Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 06-24-2011, 12:34   #1 (permalink)
ChandruChiyyan's Avatar
Member: 660093
Sonork: 100.1602344
Thanks Meter: 277
Thumbs up 5230 phone startup failed - [Problem Solved]
here is the phone log:
PHP Code:
MCU VersionV ICPR72_11w10.1 15-03-11 RM-588 (cNokia
IMEI Plain
359351030979599
IMEI Spare
A359351030979590
IMEI SV
33593510309795923F
Phone Model
Nokia 5230
Product Serial Number
0
Default SN Type      0
PPM Version
RFIC Version
17141716
DSP Version
ICPR72_10w43
AHNE Version
11
APE SW Core Version
V 50.0.001
APE Variant Version
V 50.0.001V 50.0.001 V 50.0.001
APE Test Version
eno_version
Retu Version
16
Tahvo Version
22
APE HW Version
256
APE ADSP SW Version
256
********   Reading SimLock   ********
Unable to read SP Data..
IMEI Plain
359351030979599
IMEI Spare
A359351030979590
IMEI SV
33593510309795923F
Phone Model
Nokia 5230
0
Default SN Type      0
PPM Version
RFIC Version
17141716
DSP Version
ICPR72_10w43
AHNE Version
11
APE SW Core Version
V 50.0.001
APE Variant Version
APE Test Version
eno_version
Retu Version
16
Tahvo Version
22
APE HW Version
256
APE ADSP SW Version
256
SECURITY_TEST           PASSED
PHONE_MODE
LOCAL MODE
It's Rpl problam ?
Old 06-24-2011, 13:27   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Hello.
Yes, simlock is corrupted - need to buy an RPL file or write PM120 backup if you have that.
Old 06-24-2011, 13:34   #3 (permalink)
Member: 660093
Sonork: 100.1602344
Thanks Meter: 277
Originally Posted by ..::Angel::.. View Post
Hello.
I have backup this file(SL3_certificate_V ICPR72_10w42.2 26-11-10 RM-588 (c) Nokia_359351030979599__114752.pm) can i write this?
Old 06-24-2011, 13:57   #4 (permalink)
Member: 643472
Sonork: 100.96901
Hello.
Do write, and post here writing log too.
Old 06-24-2011, 14:20   #5 (permalink)
Member: 660093
Sonork: 100.1602344
Thanks Meter: 277
Hello.
here is the log:
PHP Code:
IMEI Plain
359351030979599
IMEI Spare
A359351030979590
IMEI SV
33593510309795923F
Phone Model
Nokia 5230
0
Default SN Type      0
PPM Version
RFIC Version
17141716
DSP Version
ICPR72_10w43
AHNE Version
11
APE SW Core Version
V 50.0.001
APE Variant Version
APE Test Version
eno_version
Retu Version
16
Tahvo Version
22
APE HW Version
256
APE ADSP SW Version
256
IMEI Plain
359351030979599
IMEI Spare
A359351030979590
IMEI SV
33593510309795923F
Phone Model
Nokia 5230
0
Default SN Type      0
PPM Version
RFIC Version
17141716
DSP Version
ICPR72_10w43
AHNE Version
11
APE SW Core Version
V 50.0.001
APE Variant Version
APE Test Version
eno_version
Retu Version
16
Tahvo Version
22
APE HW Version
256
APE ADSP SW Version
256
PHONE_MODE
TEST MODE
Changing MODE
FLASH
BOOTING BB5 Phone
TIME STARTS HERE
CMT Hardware 400C192101051103
CMT
PUBLIC ID 1EB00016378A0052E5D6271B45666763CD424A95
CMT ROOTHASH
479C6DDE3942E12C429C1D6ADED80371
CMT ROM_ID
4B9B75103E691FF8
Send Loader
This Phone is a "New HASH" Phone
You need to use The ATF Network and
Authorize this Phone to enable Super
   Dongle Repair
and Stand-Alone SX4.
Visit The ATF Store for more Information
VBATT OFF
VBATT ON
Setting VBATT Done
Old 06-24-2011, 14:56   #6 (permalink)
wong edan's Avatar
Member: 775581
Thanks Meter: 186
I'm still not clear whether every time Unable to read sp data means that the simlock corrupted ?
in the mx-key it is written clearly whether simlock corrupted or simlock invalid, etc.
please explain...
Old 06-25-2011, 07:06   #7 (permalink)
Member: 660093
Sonork: 100.1602344
Thanks Meter: 277
Supporter post the replay.....what can i do ?
Old 06-25-2011, 14:39   #8 (permalink)
Member: 1144411
Sonork: 100.1593619
Thanks Meter: 60
Send Loader...
Phone
and
Dongle Repair
and Stand-Alone SX4
more Information
VBATT OFF
VBATT ON
Setting VBATT Done
their your answer
autorize with atf network
br
Old 06-25-2011, 15:00   #9 (permalink)
Member: 643472
Sonork: 100.96901
Hello.
I said, write backup and post writing log, above log are not PM writing log.
Old 06-27-2011, 08:14   #10 (permalink)
Member: 660093
Sonork: 100.1602344
Thanks Meter: 277
Hello.
PHP Code:
Selected PM FileC:\AdvanceBox Turbo Flasher\Nokia\Backup\359351030979599\SL3_certificate_V ICPR72_10w42.2 26-11-10 RM-588 (cNokia_359351030979599_Not Locked_111750.pm
Start Uploading PM
IMEI Plain
359351030979599
IMEI Spare
A359351030979590
IMEI SV
33593510309795923F
Phone Model
Nokia 5230
0
Default SN Type      0
PPM Version
RFIC Version
17141716
DSP Version
ICPR72_10w43
AHNE Version
11
APE SW Core Version
V 50.0.001
APE Variant Version
APE Test Version
eno_version
Retu Version
16
Tahvo Version
22
APE HW Version
256
APE ADSP SW Version
256
IMEI Plain
359351030979599
IMEI Spare
A359351030979590
IMEI SV
33593510309795923F
Phone Model
Nokia 5230
0
Default SN Type      0
PPM Version
RFIC Version
17141716
DSP Version
ICPR72_10w43
AHNE Version
11
APE SW Core Version
V 50.0.001
APE Variant Version
APE Test Version
eno_version
Retu Version
16
Tahvo Version
22
APE HW Version
256
APE ADSP SW Version
256
PHONE_MODE
LOCAL MODE
Field
120 Sub 0 Byte(s): 944  Ok
Field
120 Sub 1 Byte(s): 160  Ok
Field
120 Sub 2 Byte(s): 132  Ok
Field
120 Sub 3 Byte(s): 112  Ok
Field
308 Sub 0 Byte(s): 4  Failed
Field
308 Sub 1 Byte(s): 8192  Failed
Field
308 Sub 3 Byte(s): 4  Failed
Field
308 Sub 4 Byte(s): 4  Failed
Field
308 Sub 6 Byte(s): 4  Failed
Field
308 Sub 7 Byte(s): 4  Failed
Field
308 Sub 9 Byte(s): 40  Failed
PM  Upload Done
IMEI Plain
359351030979599
IMEI Spare
A359351030979590
IMEI SV
33593510309795923F
Phone Model
Nokia 5230
0
Default SN Type      0
PPM Version
RFIC Version
17141716
DSP Version
ICPR72_10w43
AHNE Version
11
APE SW Core Version
V 50.0.001
APE Variant Version
APE Test Version
eno_version
Retu Version
16
Tahvo Version
22
APE HW Version
256
APE ADSP SW Version
256
CONFIG KEY:  0000000000000000
PROVIDER KEY
:  2440700000000000
Provider
:  AT&T;U.S.A. (3650)
Counters  :  0/3  ,  0/10
   Block
[1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block
[2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block
[3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block
[4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block
[5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block
[6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block
[7]  1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status
:  Not Locked
SIMLOCK_TYPE
PA_SL3 (15-digit NCK)
SIMLOCK_TEST             PASSED
SECURITY_TEST
PASSED
SECURITY_CODE
ENCRYPTED
PHONE_MODE
LOCAL MODE
After write back up my mobile is ready.........
Old 06-27-2011, 10:05   #11 (permalink)
Member: 643472
Sonork: 100.96901
PHP Code:
Start Uploading PM
IMEI Plain
359351030979599
IMEI Spare
A359351030979590
IMEI SV
33593510309795923F
Phone Model
Nokia 5230
0
Default SN Type      0
PPM Version
RFIC Version
17141716
DSP Version
ICPR72_10w43
AHNE Version
11
APE SW Core Version
V 50.0.001
APE Variant Version
APE Test Version
eno_version
Retu Version
16
Tahvo Version
22
APE HW Version
256
APE ADSP SW Version
256
IMEI Plain
359351030979599
IMEI Spare
A359351030979590
IMEI SV
33593510309795923F
Phone Model
Nokia 5230
0
Default SN Type      0
PPM Version
RFIC Version
17141716
DSP Version
ICPR72_10w43
AHNE Version
11
APE SW Core Version
V 50.0.001
APE Variant Version
APE Test Version
eno_version
Retu Version
16
Tahvo Version
22
APE HW Version
256
APE ADSP SW Version
256
PHONE_MODE
LOCAL MODE
Field
Field
Field
Field
Field
Field
Field
Field
Field
Field
Field
PM  Upload Done
IMEI Plain
359351030979599
IMEI Spare
A359351030979590
IMEI SV
33593510309795923F
Phone Model
Nokia 5230
0
Default SN Type      0
PPM Version
RFIC Version
17141716
DSP Version
ICPR72_10w43
AHNE Version
11
APE SW Core Version
V 50.0.001
APE Variant Version
APE Test Version
eno_version
Retu Version
16
Tahvo Version
22
APE HW Version
256
APE ADSP SW Version
256
PROVIDER KEY
:  2440700000000000
Provider
   Block
   Block
   Block
   Block
   Block
   Block
   Block
SP Lock Status
:  Not Locked
SIMLOCK_TYPE
SIMLOCK_TEST             PASSED
SECURITY_TEST
PASSED
SECURITY_CODE
ENCRYPTED
PHONE_MODE
LOCAL MODE
It is good to make backup before :-)
Cheers!
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
Page generated in 0.40831 seconds with 9 queries
