03-13-2011, 13:53 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Punjab INDIA
Member: 1021573 Status: Offline Sonork: 100.1622854 Thanks Meter: 55 | 7210 cs waht i do i did in imei and locks and tick repair sl1/sl2 but it says MCU: V 07.23 17-07-09 RM-436 (c) Nokia IMEI: 351962033119922 Model : Nokia 7210 Supernova Product Serial Number: HDA144921 Module Code : 0203868 Basic Production Code: 0563951 Default SN Type : 0 MCU SW Version : V 07.23 17-07-09 RM-436 (c) Nokia C BT MCM Version : 2222-143C PPM Version : V 07.23 17-07-09 RM-436 (c) Nokia HW Version : 1001 RFIC Version : 06540601 DSP Version : ICPR72_09w17 LCD Version : SEIKO AHNE Version : 30 Retu Version : 15 Tahvo Version : 22 ******** Reading SimLock ******** Unable to read SP Data.. ******** Reading SimLock ******** Unable to read SP Data.. SIMLOCK_TYPE : PA_SL1/PA_SL2 SIMLOCK_TEST : FAILED SECURITY_TEST : PASSED PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NIMMIIIIRRFF094B2F01 DCC Ver: XXXXXX ERROR: DCC File Mismatched! Required DCC File: NIMMIIIIRRFF094B2F01 Write the correct DCC to Fix the Problem ================================================== = SL1/SL2 Simlock RPL Stand Alone Edition ================================================== = Generating Simlock Dongle RPL... (This may take upto 30 Seconds on New RAPIDO HASH) ERROR: Cannot Create Simlock RPL! |
03-13-2011, 15:14 | #3 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Delphi XE2
Member: 1004812 Status: Offline Thanks Meter: 152 | you problem on here : SIMLOCK_TEST : FAILED repair use ATF ( menu in > emei & lock >repair simlock sl1 sl2) after it finished do sx4 auth pm choose 1 & 309 pm all will be resolved ENJOY to use ATF |
07-31-2012, 13:16 | #9 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 835074 Status: Offline Thanks Meter: 35 | not done sim lock AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 24B0010C ID DWORD 1 : B31B0354 ID DWORD 2 : E6AF1C9D ID DWORD 3 : 23C52DB8 ID DWORD 4 : 6822EE12 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum FB SearchForBootstrap_DCT5.. D:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> NU48F512 Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK D:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: D93826B23E9B093BE4DD7304FBAA6778996AE60B Scanning Simlock Applet Type... OK ================================================= SL1/SL2 Applet detected ================================================= FlashInfo.RestartMode : 2 ================================================ Basic Phone Information ================================================ MCU Version: V 07.23 17-07-09 RM-411 (c) Nokia IMEI Plain : 353662016016255 IMEI Spare : A353662016016250 IMEI SV : 33536620160162540F Phone Model: Nokia 5220 XpressMusic Category : Classic Phone Phone Type : RM-411 ================================================ Extended Phone Information ================================================ Product Serial Number: DTB781537 Product Code : 0563611 Module Code : 0203661 Basic Production Code: 0554881 Long Production SN : 0 PPM SW Version : V 07.23 17-07-09 RM-411 (c) Nokia MR MCU SW Version : V 07.23 17-07-09 RM-411 (c) Nokia HW Version : 1000 Content Pack Version : Content: mr_in_red V 07.23 17-07-09 RM-411 (c) Nokia AHNE Version : 30 RETU Version : 15 TAHVO Version : 22 Bluetooth ID : 00:21:AB:ED:72:45 CS Type : GSM850, GSM1800, GSM1900 ================================================ Simlock Information ================================================ Unable to read SP Data.. ================================================ Basic Phone Information ================================================ MCU Version: V 07.23 17-07-09 RM-411 (c) Nokia IMEI Plain : 353662016016255 IMEI Spare : A353662016016250 IMEI SV : 33536620160162540F Phone Model: Nokia 5220 XpressMusic Category : Classic Phone Phone Type : RM-411 ================================================ Extended Phone Information ================================================ Product Serial Number: DTB781537 Product Code : 0563611 Module Code : 0203661 Basic Production Code: 0554881 Long Production SN : 0 PPM SW Version : V 07.23 17-07-09 RM-411 (c) Nokia MR BT MCM Version : 2222-143C MCU SW Version : V 07.23 17-07-09 RM-411 (c) Nokia HW Version : 1000 RFIC Version : 064c0601 DSP Version : ICPR72_09w17 LCD Version : SHARP Content Pack Version : Content: mr_in_red V 07.23 17-07-09 RM-411 (c) Nokia AHNE Version : 30 RETU Version : 15 TAHVO Version : 22 Bluetooth ID : 00:21:AB:ED:72:45 CS Type : GSM850, GSM1800, GSM1900 ================================================ Simlock Information ================================================ Unable to read SP Data.. SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NIMMIIIIRRFF094B2F01 DCC Ver: 002010 Status : OK ================================================ Basic Phone Information ================================================ MCU Version: V 07.23 17-07-09 RM-411 (c) Nokia IMEI Plain : 353662016016255 IMEI Spare : A353662016016250 IMEI SV : 33536620160162540F Phone Model: Nokia 5220 XpressMusic Category : Classic Phone Phone Type : RM-411 ================================================ SL1/SL2 Simlock RPL Stand Alone Edition ================================================ Generating Simlock Data RPL... -> ERROR: wrong Simlock RPL data |
07-31-2012, 14:02 | #10 (permalink) |
No Life Poster Join Date: Dec 2009 Location: DUBAI Age: 33
Member: 1189306 Status: Offline Sonork: 100.1589231 Thanks Meter: 273 | @arifjamal63 bro repair the simlock sl1/sl2. f not done then read the rpl erase ur set flash with latest version write the rpl and then try repair simlock (sl1/sl2) bro |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
Do Scripts For new nokia work? | ondenuove | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-26-1999 21:24 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
