07-17-2012, 14:21 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Kumasi-Ghana
Member: 390204 Status: Offline Sonork: 100.1592805 Thanks Meter: 138 | E63 Simlock Unable to repair AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0BC00019 ID DWORD 1 : 6FB30052 ID DWORD 2 : 9E0315F9 ID DWORD 3 : 733A1DF3 ID DWORD 4 : C804DA91 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : C7 0C B0 73 24 05 6B C6 6A 82 43 47 F4 0D B2 D5 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum 4E SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg Boot File - Version 012.08.00 Boot File - Revision 0x0002 (2) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 Checksum : 55 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031 Flash Descriptor Manufacturer Code : 0020 Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g Algorithm File - Version 012.08.00 Algorithm File - Revision 0x0002 (2) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Now Writing : CMT NPC Certificate 0x0200 Bytes NPC Write Successful... StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Now Writing : CMT CCC Certificate 0x0200 Bytes CCC Write Successful... StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Now Writing : CMT HWC Certificate 0x0200 Bytes HWC Write Successful... StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Now Writing : CMT R&D Certificate 0x0200 Bytes R&D Write Successful... Write Certificates OK! RPL Upload Finished!!! ================================================ Basic Phone Information ================================================ MCU Version: V ICPR71_09w22.9 16-10-09 RM-437 (c) Nokia IMEI Plain : 357397043619120 IMEI Spare : A357397043619120 IMEI SV : 33573970436191207F Phone Model: Nokia E63 Category : Smartphone Phone Type : RM-437 ================================================ Extended Phone Information ================================================ Product Serial Number: 0 Long Production SN : 0 MCU SW Version : V ICPR71_09w22.9 16-10-09 RM-437 (c) Nokia RFIC Version : 17141716 DSP Version : ICPR71_09w36 Content : )400.21.013 22-10-2009 RM-437 (c)Nokia AHNE Version : 11 APE SW Core Version : 400.21.013 Variant Version : 400.21.013400.21.013_v231.03 APE Test Version : RM437ENO874571920.a01 RETU Version : 16 TAHVO Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : 10:F9:EE:5B:E3:E0 Bluetooth ID : 10:F9:EE:5B4:40 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII ================================================ Simlock Information ================================================ Unable to read SP Data.. ================================================ Basic Phone Information ================================================ MCU Version: V ICPR71_09w22.9 16-10-09 RM-437 (c) Nokia IMEI Plain : 357397043619120 IMEI Spare : A357397043619120 IMEI SV : 33573970436191207F Phone Model: Nokia E63 Category : Smartphone Phone Type : RM-437 ================================================ Extended Phone Information ================================================ Product Serial Number: 0 Long Production SN : 0 MCU SW Version : V ICPR71_09w22.9 16-10-09 RM-437 (c) Nokia RFIC Version : 17141716 DSP Version : ICPR71_09w36 Content : )400.21.013 22-10-2009 RM-437 (c)Nokia AHNE Version : 11 APE SW Core Version : 400.21.013 Variant Version : 400.21.013400.21.013_v231.03 APE Test Version : RM437ENO874571920.a01 RETU Version : 16 TAHVO Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : 10:F9:EE:5B:E3:E0 Bluetooth ID : 10:F9:EE:5B4:40 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII ================================================ Simlock Information ================================================ Unable to read SP Data.. SECURITY_TEST : PASSED PHONE_MODE : TEST DCC ID : NOT USED ================================================== ==== Selected VPL File: RM437_0568936_510.21.010_001.vpl ================================================== ==== Variant Details : RM-437 CTR APAC-R Ultramarine Software Version : 510.21.010 Product Type : RM-437 Product Code : 0568936 Variant Version : 001 Help me after writing RPL Simlock unable to repair |
07-17-2012, 14:48 | #3 (permalink) | |
Member: 390204 Status: Offline Sonork: 100.1592805 Thanks Meter: 138 | Quote:
Superdongle and pm write logs...........13:52:47 : ================================================ 13:52:47 : Basic Phone Information 13:52:47 : ================================================ 13:52:47 : MCU Version: V ICPR71_09w22.9 16-10-09 RM-437 (c) Nokia 13:52:47 : IMEI Plain : 357397043619120 13:52:47 : IMEI Spare : A357397043619120 13:52:47 : IMEI SV : 33573970436191207F 13:52:47 : Phone Model: Nokia E63 13:52:47 : Category : Smartphone 13:52:47 : Phone Type : RM-437 13:52:47 : 13:52:48 : 13:52:48 : 13:52:48 : ================================================ 13:52:48 : Super Dongle RPL Stand Alone Edition 13:52:48 : ================================================ 13:52:48 : Generating Super Dongle RPL... 13:52:48 : Sending Superdongle RPL... 13:52:48 : OK: Super Dongle RPL Accepted 13:52:50 : 13:52:50 : 13:52:50 : Successfully done. 13:53:11 : 13:53:11 : ================================================ 13:53:11 : Basic Phone Information 13:53:11 : ================================================ 13:53:11 : MCU Version: V ICPR71_09w22.9 16-10-09 RM-437 (c) Nokia 13:53:11 : IMEI Plain : 357397043619120 13:53:11 : IMEI Spare : A357397043619120 13:53:11 : IMEI SV : 33573970436191207F 13:53:11 : Phone Model: Nokia E63 13:53:11 : Category : Smartphone 13:53:11 : Phone Type : RM-437 13:53:11 : 13:53:11 : 13:53:11 : 13:53:11 : ================================================ 13:53:11 : SX4 Custom Keys Stand Alone Edition 13:53:11 : ================================================ 13:53:11 : 13:53:11 : >>> : SX4 Auth Successfull 13:53:11 : Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-437.PM 13:53:11 : Start Uploading PM... 13:53:12 : Field : 1 Sub : 0 Byte(s): 114 - Ok 13:53:12 : Field : 1 Sub : 2 Byte(s): 98 - Ok 13:53:12 : Field : 1 Sub : 4 Byte(s): 110 - Ok 13:53:12 : Field : 1 Sub : 6 Byte(s): 98 - Ok 13:53:12 : Field : 1 Sub : 8 Byte(s): 110 - Ok 13:53:12 : Field : 1 Sub : 13 Byte(s): 98 - Ok 13:53:12 : Field : 1 Sub : 16 Byte(s): 98 - Ok 13:53:12 : Field : 1 Sub : 18 Byte(s): 98 - Ok 13:53:12 : Field : 1 Sub : 20 Byte(s): 98 - Ok 13:53:12 : Field : 1 Sub : 22 Byte(s): 16 - Ok 13:53:12 : Field : 1 Sub : 23 Byte(s): 4 - Ok 13:53:12 : Field : 1 Sub : 24 Byte(s): 84 - Ok 13:53:12 : Field : 1 Sub : 25 Byte(s): 4 - Ok 13:53:12 : Field : 1 Sub : 26 Byte(s): 110 - Ok 13:53:13 : Field : 1 Sub : 28 Byte(s): 98 - Ok 13:53:13 : Field : 1 Sub : 29 Byte(s): 10 - Ok 13:53:13 : Field : 1 Sub : 31 Byte(s): 98 - Ok 13:53:13 : Field : 1 Sub : 33 Byte(s): 36 - Ok 13:53:13 : Field : 1 Sub : 34 Byte(s): 80 - Ok 13:53:13 : Field : 1 Sub : 35 Byte(s): 16 - Ok 13:53:13 : Field : 1 Sub : 37 Byte(s): 4 - Ok 13:53:13 : Field : 1 Sub : 39 Byte(s): 36 - Ok 13:53:13 : Field : 1 Sub : 44 Byte(s): 182 - Ok 13:53:13 : Field : 1 Sub : 45 Byte(s): 182 - Ok 13:53:13 : Field : 309 Sub : 0 Byte(s): 4 - Ok 13:53:13 : Field : 309 Sub : 1 Byte(s): 2 - Ok 13:53:13 : Field : 309 Sub : 2 Byte(s): 12 - Ok 13:53:13 : Field : 309 Sub : 4 Byte(s): 12 - Ok 13:53:13 : Field : 309 Sub : 5 Byte(s): 12 - Ok 13:53:13 : Field : 309 Sub : 7 Byte(s): 12 - Ok 13:53:13 : Field : 309 Sub : 8 Byte(s): 12 - Ok 13:53:14 : Field : 309 Sub : 17 Byte(s): 12 - Ok 13:53:14 : Field : 309 Sub : 22 Byte(s): 12 - Ok 13:53:14 : PM Upload Done!... sorry i didnt backup simlock area.. | |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
