Atf 11.10 not working after update ATF 11.10 AFTER INSTALL NOT WORKING PROBLEM I HAVE 3 TIME REMOVE AND UNISTAAL DRIVER AFTER UPDATE SOFTWARE AND RESTORE BOX BUT SAME STILL PROBLEM >>>>PLZZ SOLVE MY PROBLEM>>>> ::::::::::::::::::::::::::::::::::>>>>>>>>>>>>>>>> >>>>>>:confused: Please update your Box Firmware ============================================== * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Click "Update Firmware" button * Make sure you put ATF Software in Windows FireWall Exclusion List * Make sure you put ATF Software in your Virus Scanner Exclusion List ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
Contact me on sonork Br - srinibas |
I have same problem shine star electronics |
Make sure you put AdvanceBox.exe into your Windows Firewall Exception List. BR |
i also in the same problem, but after i press stop then can use like normal.. is there got other solution to solve it? my computer don have anti virus and i already add ATF to Exception List still not working normally.. thankyou |
Until Solved I Dont Buy It! ATF Nitro Until Solved I Dont Buy It! ATF Nitro!! I really need it but If the Team dont make a solution soon then Ill have to make another selection. BRs, LDAR |
Atf 11.10 is not perfect.....so...guys you have to uninstall any version first....then install v11.00.....then you update with version 11.10.... This will solve most of the problems....try it |
Sir, i uninstall ATF and driver and install v11.10 by auto update. ATF exe run normally if i disconnect usb from box and connect box again and run ATF exe its not open. task manager show atf not responding. if i click End process its not ending from desktop. after restart pc same problem. i format pc and direct install v11.10 and update important files and add ATF exe to AV exception list but the problem same. i use MSE antivirus and xp sp-2. how can solve this problem? |
That happened to me also....that's why i said.......u uninstall any versions from pc then INSTALL V11.....THEN INSTALL V11.10 VERSION OVER IT.......follow the instructions.. |
i am also facing this problem. i downloaded full installer and installed it but when i open atf there is nothing. look it---- http://imageshack.com/a/img34/1863/dleg.png |
