7230 USB Flash umber of Image Files: 3 Processing Image File : rm598__06.95.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 159 Entry Point: 0x0259 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm598__06.95.ppm_l CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 25 Entry Point: 0x011D Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm598__06.95_001.image_l_claro_cl_3W4C9 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 51 Entry Point: 0x0154 Page Format : -1 MAX PAGE : 0x00040000 AUTO SELECTED DEAD USB FLASHING... If Flashing DOES NOT Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly.. AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 Cant verify BootRom! AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootRom Verified! BootFlashModeDCT5Ex Succeded After 2 Tries SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00000001 ID DWORD 3 : 020C1921 ID DWORD 4 : 02044100 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001030 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 21C00117 ID DWORD 1 : B4360049 ID DWORD 2 : 22DC3198 ID DWORD 3 : 549CE530 ID DWORD 4 : F836D5DE 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 67E82268 CRC 1 : F29CEA60 START FLASHING RawLoaderExtract: Processing rm598__06.95.mcusw Match LOADER : D:\atf\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAP3Gv40_2 nd.fg Loader Uploaded..... ERROR: MCU_CONFIGURATION_RESPONSE is not VALID Please make sure your Battery Power is enough. Then try to Flash again... Flashing Failed.... Booting/Flashing Failed... Please Try Again... The >Battery is full charged. Cannot flash with any tool :( With ATF i try with new loader and old loader Fbus is a only way? Thnks in advance Polaco |
"With ATF i try with new loader and old loader" when you flash via usb no new nor old loader come in consideration because there are other loaders used. Fbus is a only way? ---yes indeed! |
