after flash (upgrade ) N82 white screen - [SOLVED ✔✔✔ Solution Inside ✔✔✔] hello ATF team I flash the n82 set but after successfull flash it came to white screen infor before flash..Good condition. Code: 19:53:17 : ****************************************************** Code: 20:18:24 : MCU: V 06wk41v51 28-01-08 RM-313 (c) Nokia now it is white screen So I erased and flash again---same also erased and put the 20.0.062 also same Now how to fix this????? thanks. |
The last file for APE probably it's no correct, it says ERASEIMAGE... NO IMAGE WRITTEN in fact... Check this. Bye |
How to fix this problem.. I am waiting...ATF team please help me. |
what version of ATF are u using mate??? because i used ATF 6.60 to fix my n-82 |
I use to flash 7.50.. You mean that you fixed by 6.60..Means how to fix this..Just flash in 6.60 or Is there any other way to to fix this problem Thanks. |
why atf team is not reply here... |
White Screen on Normal Mode sounds like ENO Problem or FILE SYSTEM Format. Anyway, since you FULL ERASE already, then just go download this ENO FILE for your N82 RM-313 file name is Nokia_firmware_RM-313_ENO_SW_2008wk06_v3.0.exe get it here: http://174.120.45.27/tmp/full_support.png Make sure that you write back your FULL RPL back to the phone. If APE NPC is missing, then it will also sometimes become white screen + Nokia Logo on Normal Mode. |
Flashed with ENO Code: ATF Software Version v7.60 |
@sky_finder Follow this procedure step by step and you will have it working. I assume you have FULL RPL backup since I see it in your logs... Anyway, let's begin! 1. Full Erase CMT 16 MB using ERASE Flash Function 2. Full Erase APE 256 MB usgin ERASE Flash Function A shortcut for 1 and 2 is just to click the SCAN button inside the Erase Flash tab, then put a check on the 2 flash chips found, then click ERASE. 3. Full Flash your phone using your latest 35.0.002 Firmware (MCU, PPM, CNT etc...) * uncheck Backup Simlocks * uncheck Backup RPL * uncheck Factory Reset --> Now Phone should be BLACK Screen, but scan phone works with 12345 imei... 4. Now Write this RPL File to your Phone: C:\AdvanceBox Turbo Flasher\Nokia\backup\358984013759900\3589840137599 00_81913.rpl 5. Now Write this PM File to your Phone: C:\AdvanceBox Turbo Flasher\Nokia\Backup\358984013759900\SL2_certifica te_V 06wk41v51 28-01-08 RM-313 (c) Nokia_358984013759900_Not Locked_81831.pm *** You can also skip this write PM by just using Repair Simlocks (SL1 and SL2) function. 6. Now use "Stand Alone SX4" and write PM 1 and 309 from RM-320.pm --> Now scan phone should show everything is ok, but phone should be BLANK Screen! 7. Now Flash one of the ENO file which I told you to download... Flash 1 file only,, this file "rm313_ENO_x_2008wk06updv0.030.fpsx" * uncheck Backup Simlocks * uncheck Backup RPL * uncheck Factory Reset --> Now you will get "Test Mode" on screen 8. Now flash the second ENO file to the phone, file name: "normalize_susd_eno_sharaku_urel.fpsx" * uncheck Backup Simlocks * uncheck Backup RPL * uncheck Factory Reset --> You will still get "Test Mode" on screen 9. Now Full Flash the phone again (MCU, PPM, CNT etc...) * uncheck Backup Simlocks * uncheck Backup RPL * PUT A CHECK on Factory Reset 10. Now Phone SHOULD BE ok... The Procedure above WORKS on ALL RAPIDOYAWE Based Phones (N95, N95 8GB, N82 etc...) All you need is 2 ENO files and a full RPL Certificate Backup of the CMT and APE Subsystems. |
Flashed with ENO Code: ATF Software Version v7.60 Then fullflash with product code (4 files) Code: ATF Software Version v7.60 Write backup rpl Code: AdvanceBox SendBootCodeEx RPL IS failed to write but This is the backup which I took on ATF. SO I think some bug on the new update.... so I tried on 7.40... |
Yes, it has write RPL problem on some phones,, but I will release a quick fix today,, anyway, try my 10 steps on how to fix your phone,, I have done those steps many many times and fixed many phones as well. |
Try on 7.40 Code: AdvanceBox SendBootCodeEx INFOR on 7.40 Code: AdvanceBox SendBootCodeEx Now I try to fix simlock sd pm 1.309 . INFO Code: AdvanceBox SendBootCodeEx WOW..MY SET IS OK....I FIXED IT WITH YOUR HELP.. OHHHHHO I CAN NOT BELIEVE IT..because it almost 6 days to try to fix this problem.. I think the mistake what I have done is... 1. When I flash the set I put 3 files not 4 because some users report in the forum ..so I did it. 2. Did not write the NPC data.. because I thought phone will On with out NPC.But You advice me to put the backup and test.Thanks for that 3.I flash the ENO (before I try many time)one by one not at the same time also I did not use ATF for flash ENO because I had a problem on the new update and now I fix it and I tried to flash the ENO.It was ok. Thanks for all.... (But please check why in the new update my backup (RPL)can not write it) THANKS FOR THE HELP |
@sky_finder Rapidoyawe phones are really confusing, so it is not your fault. Congratulations on fixing your phone... If anybody knows a short-cut method to my 10 steps, they are very welcome to share a faster method... if they are willing to share :P B.R. |
I didn't remember about phone type, but when I use ENO, I flash it BEFORE flash FULL FIRMWARE and phone it's ok! Hope this help you, master! :) Bye |
Just a little correction.. Quote:
Thanks. |
