all box not activated - look inside asap : CLOSED Hi, On May 20, 2014 our ACTIVATION SERVER had a small database corruption and we have since then FULLY Restored it. However, if you are still experiencing Box Activation Problems after updating your firmware to LogiCore 11.0.00 or ATF Software 11.xx and above, please: 1. POST FULL BOX SN Here 2. Post Date of when you Updated your Box Firmware There is NO NEED TO PANIC. I will solve your ACTIVATION Problem and you DO NOT NEED TO CONTACT YOUR RESELLER. Just give me Info 1 and 2 as I require above. B.R. |
seiral number ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 10.3.80 Software Version : v10.20 AdvanceBox SN : F65644E9A4B745BAE758CDAA Box Status : NOT ACTIVATED i think that was 2014/5/22 ================================================ Box Successfully Initialized ================================================ |
hi Driver Version : 00020830 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : C9E01798B284F824841C3A6F Box Status : NOT ACTIVATED thx |
please ATF box not activated Advance Turbo Flasher Found Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : 872AFB0DF8B7B857AC8FD9A8 |
Br - srinibas |
Br - srinibas |
excuseme for posting again i tested two times but not activated ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : F65644E9A4B745BAE758CDAA Box Status : NOT ACTIVATED 2014/5/22 or 23 |
Driver Version : 00020416 Library Version : 00030118 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : CECA77CF80B22104C863E0EA Box Status : NOT ACTIVATED |
================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : D8925374C2A34349DDDC2AFB Box Status : NOT ACTIVATED ================================================ Please Activate your Box ================================================ * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Fill in the Required Information 5. Click "Activate Box" button ================================================ Box Successfully Initialized ================================================ date 21/05/2014 |
hi im alibagheri help============================================== == Advance Turbo Flasher Found ================================================ Driver Version : 00020416 Library Version : 00030118 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : FA3B7527EF721F47B1178967 Box Status : NOT ACTIVATED data 2014/05/23or2014/05/25 tank you |
hi Driver Version : 00020422 Library Version : 00030119 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : D1A0FE21BBD80C41AB6289FE Box Status : NOT ACTIVATED tank you |
Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : 84E6FDF48B55603BC58F1AE6 Box Status : NOT ACTIVATED ================================================ Please Activate your Box ================================================ |
hi Please Activate your Box Driver Version : 00020422 Library Version : 00030119 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : D1A0FE21BBD80C41AB6289FE Box Status : NOT ACTIVATED tank you 2014/05/23 or 24 |
