After unlock lumia 800 done Again ask pin code hi yesterday i unlock lumia 800 sucess. 13:37:47 : ================================================== ==== 13:37:47 : Lumia Test Point Connection Module 13:37:47 : ================================================== ==== 13:37:47 : ================================================== ==== 13:37:47 : 13:37:47 : 1. DO NOT USE THE PHONE"S BATTERY 13:37:47 : 2. Connect the Soldered TP Connections to ATF Box 13:37:47 : 3. Disconnect the USB Cable and Wait until the 13:37:47 : the ATF Software will tell you to Connect the USB. 13:37:47 : 13:37:49 : 13:37:49 : Interface Reset OK! 13:37:49 : Reading Platform Information... 13:37:49 : Selecting Active Handle... 13:37:49 : Select Handle OK! 13:37:49 : Sending Ping... 13:37:49 : Ping Reply OK! 13:37:49 : 13:37:49 : Lumia 800/800C Detected 13:37:49 : 13:37:49 : Storage Device Information 13:37:49 : Manufacturer ID: 90 13:37:49 : Application ID : 014A 13:37:49 : Product Name : HYNIX 13:37:49 : Product Rev : 5C 13:37:49 : Product SN : 001801D6 13:37:49 : 13:37:49 : Protection Information 13:37:49 : Write Protect A: OFF 13:37:49 : Write Protect B: OFF 13:37:49 : 13:37:49 : 13:37:49 : Dumping AMSS FAT16 Region 13:37:49 : Please wait for 2-4 Minutes... 13:42:58 : Patch Bit Found... 13:42:58 : Total Patch Bits Found: 1 13:42:58 : Patching AMSS... 13:42:59 : Patch OK! 13:42:59 : 13:42:59 : SP Unlock Done! 13:42:59 : 13:42:59 : PIN: 00000000 13:42:59 : PUK: 0000000000 13:42:59 : 13:42:59 : Total Elapsed Time 00:05:12 then i enter "00000000" phone sucessful unlock then i flash phone to latest fw now it ask pin code i try with "00000000" but wrong so again i try to unlock via test point ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 001801D6 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... WARNING: Patch Bit NOT FOUND! Maybe Phone is already UNLOCKED! Total Elapsed Time 00:04:45 now Ask puk code i try with "0000000000" 10 zero but wrong what is problem please help me |
Br - srinibas |
14:00:41 : ================================================== ==== 14:00:41 : Flash File Checksum Verification 14:00:41 : ================================================== ==== 14:00:41 : RM801_12w46_prod_generic_nokia_osbl.esco: CHECKSUM PASSED 14:00:41 : RM801_12w46_prod_generic_amss.esco: CHECKSUM PASSED 14:00:41 : RM801_12w46_prod_generic_adsp.esco: CHECKSUM PASSED 14:00:47 : RM801_12460_prod_249_01_boot.esco: CHECKSUM PASSED 14:00:47 : RM801_12w46_prod_generic_user_area_erase.esco: CHECKSUM PASSED 14:00:47 : ================================================== ==== 14:00:47 : Verification Done... 14:00:50 : Windows Phone Flashing Started 14:00:50 : 14:00:50 : OSBL File Found: 14:00:50 : RM801_12w46_prod_generic_nokia_osbl.esco 14:00:50 : AMSS File Found: 14:00:50 : RM801_12w46_prod_generic_amss.esco 14:00:50 : ADSP File Found: 14:00:50 : RM801_12w46_prod_generic_adsp.esco 14:00:53 : WPOS File Found: 14:00:53 : RM801_12460_prod_249_01_boot.esco 14:00:53 : USER AREA ERASE File Found: 14:00:53 : RM801_12w46_prod_generic_user_area_erase.esco 14:00:53 : 14:00:53 : ================================================== ==== 14:00:53 : Windows Phone Lumia Flasher 14:00:53 : ================================================== ==== 14:00:53 : 14:00:53 : If the Phone is ALIVE 14:00:53 : 1. Power On the Phone and Connect it to the USB Port 14:00:53 : 14:00:53 : If the Phone is DEAD 14:00:53 : 1. Press and Hold the VOLUME UP button 14:00:53 : 2. Connect it to the USB Port while still Pressing 14:00:53 : the VOLUME UP button 14:00:53 : 3. Continue to Press the VOLUME UP button for 8 more 14:00:53 : seconds 14:00:53 : ================================================== ==== 14:00:53 : 14:01:18 : 14:01:19 : ================================================ 14:01:19 : Basic Phone Information 14:01:19 : ================================================ 14:01:19 : SW Version : 1600.2479.7740.11451 14:01:19 : IMEI Plain : 351682050350818 14:01:20 : HW Version : 112.1402.2.4 14:01:21 : Phone Type : RM-801 14:01:22 : Product Code : 059L7C6 14:01:22 : Basic Product Code: 059J2N6 14:01:22 : Module Code : 0205051 14:01:23 : PSN Number : 00A8D1EAB 14:01:23 : NCSD Version : 1.5 14:01:23 : Variant Information:VAR EURO1 GB ORANGE SL MBLACK 14:01:23 : 14:01:23 : ================================================ 14:01:23 : Extended Phone Information 14:01:23 : ================================================ 14:01:24 : Public ID : 4E5AE7AC3DEACBAEF6CD98C4635C4F3B 14:01:24 : Wireless Lan ID: 94:00:70:8A:7D:2D:00:00 14:01:24 : Bluetooth ID : 94:00:70:89:E0:C7:00:00:00:00:00:00 14:01:24 : 14:01:39 : Rebooting to OSBL MODE 14:01:56 : 14:01:56 : Sending OSBL Certificate 14:01:56 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 14:01:56 : Certificate Size: 452 Bytes 14:01:56 : Status : WRITE OSBL CERTIFICATE SUCCESS 14:01:56 : 14:01:56 : Sending OSBL Data Blocks 14:01:56 : [BLOCK 1 0x00000000~0x000EA227] 14:01:56 : Data Size: 0x000EA228 Bytes 14:01:56 : SHA-256 : F1D3F65C19CCE74C80F90D45FD537862 14:01:56 : ---------- : 29F31C976F943EF924D13C13431AA2B4 14:01:58 : Status : OSBL WRITE SUCCESS 14:01:58 : 14:01:58 : Sending AMSS Certificate 14:01:58 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 14:01:58 : Certificate Size: 449 Bytes 14:01:58 : Status : WRITE AMSS CERTIFICATE SUCCESS 14:01:58 : 14:01:58 : Sending AMSS Data Blocks 14:02:01 : (Please Wait for 25 Seconds...) 14:02:24 : Status : AMSS WRITE SUCCESS 14:02:24 : 14:02:24 : Sending ADSP Certificate 14:02:24 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 14:02:24 : Certificate Size: 449 Bytes 14:02:24 : Status : WRITE ADSP CERTIFICATE SUCCESS 14:02:24 : 14:02:24 : Sending ADSP Data Blocks 14:02:25 : (Please Wait for 25 Seconds...) 14:02:33 : Status : ADSP WRITE SUCCESS 14:02:34 : 14:02:34 : Sending WPOS Certificate 14:02:35 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 14:02:35 : Certificate Size: 1652 Bytes 14:02:36 : Status : WRITE WPOS CERTIFICATE SUCCESS 14:02:36 : 14:02:36 : Sending WPOS Data Blocks 14:02:36 : [BLOCK 1 0x00000000~0x00FFFFFF] 14:02:36 : Data Size: 0x01000000 Bytes 14:02:36 : SHA-256 : 27B0BC606B458A6C31E3B2B80AA5C2FD 14:02:36 : ---------- : AB9B3C22396BB55FEBEDA713EB805C09 14:02:44 : Status : WPOS WRITE SUCCESS 14:02:44 : [BLOCK 2 0x01000000~0x016573FF] 14:02:44 : Data Size: 0x00657400 Bytes 14:02:44 : SHA-256 : 6729DED1321909B0C3CD9D14DAAED23D 14:02:44 : ---------- : 6AE73BB984C7DAC2017B841AA12103D3 14:02:48 : Status : WPOS WRITE SUCCESS 14:02:48 : [BLOCK 3 0x01697400~0x01FFFFFF] 14:02:48 : Data Size: 0x00968C00 Bytes 14:02:48 : SHA-256 : F804E5F3090ACCD1E44C6F50D5254C0C 14:02:48 : ---------- : D84C73570F99D9D8B6E0DA4BB3A6E9D5 14:02:53 : Status : WPOS WRITE SUCCESS 14:02:53 : [BLOCK 4 0x02000000~0x02FFFFFF] 14:02:53 : Data Size: 0x01000000 Bytes 14:02:53 : SHA-256 : 1C861D3E8CFD8007966A2FC382185D2D 14:02:53 : ---------- : 346C0140F4051D8495826865DF20B51E 14:03:01 : Status : WPOS WRITE SUCCESS 14:03:01 : [BLOCK 5 0x03000000~0x03FFFFFF] 14:03:01 : Data Size: 0x01000000 Bytes 14:03:01 : SHA-256 : 83C688F9EE88B12BF7FD29493C6C6947 14:03:01 : ---------- : F567A180C621D86C2DBB7126940285B1 14:03:09 : Status : WPOS WRITE SUCCESS 14:03:09 : [BLOCK 6 0x04000000~0x04FFFFFF] 14:03:09 : Data Size: 0x01000000 Bytes 14:03:09 : SHA-256 : AF2A3333A8D52FDC86C7D2AB4AA1D461 14:03:09 : ---------- : 3EF4D25B54670E0E2634C97E1893D9BC 14:03:17 : Status : WPOS WRITE SUCCESS 14:03:17 : [BLOCK 7 0x05000000~0x05FFFFFF] 14:03:17 : Data Size: 0x01000000 Bytes 14:03:17 : SHA-256 : 68791CB26CD4DC68DD6CBC86F0C90104 14:03:17 : ---------- : E64246C6B3387AE22E6EF480C1EDD2D3 14:03:24 : Status : WPOS WRITE SUCCESS 14:03:24 : [BLOCK 8 0x06000000~0x06FFFFFF] 14:03:25 : Data Size: 0x01000000 Bytes 14:03:25 : SHA-256 : 2C680D05562DC7E28B8322700D33686F 14:03:25 : ---------- : 6370C91ECA30F0F3C037E037B3ECB93A 14:03:33 : Status : WPOS WRITE SUCCESS 14:03:33 : [BLOCK 9 0x07000000~0x07FFFFFF] 14:03:33 : Data Size: 0x01000000 Bytes 14:03:33 : SHA-256 : 002FA28E33DDD68557246B9485B8E3A6 14:03:33 : ---------- : 82F9F13ED1FBC5946CF0F26825195C10 14:03:40 : Status : WPOS WRITE SUCCESS 14:03:40 : [BLOCK 10 0x08000000~0x08FFFFFF] 14:03:40 : Data Size: 0x01000000 Bytes 14:03:40 : SHA-256 : 39EFB7509733EE385A7B137FF6E0846B 14:03:40 : ---------- : 62F60B025B839D450E21B28B4C61440D 14:03:48 : Status : WPOS WRITE SUCCESS 14:03:49 : [BLOCK 11 0x09000000~0x09FFFFFF] 14:03:49 : Data Size: 0x01000000 Bytes 14:03:49 : SHA-256 : C5DA97BB5CD8002D75EB31D5FE8EC786 14:03:49 : ---------- : 7B533F2D633F737F4CA494FE672BDBE4 14:03:56 : Status : WPOS WRITE SUCCESS 14:03:56 : [BLOCK 12 0x0A000000~0x0AFFFFFF] 14:03:56 : Data Size: 0x01000000 Bytes 14:03:56 : SHA-256 : 3C3454B86D4F9963CF30AA5FDA8544E6 14:03:56 : ---------- : C566B652EA6EF924480C542F4E44F233 14:04:05 : Status : WPOS WRITE SUCCESS 14:04:05 : [BLOCK 13 0x0B000000~0x0BFFFFFF] 14:04:05 : Data Size: 0x01000000 Bytes 14:04:05 : SHA-256 : 1402825C996307D9949CCCC3F41D010E 14:04:05 : ---------- : ED5AF660409E8FBD0B14E98976AB1060 14:04:13 : Status : WPOS WRITE SUCCESS 14:04:13 : [BLOCK 14 0x0C000000~0x0CFFFFFF] 14:04:13 : Data Size: 0x01000000 Bytes 14:04:13 : SHA-256 : 73C3DCC3A0C59F02762ECD5785D29EC3 14:04:13 : ---------- : 9D2B1A887BC35332A576621C57FDA052 14:04:21 : Status : WPOS WRITE SUCCESS 14:04:21 : [BLOCK 15 0x0D000000~0x0DFFFFFF] 14:04:21 : Data Size: 0x01000000 Bytes 14:04:21 : SHA-256 : 2A4CB8A666A1712645CAA84D9BF0B620 14:04:21 : ---------- : 9C4BCA7E29D8556C97A3E1D2B7D269B6 14:04:29 : Status : WPOS WRITE SUCCESS 14:04:29 : [BLOCK 16 0x0E000000~0x0EFFFFFF] 14:04:29 : Data Size: 0x01000000 Bytes 14:04:29 : SHA-256 : E593BE197CFEB7D6A6B21DB5959EC009 14:04:29 : ---------- : BF243C9DC593E9819AE1C3C2E196CB95 14:04:37 : Status : WPOS WRITE SUCCESS 14:04:37 : [BLOCK 17 0x0F000000~0x0FFFFFFF] 14:04:37 : Data Size: 0x01000000 Bytes 14:04:37 : SHA-256 : 7159F5DCCB0D1B6920837FB259D9C136 14:04:37 : ---------- : E19FBA81E7A244025EFBBD8A93473A82 14:04:45 : Status : WPOS WRITE SUCCESS 14:04:45 : [BLOCK 18 0x10000000~0x10FFFFFF] 14:04:45 : Data Size: 0x01000000 Bytes 14:04:45 : SHA-256 : DE539F776933ECBF2B0A95577733BB6B 14:04:45 : ---------- : 0E57D708B182A1B16C8A24A56CC25C1F 14:04:53 : Status : WPOS WRITE SUCCESS 14:04:53 : [BLOCK 19 0x11000000~0x11FFFFFF] 14:04:53 : Data Size: 0x01000000 Bytes 14:04:53 : SHA-256 : 9F30CE7EEEB838B98677AE7B40C46C2F 14:04:53 : ---------- : 8E254DED9BDCC66E901DD0C31872707B 14:05:02 : Status : WPOS WRITE SUCCESS 14:05:02 : [BLOCK 20 0x12000000~0x12FFFFFF] 14:05:02 : Data Size: 0x01000000 Bytes 14:05:02 : SHA-256 : 7E9FB8752D293591D7134B49337081E0 14:05:02 : ---------- : 7ACAA42DC083CBF242F90E6028B882B5 14:05:10 : Status : WPOS WRITE SUCCESS 14:05:10 : [BLOCK 21 0x13000000~0x13FFFFFF] 14:05:10 : Data Size: 0x01000000 Bytes 14:05:10 : SHA-256 : 29B7A8D8A82192601FB7A3A852D7360B 14:05:10 : ---------- : EBCE5B91441788248C5F65F0CCDE1F87 14:05:18 : Status : WPOS WRITE SUCCESS 14:05:18 : [BLOCK 22 0x14000000~0x14FFFFFF] 14:05:18 : Data Size: 0x01000000 Bytes 14:05:18 : SHA-256 : 74E2702FEE154C03086607AB42EFFFAB 14:05:18 : ---------- : 31AA7AD753F3037191D8E25C4DE6C66C 14:05:26 : Status : WPOS WRITE SUCCESS 14:05:26 : [BLOCK 23 0x15000000~0x15FFFFFF] 14:05:26 : Data Size: 0x01000000 Bytes 14:05:26 : SHA-256 : 9528D9FBA8EFC0DAA6BA9D4FD6DC9341 14:05:26 : ---------- : 34096DC04ACABAE40D074E9E1E4A8977 14:05:35 : Status : WPOS WRITE SUCCESS 14:05:35 : [BLOCK 24 0x16000000~0x16FFFFFF] 14:05:35 : Data Size: 0x01000000 Bytes 14:05:35 : SHA-256 : 4BB09CA48C99F70BF70DE1D034C54F44 14:05:35 : ---------- : 5350E7B87CE5262F3EF7007387656354 14:05:43 : Status : WPOS WRITE SUCCESS 14:05:43 : [BLOCK 25 0x17000000~0x17FFFFFF] 14:05:43 : Data Size: 0x01000000 Bytes 14:05:43 : SHA-256 : D4601ECDDC3F979FB74FDFAA6D6CEEB4 14:05:43 : ---------- : 942C32A32B955E8008DED43CAC148DF5 14:05:52 : Status : WPOS WRITE SUCCESS 14:05:52 : [BLOCK 26 0x18000000~0x1847EBFF] 14:05:52 : Data Size: 0x0047EC00 Bytes 14:05:52 : SHA-256 : BFB938EEEC4ADA657FEF8CE87B1CC8C3 14:05:52 : ---------- : 943E7A058FBCCD16259CEAEA51FAE648 14:05:55 : Status : WPOS WRITE SUCCESS 14:05:55 : 14:05:55 : Sending USER AREA ERASE Certificate 14:05:55 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 14:05:55 : Certificate Size: 396 Bytes 14:05:55 : Status : WRITE ERASE CERTIFICATE SUCCESS 14:05:55 : 14:05:55 : Erasing USER AREA 14:06:25 : Status : ERASE SUCCESS 14:06:28 : 14:06:28 : Flashing Done! 14:06:28 : Total Flashing Time (Erase + Flashing) : 00:04:33 but same |
