<<<< ALL Samsung eMMC Direct Test Points .mmc Files >>>> Phone Model: SM-G7102 (Galaxy Grand 2) CPU: MSM8226 eMMC Size: 8GB eMMC BOOT Repair 4.4.2 G7102DXUBNH1 SM-G7102_4.4.2_G7102DXUBNH1.mmc Test Point Picture (ONLY 4 Wires + USB Cable): http://174.120.45.27/tmp/SAMSUNG_SM-G7102_EMMC_TP.jpg |
sir how to use this procedure......pls explain 1. if this file is to use as sdc file thn why we need to jumpering wires... 2. if we have to solder these wires thn r we to work as emmc write method ????? |
@mobirepair This is for demonstration Purposes only (just for blah blah...). ALL SM-G7102 can be FIXED using SDC Unbrick Method. (YOU DO NOT NEED eMMC Direct Method from post #1) Even if you remove eMMC from Phone PCB, phone will still BOOT UP via SD CARD. I just put this here because I bought this phone and I took nice pictures of it... and I don't want to waste the effort I made. .mmc Files need to open it via ATF Plus -----> eMMC Tool After you load it there, all will be automatic. B.R. P.S. Easier Method (SDC Ubrick) can be found here: http://forum.gsmhosting.com/vbb/10584791-post8.html You do not need to OPEN Phone, unless phone does not respond to SD Card... |
I need i747 have 2 qusb load |
@hactek 16GB or 32GB ? Please create new POST and do not hi-jack this thread. I will help you, but just create new POST. |
need i9082 pin out and mmc file Dear atf supporter tnx for usefull post about g7102 its very good.but now i looking for i9082 emmc pin out and repair file for atf please can share it or can tell me any link.....plzzz |
anjuman bro...why not u try sdc method....very easy |
dear sir where is all samsung emmc direct via vire for i9300 Samsung eMMC Direct Test Points .mmc Files |
Br allumts |
Read more here: http://forum.gsmhosting.com/vbb/10584791-post8.html BR allumts |
need i9515 tp pic........ |
Sm-g900f Hi, Does anyone have the .mmc file for the samsung G900F (S5)? i need the picture of the test points! Thank you |
@abcd9 Why hi-jack bthread of other members?, open you thread and have all aswere you want. For you proble, Use "ATF SUPPORT AREA", put this in the PREFERED and first of ask search inside this, use search button always, last time atfsupport.com BR allumts |
