05-01-2010, 17:16 | #1 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 230911 Status: Offline Thanks Meter: 177 | Is Flashing Possible without External VPP |
05-01-2010, 19:33 | #2 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | yes u can flash without external vpp.if u dont have ext vpp cable u uncheck external vpp. here is log n82 flashed without external vpp turbo mode selected speed 15mhz Code: Processing Image File : D:\flash files\n82\RM-313_35.0.002_PR.C0R CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 471 Entry Point: 0x026E Page Format : -1 MAX PAGE : 0x00030000 Processing Image File : D:\flash files\n82\RM-313_35.0.002_PR.v08 CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101021103 > 400C192101021103 > 4003192101002003 > 400C192101002003 > 400C192101011103 > 4003192101011103 > 4003192101031103 > 400C192101031103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 66 Entry Point: 0x0159 Page Format : -1 MAX PAGE : 0x00030000 Processing Image File : D:\flash files\n82\RM313_31.0.016_009_uda_5.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101021103 > 400C192101021103 > 4003192101002003 > 400C192101002003 > 400C192101011103 > 400C192101021105 > 4003192101021105 > 400C192101031103 > 4003192101031103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 1582 Entry Point: 0x0113 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 11 (0x0B) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 24200705 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 4BEE1644 ID DWORD 1 : A6A9990C ID DWORD 2 : 3AD7A72A ID DWORD 3 : C22D89FC ID DWORD 4 : 94A65AD6 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : BA 87 10 A7 E1 CD 5A 29 09 B9 A8 75 DB 27 AA 24 00 00 00 00 5 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01021103 6 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 8 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 14500116 ID DWORD 1 : 2E7B0058 ID DWORD 2 : EB3CA542 ID DWORD 3 : 5D86162C ID DWORD 4 : F0BCF640 9 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 10 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 11 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : A8C1D671 CRC 1 : 3E691FF8 Checksum 0F BootCodeLen : 9A SearchForBootstrap_DCT5.. KEYS CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 2C7E -> 72NS128N Extended/Fixed ID : 0000 Revision ID : 6921 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :2C7E ExtID :0000 RevID :6921 RAPIDOv11_XSR15_alg.fg First Algo byte : 56 XSR 1.5 phone devicealgo : Flash Descriptor Manufacturer Code : 0001 Device ID : 2C7E Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00100000 (1048576) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Searching for APE Boot File.. SearchForBootstrap_DCT5... KEYS KEYS 2ND 2ND SILO SILO APE Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA2" FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 01 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 BCM21351_PI155_XSR16_usbalg.fg First Algo byte : 56 BCM21351_XSR16_usbalg.fg First Algo byte : 56 h3_sam_nand_format.fg First Algo byte : 00 h3_sam_nand_gbbm.fg First Algo byte : 00 h3_sam_nand_hdd.fg First Algo byte : 00 h3_sam_nand_xsr.fg First Algo byte : 00 h3_sam_nand_xsr_small.fg First Algo byte : 00 h3_xsr15_flash_alg.fg First Algo byte : 00 MICROv10_alg2nd.fg OMAP2420_XSR15_alg.fg First Algo byte : 56 OMAP2420 UNISTORE-II-1.5.1 ALG phone devicealgo : Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00010000 (65536) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok Pabub KEY Request No PAPUBKeysHash Returned Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : APE 1 Certificate 2 Name : HWC ASIC Index : APE 1 Certificate 3 Name : CCC ASIC Index : APE 1 Certificate 4 Name : R&D ASIC Index : APE 1 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 01 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 01 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 01 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 01 CF STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03320000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03320000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03320000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03320000 PARTITION_INFO_REQUEST_BB5 : 64012F4F01010000010000FFFFFFFF00000004000000030000000200A4000003320000000000040000000203D60000033200000000000800000001070800000880000000000009000000010F880000001A000030 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03320000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03320000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03320000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03320000 PARTITION_INFO_REQUEST_BB5 : 64012F4F01010000010000FFFFFFFF00000004000000030000000200A4000003320000000000040000000203D60000033200000000000800000001070800000880000000000009000000010F880000001A000030 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) No partition info.... StartErase_DCT5... BlockLength : 0x0063 (99) ERASE Blocks : 0x0002 (2) erase blocks : 2 CurrPos : 03 CurrEraseLen : 1B 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00080000-007CF13D 1 : 00000000-0005FFFF 2 : 00880000-00EFFFFF CurrPos : 20 CurrEraseLen : 43 1 ERASE_AREA_BB5 0x12 Block Length : 0x43 (67) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 00000200-0000AFFF 1 : 0000B800-000AFFFF 2 : 00000000-00000FFF 3 : 0000D800-0000E9FF 4 : 00080000-000BFFFF 5 : 000E0000-0045FFFF 6 : 004C0000-0073FFFF 7 : 00A40000-0707FFFF ERASE_REQUEST_BB5 : 5003120B00000000080000007CF13D120B000000000000000005FFFF120B0000000088000000EFFFFF7B >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds >> Time Elapsed 36 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 ERASE_REQUEST_BB5 : 5008120B010100000002000000AFFF120B0101000000B800000AFFFF120B0101000000000000000FFF120B0101000000D8000000E9FF120B01010000080000000BFFFF120B010100000E00000045FFFF120B010100004C00000073FFFF120B01010000A400000707FFFFF2 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000001 Additional Bad : 00000001 Correctable ECC : 00000000 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 05760000-0707FFFF ERASE_REQUEST_BB5 : 5001120B010100057600000707FFFF58 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000001 Additional Bad : 00000001 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:41 Is Flashing CLOCK AUTO : 0 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : RM-313_35.0.002_PR.C0R Total blocks to write : 471 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> APE Rootkey Hash CERT : X-LOADER >> APE Rootkey Hash CERT : KEYS >> APE Rootkey Hash CERT : PRIMAPP >> APE Rootkey Hash CERT : X-LOADER >> APE Rootkey Hash CERT : KEYS >> APE Rootkey Hash CERT : PRIMAPP >> APE Rootkey Hash CERT : SOS+XZIP >> APE Rootkey Hash CERT : PASUBTOC >> APE Rootkey Hash CERT : PAPUBKEYS >> APE Rootkey Hash CERT : SOS+UPDAPP >> APE Rootkey Hash CERT : SOS+CORE >> APE Rootkey Hash CERT : SOS+ROFS Processing : RM-313_35.0.002_PR.v08 Total blocks to write : 66 >> APE Rootkey Hash CERT : SOS+ROFX Processing : RM313_31.0.016_009_uda_5.fpsx Total blocks to write : 1582 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000001 Additional Bad : 00000001 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:02:01 Total Flashing Time (Booting + Erase + Flashing) : 00:02:49 |
05-02-2010, 06:07 | #3 (permalink) | |
Member: 230911 Status: Offline Thanks Meter: 177 | Quote:
1- N70 2- 7210C 3- 5220 4-2700c | |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
