkey and as interface? do u think what is the problem sir? |
The Following 2 Users Say Thank You to dArk_shAdE For This Useful Post: |
03-28-2010, 06:09 | #4 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
is there way to repair eeprom of Atmega128L ...........? | |
The Following 2 Users Say Thank You to cel_phon For This Useful Post: |
03-28-2010, 07:10 | #5 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Taguig CT Age: 42
Member: 488875 Status: Offline Sonork: 100.1626294 Thanks Meter: 1,129 | hope some team can make jafbox reader/flasher sw.................soon.,................ |
The Following User Says Thank You to bronce For This Useful Post: |
03-28-2010, 07:32 | #6 (permalink) | |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
oOXTCOo my jaf box ok like this condtion ODJAF000 but when i m trying to dpwngrade or upgrade box still same version not update and not downgrade y? | |
The Following 5 Users Say Thank You to ..::Rizwan::.. For This Useful Post: |
03-28-2010, 08:00 | #7 (permalink) | |
Junior Member Join Date: Mar 2010
Member: 1271972 Status: Offline Thanks Meter: 292 | Quote:
My Serial is : ODJAF000 so how to upgraded ? and where download tool to upgraded my box ? please help me | |
The Following User Says Thank You to myohmymusic For This Useful Post: |
03-28-2010, 08:05 | #8 (permalink) |
Freak Poster Join Date: Nov 2005 Location: BY
Member: 201432 Status: Offline Thanks Meter: 38 | why box update don't work - always 1.b4 - flash 1.b0 - the same, check 1.b4??? ps fake update 1.7 destroy box? |
The Following User Says Thank You to dikey For This Useful Post: |
03-28-2010, 08:16 | #9 (permalink) | |
No Life Poster Join Date: May 2006 Location: Gojra
Member: 279362 Status: Offline Sonork: 100.1594141 Thanks Meter: 500 | Quote:
The Following User Says Thank You to meeza_84 For This Useful Post: |
03-28-2010, 10:08 | #11 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Stavropol Rus www.lasdorf.info Age: 48
Member: 234549 Status: Offline Sonork: 100.107451 Thanks Meter: 413 | DONLOAD j.a.f_box_firmware_updater_v1.1 http://www.jau.gsm26.ru/downloads/ja...dater_v1.1.rar http://www.entsperren.net/JAFUpd.zip |
The Following 8 Users Say Thank You to LASDORF For This Useful Post: |
03-28-2010, 10:36 | #12 (permalink) |
Member: 234549 Status: Offline Sonork: 100.107451 Thanks Meter: 413 | Solution for working J.A.F Box Firmware Updater_v1.1 Solution for working J.A.F Box Firmware Updater_v1.1 So, we begin that is disconnected all boxes from a computer, including JAF. Further we attach box JAF a cable to USB-port your PC and we start the program J.A.F Box Firmware Updater_v1.1. See the prevention in a dialogue window of the program: Code: IMPORTENT: BEFORE START FIRMWARE DOWN - / UPGRADE RECONNECT YOUR BOX FROM USB PORT, TO MAKE SHURE NO TRASH IS IN THE ATMEGA128L SRAM! If You not disconnect and reconnect, possible that your Box get demaged! Press the button "Do Job", preliminary having noted an option "Check JAF Firmware Version". See the log: Code: Search for J.A.F Box. Trying To Connect Default Device Serial: ODP ***** Opening Connection... Connect Ok! Initializing Connection... Initalizing Success! Reading. Setting Bus. Box firmware version: 01 B1 Expose a necessary option. I chose "Upgrade/Downgrade to Firmware 01.B4". Press the button "Do Job". I result the received log: Code: Search for J.A.F Box. Trying To Connect Default Device Serial: ODP ***** Opening Connection... Connect Ok! Initializing Connection... Initalizing Success! Update Box Firmware. Setting Bus. Flashing Firmware v01.B4 to J.A.F Box. Reading. Box firmware version: 9C 00 Done! Check, using an option "Check JAF Firmware Version" and having pressed the button "Do Job". A log received after an insertion and check: Code: Search for J.A.F Box. Trying To Connect Default Device Serial: ODP ***** Opening Connection... Connect Ok! Initializing Connection... Initalizing Success! Reading. Setting Bus. Box firmware version: 01 B4 The main thing, do not forget about that before each operation, it is necessary to disconnect boxing from the personal computer for some seconds and to attach again. Direct link for download: Download from official Website >>> Download from official Russian-language Website J.A.U >>> |
The Following 13 Users Say Thank You to LASDORF For This Useful Post: |
03-28-2010, 10:41 | #13 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Skype , Sonork
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Quote:
03-28-2010, 10:49 | #15 (permalink) |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Search for J.A.F Box.. Trying To Connect Default Device Serial : ODJAF000 Opening Connection... Connect Ok! Initializing Connection... Initalizing Success! Reading.. Setting Bus.. Box firmware version: 01 B2 mean Trying To Connect Default Device Serial : ODJAF000 my box ok but my box is lock 01 B2 so mebay not support with this soft and however i can say thank to all jau team that look for program to help jafbox user |
How to know if my box is a clone | 45PR1 | UFS2 + UFS3-Tornadoflasher | 2 | 10-31-2010 20:45 |
How to know if my Smartclip is Original or Clone ??? | makroud | Smart-Clip | 1 | 04-02-2007 23:17 |
How to know if Nokia 6100 is locked or needs Security Code? | o00ze | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 04-26-2006 14:02 |
How to know if Smart clip is Clonet or Original | Nizamo | Smart-Clip | 4 | 06-24-2004 21:32 |
How to know if the card is V1 or V2? | dito | Sim Cloning and Scaning | 1 | 12-18-2002 09:48 |
