5220 flesh problem plz help me Reading Phone Information... ERROR : PHONE READ INFO FAILED ERROR : FAILED TO BACKUP, TRY AGAIN... Changing MODE : FLASH VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1A50000B ID DWORD 1 : ADA10254 ID DWORD 2 : 8084D9F8 ID DWORD 3 : 5D41AA74 ID DWORD 4 : DF60CB12 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum E0 BootCodeLen : 61 SearchForBootstrap_DCT5.. KEYS KEYS 2ND 2ND SILO SILO 2ND 2ND KEYS 2ND CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 BCM21351_PI155_XSR16_usbalg.fg First Algo byte : 56 BCM21351_XSR16_usbalg.fg First Algo byte : 56 h3_xsr15_flash_alg.fg First Algo byte : 00 check me : MICROv10_alg2nd.fg OMAP2420_XSR15_alg.fg First Algo byte : 56 RAP3Gv3_algo.fg First Algo byte : C0 BB5 ALGORITHM phone devicealgo : Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00400000 (4194304) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) START READING RPL DATA Reading : NPC OK Reading : VARIANT VARIANT : Empty Reading : CCC OK Reading : HWC OK Reading : R&D OK FINISHED READING RPL DATA RPL saved to: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\backup\353662010523686\3536620105236 86_65019.rpl FlashInfo.RestartMode : 2 Processing Image File : c:\Program Files\Common Files\Nokia\DataPackage\Products\RM-411\rm411__07.23.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1289 Entry Point: 0x5047 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1A50000B ID DWORD 1 : ADA10254 ID DWORD 2 : 8084D9F8 ID DWORD 3 : 5D41AA74 ID DWORD 4 : DF60CB12 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum E0 BootCodeLen : 61 SearchForBootstrap_DCT5.. KEYS KEYS 2ND 2ND SILO SILO 2ND 2ND KEYS 2ND CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 BCM21351_PI155_XSR16_usbalg.fg First Algo byte : 56 BCM21351_XSR16_usbalg.fg First Algo byte : 56 h3_xsr15_flash_alg.fg First Algo byte : 00 MICROv10_alg2nd.fg OMAP2420_XSR15_alg.fg First Algo byte : 56 RAP3Gv3_algo.fg First Algo byte : C0 BB5 ALGORITHM phone devicealgo : Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00400000 (4194304) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x0036 (54) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 33 0 ERASE_AREA_BB5 0x12 Block Length : 0x33 (51) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00040000-000BFFFF 3 : 000C0000-0013FFFF 4 : 00140000-0137FFFF 5 : 01380000-0151FFFF ERASE_REQUEST_BB5 : 5006120B00000000000000000006BF120B000000000006C000 01FFFF120B00000000040000000BFFFF120B000000000C0000 0013FFFF120B000000001400000137FFFF120B000000013800 000151FFFFC4 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds >> Time Elapsed 36 seconds >> Time Elapsed 39 seconds >> Time Elapsed 42 seconds >> Time Elapsed 45 seconds >> Time Elapsed 48 seconds >> Time Elapsed 51 seconds >> Time Elapsed 54 seconds >> Time Elapsed 57 seconds >> Time Elapsed 60 seconds >> Time Elapsed 63 seconds >> Time Elapsed 66 seconds >> Time Elapsed 69 seconds >> Time Elapsed 72 seconds >> Time Elapsed 75 seconds >> Time Elapsed 78 seconds >> Time Elapsed 81 seconds >> Time Elapsed 84 seconds >> Time Elapsed 87 seconds >> Time Elapsed 90 seconds >> Time Elapsed 93 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:42 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : FF APE_RAP TransmissionTypeRequest_DCT5 : ERROR Operations Failed.... |
I also had same problem. Today I have flashed 5220 the set was alive but it became dead with same log as you posted. but When I gave external VPP by using Extension Slot the set was alive again so use external VPP but it needs time so flash it on another tool |
Bro. flesh thes JAF wilbe 1000000000000000000%OK |
Uncheck Turbo mode than flash and post result thanx |
