02-05-2018, 22:41 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Reapri SM-J105B dead is possible? Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.49 (RIFFBOX1), JTAG Manager Version: 1.77 Connecting to the SD/eMMC Card...OK Set I/O Voltage reads as 2.68V, SD_CLK Frequency is 533 KHz Memory Type .......................... eMMC Manufacturer ID ...................... 0x65 OEM/Application ID ................... 0x6F Product Name ......................... "M MOR " Package .............................. Removable User Area Partition Size ............. 0x000075700000 Bytes (1.83 GB) Boot Partition Size .................. 0x000000200000 Bytes (2.00 MB) RPMB Partition Size .................. 0x000000020000 Bytes (128.00 KB) OCR Register ......................... 0xC0FF8080 (Dual Voltage, High Capacity) Write Protection Bits ................ NONE ExtCSD Register Fields ............... [177] = 0x00, [179] = 0x78, [162] = 0x00 Boot Configuration ................... Boot from User Area (Bus Width = 1Bit) Chip Revision ........................ 10.1 Multimedia Card Revision ............. 1.5 (eMMC v4.41) Serial Number ........................ 0x00000615 Memory Manufacturing Date ............ May, 2017 |
02-13-2018, 17:39 | #3 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: KATHMANDU,NEPAL
Member: 2438408 Status: Offline Thanks Meter: 380 | Quote:
The Following User Says Thank You to alexid For This Useful Post: |
