Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 05-02-2010, 06:38   #1 (permalink)
marvin03's Avatar
Member: 1015389
Sonork: 19830303
Thanks Meter: 526
TMA Adaptor w/usb attach to ATF!
if i add tma adaptor (the one w/ usb) in atf the green light looks brighter than normal..in this way do i get damage in my box in future..
i have some test here 3110c with TMA w/ usb attach:
Reading Phone Information...
MCU: V 07.21 05-11-08 RM-237 (c) Nokia.
IMEI: 356061031255963
Product code : 0514947
   ********   Reading SimLock   ********
Simlock Version :  SIMLOCK SERVER VERSION 63
CONFIG KEY:  0000000000000000
PROVIDER KEY:  2440700000000000
Provider  :  AT&T;U.S.A. (3650)
Counters  :  0/3  ,  0/10
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status :  Not Locked
SIMLOCK_TEST  : PASSED
SECURITY_TEST : PASSED
Certificate saved to :  C:\Program Files\AdvanceBox Turbo Flasher\Nokia\Backup\sl1_certificate_V 07.21 05-11-08 RM-237 (c) Nokia._356061031255963_Not Locked_124257.pm
Changing MODE : FLASH
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
                 TIME START HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 7  (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000001
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00010006
     ID DWORD    3 : 010C1921
     ID DWORD    4 : 01001101
  2  ROM_ID 15
     Block Length  : 5  (05)
     ID DWORD    0 : 00000232
  3  ROM_ID 15
     ID DWORD    0 : 00000353
  4  PUBLIC_ID 12
     ID DWORD    0 : 2D200218
     ID DWORD    1 : 5EC58B56
     ID DWORD    2 : B575057F
     ID DWORD    3 : 994BBC1D
     ID DWORD    4 : 11BBC83F
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 191EC665
     CRC         1 : DFAAF68F
Checksum           66
BootCodeLen : 61
SearchForBootstrap_DCT5..
2ND
KEYS
2ND
CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 03
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : NOR  00
   Device Index      : 00
   Manufacturer Code : 00EC ->
   Device ID         : 2208 -> K8F5615ETM/K5G5629ATD
   Extended/Fixed ID : 0000
   Revision ID       : 6921
 2 Sub Block ID      : 11  STORAGE_DEVICE_CONTENTS_BB5
   Block Length      : 13
   Device Index      : 00
   Device Contents   : 00000000000000000000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 Checksum   : 00
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :00EC DevID :2208 ExtID :0000 RevID :6921
 RAP3Gv3_algo.fg
First Algo byte : C0
BB5 ALGORITHM
phone devicealgo :
Flash Descriptor
   Device ID         : 2208
   Revision ID       : 0000
   Size              : 00200000  (2097152)
   VPP Info          : 0009
   Erase10s          : 28
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
VPP INFO : VPP_INFO_3V_MASK  VPP_INFO_9V_MASK
C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
SearchForAlgorithm_DCT5  : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType  : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5  : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
START READING RPL DATA
Reading : NPC
OK
Reading : VARIANT
OK
Reading : CCC
OK
Reading : HWC
OK
Reading : R&D
OK
FINISHED READING RPL DATA
RPL saved to: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\backup\356061031255963\356061031255963_124317.rpl
FlashInfo.RestartMode : 2
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.mcusw_cal
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
CMT Supported Hardwares :
                         > 0103192101001101
                         > 010C192101001101
Secondary Sending Speed    : 3250000Hz
Algorithm Sending Speed    : 6500000Hz
Program Sending Speed      : 6500000Hz
Message Reading Speed      : 98000Hz
Number of Blocks :  944
Entry Point:  0x44FC
Page Format : -1
MAX PAGE : 0x00004000
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_cal
CMT Type : BB5
                         > 0103192101001101
                         > 010C192101001101
Number of Blocks :  208
Entry Point:  0x00A6
Page Format : -1
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_cal
CMT Type : BB5
                         > 0103192101001101
                         > 010C192101001101
Number of Blocks :  248
Entry Point:  0x00B2
Page Format : -1
BootFlashMode_DCT5
BootFlashMode_DCT5
VBATT OFF ...
VBATT ON
Setting VBATT Done!...
BootFlashMode_DCT5
                 TIME START HERE
  1  SYSTEM_ASIC_ID 01
  2  ROM_ID 15
  3  ROM_ID 15
  4  PUBLIC_ID 12
  5  ASIC_MODE_ID 13
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
  7  ROM_ID 15
     CRC         0 : 191EC665
     CRC         1 : DFAAF68F
Checksum           66
BootCodeLen : 61
2ND
KEYS
2ND
 MessageID  : C1
 SubBlocks  : 03
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 6921
   Block Length      : 13
   Device Index      : 00
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
 Checksum   : 00
SendAlgoCode_DCT5..
 RAP3Gv3_algo.fg
BB5 ALGORITHM
phone devicealgo :
Flash Descriptor
   Device ID         : 2208
   Revision ID       : 0000
   VPP Info          : 0009
   Erase10s          : 28
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
No partition info....
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength  :  0x004E  (78)
ERASE Blocks :  0x0001  (1)
erase blocks : 1
CurrPos : 03
CurrEraseLen : 4B
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x4B (75)
            BB ASIC Index    : 0x00 CMT
            Device Type      : 0x00 NOR
            Device Index     : 0x00
               0             : 00000000-000006BF
               1             : 000006C0-0001FFFF
               2             : 00020000-0007FFFF
               3             : 00080000-000DFFFF
               4             : 00100000-001FFFFF
               5             : 00200000-0031FFFF
               6             : 00320000-0105FFFF
               7             : 01060000-01067FFF
               8             : 01068000-0107FFFF
ERASE_REQUEST_BB5 : 5009120B00000000000000000006BF120B000000000006C00001FFFF120B000000000200000007FFFF120B00000000080000000DFFFF120B00000000100000001FFFFF120B000000002000000031FFFF120B000000003200000105FFFF120B0000000106000001067FFF120B000000010680000107FFFF82
   >> Time Elapsed 3 seconds
   >> Time Elapsed 6 seconds
   >> Time Elapsed 9 seconds
   >> Time Elapsed 12 seconds
   >> Time Elapsed 15 seconds
   >> Time Elapsed 18 seconds
   >> Time Elapsed 21 seconds
   >> Time Elapsed 24 seconds
   >> Time Elapsed 27 seconds
   >> Time Elapsed 30 seconds
   >> Time Elapsed 33 seconds
   >> Time Elapsed 36 seconds
   >> Time Elapsed 39 seconds
   >> Time Elapsed 42 seconds
   >> Time Elapsed 45 seconds
Status_BB5 STATUS_REQUEST_BB5..
1  Sub Block ID      : 14 STATUS_NOR_OK_BB5
           Block Length      : 01
           BB ASIC Index     :  00
Successfully erased..
StartErase_DCT5...
BlockLength  :  0x000E  (14)
erase blocks : 1
CurrPos : 03
CurrEraseLen : 0B
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 01080000-0151FFFF
ERASE_REQUEST_BB5 : 5001120B000000010800000151FFFF88
           Block Length      : 01
           BB ASIC Index     :  00
StartErase_DCT5...
erase blocks : 1
CurrPos : 03
CurrEraseLen : 0B
            Device Index     : 0x00
               0             : 01520000-01FDFFFF
ERASE_REQUEST_BB5 : 5001120B0000000152000001FDFFFF92
           Block Length      : 01
           BB ASIC Index     :  00
Time Taken to Erase : 00:01:31
TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 04 D9
ReturnedType : 04 DDRand2TX
Is Flashing CLOCK AUTO : -1
Processing  : rm237__07.21.mcusw_cal
Total blocks to write : 944
>>  CMT Rootkey Hash CERT : NOLO
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS
>>  CMT Rootkey Hash CERT : UPDAPP
>>  CMT Rootkey Hash CERT : DSP0
>>  CMT Rootkey Hash CERT : MCUSW
>>  CMT Rootkey Hash CERT : PMM_CONF
>>  CMT Rootkey Hash CERT : SBIF_CONF
Processing  : rm237__07.21.ppm_cal
Total blocks to write : 208
Processing  : rm237__07.21.image_cal
Total blocks to write : 248
ContinueFlash_DCT5 Complete
           Block Length      : 01
           BB ASIC Index     :  00
Continue Flash Complete :  : No Error - 0 (0x00)
Time Taken to Flash  : 00:02:08
Total Flashing Time (Booting + Erase + Flashing) : 00:03:42
all reading back up and flashing ok
br,
marvin
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.17938 seconds with 9 queries
