Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 01-05-2014, 10:11   #1 (permalink)
Member: 714722
Thanks Meter: 33
Help lumia 800 boot change - [SOLVED]
emmc boot information
boot partition : User area
partition access : R/w user partition
perm_boot_cfg_prot: Disabled
pwr_boot_cfg_prot : Disabled
emmc firmw update : Disabled
lumia 800/800c detected
emmc device information
manufacturer id: Hynix
device type : Embedded bga
application id : 4a
product name : Hynix
product rev : 5.12
product sn : 008cb6b6
manufactured : January 2011
card specific data
csd_structure : Extended
spec_vers : Version 4.1/4.2/4.3
taac : 300 ns
trans_speed : 4000000 khz
read_bl_len : 512 bytes
c_size : High capacity
wp_grp_enable : Yes
write_bl_len : 512 bytes
content_prot_app : No
perm_write_protect: No
tmp_write_protect : No
writing mbr...
Write success!
Writing dbl...
Error: Block write failed at 0x00000004
check your test point soldering!
Error: Write failed!
Total elapsed time 00:00:01
please how to fix that thanks
Old 01-06-2014, 02:06   #2 (permalink)
Member: 2054979
check your test point soldering 检查一下你的测试点
Old 01-06-2014, 09:12   #3 (permalink)
Member: 714722
Thanks Meter: 33
all is ok please wheris the probleme i'am not activate the jtag in my atf i yhink not important for do that and i'am anew user of atf i havan't mor experiance oi it and i need to change the boot to quelqom dload
thanks for help
Old 01-06-2014, 10:58   #4 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
You do not need Test Points to change boot loader. It can be now done via USB cable:
http://forum.gsmhosting.com/vbb/f609...steps-1580402/
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 01-07-2014, 10:00   #5 (permalink)
Member: 714722
Thanks Meter: 33
AND WHAT ABOUT YOUR THIS POST HER
http://forum.gsmhosting.com/vbb/9004471-post6.html
THANKS
Old 01-07-2014, 10:34   #6 (permalink)
Member: 643472
Sonork: 100.96901
THANKS
Hi, that is 100% right what I written in my post. The only problem is, that was my old post: 10th Dec 2012, 03:30 PM, that time we were NOT supporting this phone via USB and now we do.
Old 01-07-2014, 14:17   #7 (permalink)
Member: 714722
Thanks Meter: 33
but the phone it dead now after playing withe test point repair and not conected by usb and volume up and i have bay the atf nitro please it need to do this modification or no For ATF Nitro, you need some small modification to give Power to eMMC socket via RJ-45 PIN 2 (the pin beside VBATT PIN 1). Needless to say, if you modify your Nitro Box, you will loose warranty. So just decide for yourself if you need to modify or you want to buy external power supply instead. Anyway, here is modification needed, just look at light blue encircled area... you will see a very thin wire connected to PIN 2 of RJ-45.
thanks for help
Old 01-08-2014, 10:34   #8 (permalink)
Member: 643472
Sonork: 100.96901
Hi, Your box does not need any modification. Repair Boot to alive phone again, since it was stopped during Boot Change because of BAD SOLDERING.
Old 01-13-2014, 10:26   #9 (permalink)
Member: 714722
Thanks Meter: 33
please i need to active jtag to my box to worck on dead boot repair or not
thanks for help
Old 01-13-2014, 10:30   #10 (permalink)
Member: 643472
Sonork: 100.96901
thanks for help
Hi, JTAG requires to repair ALL Lumia Phones Boot via JTAG and ATF Software
repairs Boot via eMMC - both are different, lumia 710/ 800 does not requires
ATF JTAG. But for all the rest of lumia, JTAG is needed for JTAG Boot Repair.
Page generated in 0.23965 seconds with 8 queries
