05-29-2017, 15:18 | #211 (permalink) | |
Registered User Join Date: Mar 2012 Location: indonesia
Member: 1731024 Status: Offline Thanks Meter: 13 | Quote:
Your Box Distributor/Reseller has requested that your Box should be Disabled. Please Contact your Box Distributor/Reseller and settle the Problem. If you think you are getting this Message by Mistake, please visit ATF Support: Advance-Box - GSM-Forum please help me sir... | |
07-17-2017, 19:18 | #214 (permalink) |
No Life Poster Join Date: Sep 2001 Location: London, UK
Member: 6486 Status: Offline Sonork: 100.79846 Thanks Meter: 350 | ADVANCEBOX TURBO FLASHER A SN: 9D5AB390A ============================================== Please update your Box Firmware ============================================== * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Click "Update Firmware" button SERVER ERROR . PLEASE FIX REQUIRED BR, |
08-25-2017, 08:38 | #215 (permalink) |
Junior Member Join Date: Aug 2017 Location: Iran Age: 33
Member: 2751020 Status: Offline Thanks Meter: 0 | I have same problem Help me PLz ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020416 Library Version : 00030118 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : D5BDB9B49D327F91F6741A3B ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
09-02-2017, 22:11 | #216 (permalink) |
Insane Poster Join Date: Mar 2004 Age: 53
Member: 58642 Status: Offline Thanks Meter: 6 | same problem ihave bought this box more than 3 years ago idonīt know exactly maybe more than 4 years a go ,and it started to give me problems more than a year a go,now i want to start to use it but ihave a problem : ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software please i need a solution ,all the information are here: Driver Version : 00020819 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : B9E32C75FDB091C38241A2FC ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done best regards. |
09-07-2017, 11:14 | #218 (permalink) |
Junior Member Join Date: Aug 2011 Location: romania
Member: 1638195 Status: Offline Sonork: mel_gsm Thanks Meter: 1 | atf activation hi,i have this problem with my atf, Your Box Distributor/Reseller has requested that your Box should be Disabled. Please Contact your Box Distributor/Reseller and settle the Problem. |
12-24-2017, 13:55 | #219 (permalink) |
Junior Member Join Date: May 2017
Member: 2715217 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : 99033AC6F34805CFABF94C3E ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done i have this problem .please help me too |
12-27-2017, 13:08 | #220 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Armenia, Armavir
Member: 616204 Status: Offline Thanks Meter: 26 | I have that problem too. please help any solution ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : C7DD3B768DED5191ADC507F6 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done After restor box firmware ============================================== Please update your Box Firmware ============================================== * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Click "Update Firmware" button * Make sure you put ATF Software in Windows FireWall Exclusion List * Make sure you put ATF Software in your Virus Scanner Exclusion List ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
04-13-2018, 10:16 | #223 (permalink) |
Junior Member Join Date: Mar 2007
Member: 473661 Status: Offline Thanks Meter: 0 | Your Box Distributor/Reseller has requested that your Box should be Disabled. Please Contact your Box Distributor/Reseller and settle the Problem. If you think you are getting this Message by Mistake, please visit ATF Support: Is the problem solvable? |
