Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
View Poll Results: Did ATF 9.40 "SKINLESS EDITION" Solved "Access Violation" Problems ???
YES IT WORKS - Even without Disabling Skins in Settings 45 54.88%
YES IT WORKS - After I Disabled Skin in Settings 12 14.63%
YES IT WORKS - But I never had problems with 9.00 to 9.40 at all 15 18.29%
STILL PROBLEMS - I am still getting "Access Violation" 10 12.20%
Voters: 82. You may not vote on this poll
Old 12-25-2012, 14:37   #1 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
ATF 9.40 "SKINLESS EDITION" Test Results
Did you get Random Access Violation on ATF 9.00 upto 9.40 ???
Try the new 9.40 "SKINLESS EDITION" via the ATF AutoUpdate Server and
post your results here...
B.R.
The Following 14 Users Say Thank You to Advance-Box For This Useful Post:
Old 12-25-2012, 15:04   #2 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
B.R.
I Still Have This Error Plz Help Me
The Following User Says Thank You to shoaibrao For This Useful Post:
Old 12-25-2012, 15:07   #3 (permalink)
Member: 651945
@shoaibrao
Give me TeamView ID Pass in PM...
Your problem is different, it is not "Access Violation"
Yours is "Access is denied"
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 12-25-2012, 15:23   #4 (permalink)
FayGsmDz's Avatar
Member: 274054
Thanks Meter: 400
My Box Work Fine With Last FW
we have not any problem
The Following User Says Thank You to FayGsmDz For This Useful Post:
Old 12-25-2012, 15:32   #5 (permalink)
Member: 651945
@husainsarfraz
NOD32 will always say virus on packed+protected EXE files...
Nothing new...
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 12-25-2012, 15:33   #6 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
http://postimage.org/image/c4d8vkhxn/
wbr ; tejaram
The Following User Says Thank You to .::TEJARAM::. For This Useful Post:
Old 12-25-2012, 15:41   #7 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
Thanks To X-Shadow
After Updating Again With The Help Of My Respected Sir X-Shadow On Team Viewer My Problem Solved
Now Working Well
Thanks Again To Sir X-Shadow
Old 12-25-2012, 15:45   #8 (permalink)
Member: 619982
Thanks Meter: 6
Thanks To X-Shadow
Now Working Well
i had also same problem. plz tell me what to do?
Thanks
Old 12-25-2012, 15:49   #9 (permalink)
Member: 651945
@taturi1
AutoUpdate Again.. Fix already uploaded to server
Old 12-25-2012, 16:04   #10 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Subhadeep & dragosgsm
What problem you have ? Post in detail or contact me on SONORK
Br - srinibas
Old 12-25-2012, 16:17   #11 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
hi
my "Access is denied" problem solved by disable skin
but still some usb flashing problem is there
i faced usb flashing problem in C5-03 and N8 and e52
please chk it
Old 12-25-2012, 16:22   #12 (permalink)
Member: 651945
@rajiv007
It is flashing OK ...
Number of Image Files: 4
Processing Image File :
 RM-779_113.010.1506_79u_prd.core.fpsx
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed    : 650000Hz
Algorithm Sending Speed    : 6500000Hz
Program Sending Speed      : 13000000Hz
Message Reading Speed      : 98000Hz
Number of Blocks :  587
Entry Point:  0x0272
Page Format : -1
MAX PAGE : 0x00040000
 RM-779_113.010.1506_C07.01_UK_79u_prd.rofs3.fpsx
CMT Type : BB5
Number of Blocks :  8
Entry Point:  0x0153
Page Format : -1
MAX PAGE : 0x0000D800
 RM-779_113.010.1506_01.01_Euro_1_79u_prd.rofs2.fpsx
CMT Type : BB5
Number of Blocks :  321
Entry Point:  0x014B
Page Format : -1
 RM-779_113.010.1506_U01.01_79u.uda.fpsx
CMT Type : BB5
Number of Blocks :  781
Entry Point:  0x014B
Page Format : -1
[]: Found 1 active devices.
[Nokia 603 USB Phonet]: Opening Connection
[Nokia 603 USB Phonet]: Port opened OK!
SW: V 79u_sr2_12w20.8 20-08-12 RM-779 (c) Noki
IMEI: 358647040584720
CONFIG KEY    :  0000000000000000
PROVIDER KEY  :  2440700000000000
NETWORK NAME  :  Nokia Default;Finland
LOCK COUNTERS :  KEYPRESS 0/3,  FBUS 0/10
SIMLOCK TABLE :
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE :  Not Locked
 START FULL PM BACKUP
Please Wait...
Reading : PM 0~400... OK!
 FULL PM Backup Saved to:
 C:\AdvanceBox Application_NEW\Nokia\Backup\358647040584720\USB_FULL_BACKUP_V 79u_sr2_12w20.8 20-08-12 RM-779 (c) Noki_358647040584720_Not Locked_72123.pm
Reading Battery Value  : 3856 mV
Rebooting Phone...
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96  (0x60) bytes returned
Number of Sub Blocks 7 (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000003
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00010007
     ID DWORD    3 : 400C1921
     ID DWORD    4 : 03032108
  2  EM_ASIC_ID 02
     Block Length  : 5  (05)
     ID DWORD    0 : 00001040
  3  EM_ASIC_ID 02
     ID DWORD    0 : 00001060
  4  PUBLIC_ID 12
     ID DWORD    0 : 14710000
     ID DWORD    1 : FFFB3C40
     ID DWORD    2 : 1EB7A681
     ID DWORD    3 : 66A68102
     ID DWORD    4 : 3753C54E
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 2CAC45E2
     CRC         1 : 3BC33C8B
CMT Secondary Loader: C:\AdvanceBox Application_NEW\Nokia\BB5_Loader\New\RAPUv21_2nd.fg
Secondary Loader Sent....
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> Type not in database
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Revision ID       : 0000
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0000 -> SPANSION
   Device ID         : 0001 -> Type not in database
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Manufacturer Code : 00EC ->
   Device ID         : 0060 -> Type not in database
   Revision ID       : 0032
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              : XSR 1.6
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Flash Descriptor
   Device ID         : 0060
   Revision ID       : 0000
   Size              : 40000000 (1024 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
CMT Algorithm Loader: C:\AdvanceBox Application_NEW\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
 START READING RPL DATA
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
Reading : PARTNERC... OK!
NPC CERTIFICATE INFORMATION (CMT):
IMEI           : 358647040584720
PRODUCT CODE   : 059L9V2
WLAN ID        : 9C:CA:D9:D9:21:D4
BLUETOOTH ID   : 9C:CA:D9:D9:12:34
PUBLIC_ID      : 14710000FFFB3C401EB7A68166A681023753C54E
PAPUB_KEYS_HASH: BC8F5330DDAE68D572ADF62FA254EB9EA2EEF364
CCC CERTIFICATE INFORMATION (CMT):
HWC CERTIFICATE INFORMATION (CMT):
RPL Backup was Successful...
 Plain RPL saved to:
 C:\AdvanceBox Application_NEW\Nokia\Backup\358647040584720\358647040584720_72131.rpl
PA PUBLIC KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
  PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index   : 00
CMT PAPUBKEYS HASH:
ImagePath: C:\Nokia Firmware\RM-779\
ImageFilename: RM-779_113.010.1506_79u_prd.core.fpsx
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
Certificate 5
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 50 41 52 54 4E 45 52 43 00 00 00 00 00 3B
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
PARTITION_INFO_REQUEST_BB5 : 64012F5F00030000020000FFFFFFFF0000000500000003000000020014000002DA0000000000040000000202EE0000142200000000000800000001171000001700000000000027000000012E100000105000000000000A000000013E6000000040000053
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength  :  0x57  (87)
ERASE Blocks :  0x02  (2)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x23 (35)
            BB ASIC Index    : 0x00 CMT
            Device Type      : 0x03 MuxOneNAND
            Device Index     : 0x00
               0             : 00040000-0007FFFF
               1             : 000C0000-008BFFFF
               2             : 010C0000-170FFFFF
               3             : 2E100000-3E5FFFFF
     1   FORMAT_PARTITION_BB5 0x19
            Block Length     : 0x2F (47)
            Device Index     : 0x00
            Format Info ID   : 0x03000000
            Format Info      : 000000000000000A0000000000000002000000640018000000000002000000010000000000000000
ERASE_REQUEST_BB5  : 5004120B000300000400000007FFFF120B000300000C0000008BFFFF120B000300010C0000170FFFFF120B0003002E1000003E5FFFFFD3
FORMAT_REQUEST_BB5 : 5001192F00030000000003000000000000000A000000000000000200000064001800000000000200000001000000000000000025
Successfully Erased...
Total blocks to write : 587
>>  CMT Rootkey Hash CERT : ADA
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : RAP3NAND
>>  CMT Rootkey Hash CERT : SOS+PMML
>>  CMT Rootkey Hash CERT : SOS+DECOMP
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS [BC8F5330DDAE68D572ADF62FA254EB9EA2EEF364]
>>  CMT Rootkey Hash CERT : GENIO_INIT
>>  CMT Rootkey Hash CERT : SOS+IVE3A
>>  CMT Rootkey Hash CERT : SOS*UPDAPP
>>  CMT Rootkey Hash CERT : SOS*DSP0
>>  CMT Rootkey Hash CERT : LDSP
>>  CMT Rootkey Hash CERT : SOS*ISASW
>>  CMT Rootkey Hash CERT : SOS+CORE
>>  CMT Rootkey Hash CERT : SOS+ROFS1
ImageFilename: RM-779_113.010.1506_C07.01_UK_79u_prd.rofs3.fpsx
StartErase_DCT5...
BlockLength  :  0x16  (22)
ERASE Blocks :  0x01  (1)
            Block Length     : 0x13 (19)
            Device Index     : 0x00
               0             : 01678000-0169FFFF
               1             : 135C0000-170FFFFF
ERASE_REQUEST_BB5  : 5002120B000300016780000169FFFF120B000300135C0000170FFFFFDA
Total blocks to write : 8
>>  CMT Rootkey Hash CERT : SOS+ROFS3
>>  CMT Rootkey Hash CERT : SOS+IVE3B
ImageFilename: RM-779_113.010.1506_01.01_Euro_1_79u_prd.rofs2.fpsx
StartErase_DCT5...
BlockLength  :  0x0E  (14)
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 0D1C0000-135BFFFF
ERASE_REQUEST_BB5  : 5001120B0003000D1C0000135BFFFF49
Total blocks to write : 321
>>  CMT Rootkey Hash CERT : SOS+ROFS2
ImageFilename: RM-779_113.010.1506_U01.01_79u.uda.fpsx
StartErase_DCT5...
            Device Index     : 0x00
               0             : 17100000-2E0FFFFF
ERASE_REQUEST_BB5  : 5001120B000300171000002E0FFFFF7C
Total blocks to write : 781
ContinueFlash_DCT5 Complete
Continue Flash Complete :  : No Error - 0 (0x00)
STATUS_REQUEST_BB5...
1  Sub Block ID      : 15 STATUS_NAND_OK_BB5
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Num Bad Blocks    :  00000002
          Additional Bad    :  00000002
          Correctable ECC   :  00000000
FlashInfo.RestartMode : 1
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:49
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
SIMLOCK TABLE :
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SUPER_DONGLE_TEST  : PASSED
               SL3 Phone detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
FACTORY SET TO : Full Factory Set
 OK
FACTORY SET TO : User Data
 OK
FACTORY SET TO : Leave Factory
 OK
FACTORY SET TO : Service Center
 OK
FACTORY SET TO : Software Upgrade
 OK
FACTORY SET TO : Production Tune
 OK
RESET LIFE TIMER TO : 0000:00
 OK
Old 12-25-2012, 16:38   #13 (permalink)
jaan G's Avatar
Member: 1438545
Sonork: 100.1610062
Thanks Meter: 49
still prb...........
The Following User Says Thank You to jaan G For This Useful Post:
Old 12-25-2012, 18:02   #14 (permalink)
Registered User
Member: 65987
Thanks Meter: 45
Old 12-25-2012, 20:45   #15 (permalink)
mastersgsm's Avatar
Member: 1470188
Sonork: 100.1638921
Thanks Meter: 88
THANK YOU VERY MUCH!!! MY PROBLEM SOLVED after update, without disable skins!!! GOOD LUCK!!! BEST ATF IN BEST UPDATES!!!!
Page generated in 0.31630 seconds with 11 queries
