06-10-2016, 14:37 | #422 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1838049 Status: Offline Thanks Meter: 3 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : EFDAA3A785208016A09B1B57 Box Status : NOT ACTIVATED ================================================ Please Activate your Box ================================================ * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Fill in the Required Information 5. Click "Activate Box" button ================================================ Box Successfully Initialized ================================================ Last edited by delgadito; 06-10-2016 at 14:41. Reason: http://s33.postimg.org/9xtjh8cjj/Untitled.jpg |
07-17-2016, 23:50 | #424 (permalink) |
Junior Member Join Date: Jul 2016 Location: Utardia Age: 45
Member: 2599646 Status: Offline Thanks Meter: 0 | Microsoft Lumia 640 RESET PROTECT ISSUES Windows Phone Reset Protection account and key not functioning correctly. Microsoft Lumia 640, imei: 357816066438209. Ive seen that using an imei number and win phone dev account on the wpdev site works to disable or get reset protection key but for some reason my dev account is unouthorized..can soneone help me |
03-10-2017, 05:32 | #425 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2367936 Status: Offline Thanks Meter: 0 | Here. i have the same problem. A new activation request is required after reinstalling windows. Everythings fine with older version i.e., 8.90. But a new version has a problem..i need help ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : 9D4A5522945FDA96B1AD861E ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
03-10-2017, 06:15 | #426 (permalink) |
Junior Member Join Date: Feb 2012 Location: iran
Member: 1726235 Status: Offline Thanks Meter: 0 | Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : 992EDA82C57744F29B967A1A ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software Helllllppppppppppppp |
03-11-2017, 11:35 | #429 (permalink) |
Junior Member Join Date: Jan 2009
Member: 955969 Status: Offline Thanks Meter: 1 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : FA546C219E4BC486C9C0D2D2 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
03-12-2017, 12:16 | #431 (permalink) |
Junior Member Join Date: May 2012
Member: 1757318 Status: Offline Thanks Meter: 0 | plz help ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021224 Library Version : 00030212 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : 19F6F37A8DE032F7EA936FED Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ERROR: Invalid Reply Detected... 0xA0 |
03-12-2017, 15:13 | #432 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: Đà Nẵng - Việ Age: 44
Member: 1911593 Status: Offline Sonork: 100.1645151 Thanks Meter: 130 | I have the same problem. Team pls help me ! Quote:
03-12-2017, 17:36 | #433 (permalink) |
Major Poster Join Date: Jan 2008 Age: 51
Member: 669066 Status: Offline Thanks Meter: 1 | Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : B10F3253E6104683FDD498F1 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done LOGIN TO YOUR ATF NETWORK ACCOUNT INVALID RESPONSE [email protected] |
03-12-2017, 18:19 | #434 (permalink) |
Member: 669066 Status: Offline Thanks Meter: 1 | 17:45:20 : BootFlashModeDCT5Ex Succeeded after 4 Attempts 17:45:20 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 17:45:20 : Number of Sub Blocks 12 (0x0C) 17:45:20 : 1 SYSTEM_ASIC_ID 01 17:45:20 : Block Length : 5 (05) 17:45:20 : BB ASIC Index : 1 (01) APE 17:45:20 : ID DWORD 0 : 17100708 17:45:20 : 2 ASIC_MODE_ID 13 17:45:20 : Block Length : 2 (02) 17:45:20 : BB ASIC Index : 1 (01) APE 17:45:20 : Mode Id : 00 17:45:20 : 3 PUBLIC_ID 12 17:45:20 : Block Length : 21 (15) 17:45:20 : BB ASIC Index : 1 (01) APE 17:45:20 : ID DWORD 0 : 219DAB3D 17:45:20 : ID DWORD 1 : A37197B4 17:45:21 : ID DWORD 2 : CD5AA30E 17:45:21 : ID DWORD 3 : 8F479555 17:45:21 : ID DWORD 4 : 2E3FCB30 17:45:21 : 4 ROOT_KEY_HASH 14 17:45:21 : Block Length : 21 (15) 17:45:21 : BB ASIC Index : 1 (01) APE 17:45:21 : Hash : 49 A9 7E 82 6B 93 BA 20 B7 ED 0B 08 24 75 C0 05 00 00 00 00 17:45:21 : 5 ROM_ID 15 17:45:21 : Block Length : 9 (09) 17:45:21 : BB ASIC Index : 1 (01) APE 17:45:21 : CRC 0 : 1DFD6613 17:45:21 : CRC 1 : 2C872FD4 17:45:21 : 6 SYSTEM_ASIC_ID 01 17:45:21 : Block Length : 21 (15) 17:45:21 : BB ASIC Index : 0 (00) CMT 17:45:21 : ID DWORD 0 : 00000001 17:45:21 : ID DWORD 1 : 00000226 17:45:21 : ID DWORD 2 : 00010006 17:45:21 : ID DWORD 3 : 010C1921 17:45:21 : ID DWORD 4 : 01003000 17:45:21 : 7 EM_ASIC_ID 02 17:45:21 : Block Length : 5 (05) 17:45:21 : BB ASIC Index : 0 (00) CMT 17:45:21 : ID DWORD 0 : 00000295 17:45:21 : 8 EM_ASIC_ID 02 17:45:21 : Block Length : 5 (05) 17:45:21 : BB ASIC Index : 0 (00) CMT 17:45:21 : ID DWORD 0 : 00000B22 17:45:21 : 9 PUBLIC_ID 12 17:45:21 : Block Length : 21 (15) 17:45:21 : BB ASIC Index : 0 (00) CMT 17:45:21 : ID DWORD 0 : 1AD00110 17:45:21 : ID DWORD 1 : E0A65750 17:45:21 : ID DWORD 2 : 0D9E6EC8 17:45:21 : ID DWORD 3 : FF946A1D 17:45:21 : ID DWORD 4 : 0720E16A 17:45:21 : 10 ASIC_MODE_ID 13 17:45:21 : Block Length : 2 (02) 17:45:21 : BB ASIC Index : 0 (00) CMT 17:45:21 : Mode Id : 00 17:45:21 : 11 ROOT_KEY_HASH 14 17:45:21 : Block Length : 17 (11) 17:45:21 : BB ASIC Index : 0 (00) CMT 17:45:21 : Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 17:45:21 : 12 ROM_ID 15 17:45:21 : Block Length : 9 (09) 17:45:21 : BB ASIC Index : 0 (00) CMT 17:45:21 : CRC 0 : 273F6D55 17:45:21 : CRC 1 : DFAAF68F 17:45:21 : Checksum 66 17:45:21 : 17:45:21 : SearchForBootstrap_DCT5.. 17:45:21 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAP3Gv3_2nd.fg 17:45:21 : Boot File - Version 01.030.00 17:45:21 : Boot File - Revision 0x0000 (0) 17:45:21 : eBB5ProtocolType == Original 17:45:21 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 17:45:21 : Secondary Loader Sent... 17:45:21 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 17:45:21 : MCU_CONFIGURATION_RESPONSE_BB5: 17:45:22 : MessageID : 03 17:45:22 : SubBlocks : 03 17:45:22 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 17:45:22 : Block Length : 0B 17:45:22 : BB ASIC Index : CMT 00 17:45:22 : Device Type : NOR 00 17:45:22 : Device Index : 00 17:45:22 : Manufacturer Code : 00EC -> 17:45:22 : Device ID : 22E8 -> K5G2829ATC 17:45:22 : Extended/Fixed ID : 0000 17:45:22 : Revision ID : 6921 17:45:22 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 17:45:22 : Block Length : 13 17:45:22 : BB ASIC Index : CMT 00 17:45:22 : Device Type : NOR 00 17:45:22 : Device Index : 00 17:45:22 : Device Contents : 00000000000000000000 17:45:22 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 17:45:22 : Block Length : 0B 17:45:22 : BB ASIC Index : CMT 00 17:45:22 : Device Type : MMC 04 17:45:22 : Device Index : 00 17:45:22 : Manufacturer Code : FFFF -> Flash 17:45:22 : Device ID : 0000 -> BAD FLASH TYPE 17:45:22 : Extended/Fixed ID : 0000 17:45:22 : Revision ID : 0000 17:45:22 : Checksum : 20 17:45:22 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 17:45:22 : FLS1SendAlgoCodeEx.. 17:45:22 : SendAlgoCode_DCT5.. 17:45:22 : SearchForAlgorithm_DCT5.. 17:45:22 : Looking for ALL Devices... 17:45:22 : Searching Algorithm Files NOR (00) ManID :00EC DevID :22E8 ExtID :0000 RevID :6921 17:45:22 : Flash Descriptor 17:45:22 : Manufacturer Code : 00EC 17:45:22 : Device ID : 22E8 17:45:22 : Extended/Fixed ID : 0000 17:45:22 : Revision ID : 0000 17:45:22 : Size : 01000000 (16 MB) 17:45:22 : VPP Info : 0009 17:45:22 : Erase10s : 28 17:45:22 : Block1s : 32 17:45:22 : BErase1s : 02 17:45:22 : Reserved0 : 00 17:45:22 : Reserved1 : 00 17:45:22 : Reserved2 : 00 17:45:22 : VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK 17:45:22 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAP3Gv3_algo.fg 17:45:22 : Algorithm File - Version 01.040.00 17:45:22 : Algorithm File - Revision 0x0000 (0) 17:45:22 : eBB5ProtocolType == Original 17:45:22 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00) 17:45:22 : TransmissionTypeRequest_DCT5... 17:45:22 : SuggestedType : 01 16BIT 17:45:22 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC 17:45:22 : ReturnedType : 01 16BIT 17:45:22 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 17:45:22 : 17:45:22 : Uploading ALGO File... 17:45:22 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 17:45:22 : PAPUB_KEYS_HASH_REQ_BB5 17:45:22 : PhoneInfoRequest_BB5 (Asic Index 00 ) 17:45:22 : PHONE_INFO_RESPONSE_BB5 17:45:23 : PAPUB_KEYS_HASH_RESP_BB5 2A 17:45:23 : BB Asic Index : 00 17:45:23 : CMT PAPUBKEYS HASH: 17:45:23 : 5E8D0D504A0902E261268C14FCD8A2C9093523BC 17:45:23 : 17:45:23 : 17:45:23 : Scanning Simlock Applet Type... 17:45:26 : OK 17:45:26 : 17:45:26 : ================================================= 17:45:26 : SL1/SL2 Applet detected 17:45:26 : ================================================= 17:45:26 : 17:45:27 : 17:45:27 : Waiting for Phone to Go Online... 17:45:28 : Elapsed Time: 1s 17:45:29 : Elapsed Time: 2s 17:45:30 : Elapsed Time: 3s 17:45:31 : Elapsed Time: 4s 17:45:32 : Elapsed Time: 5s 17:45:33 : Elapsed Time: 6s 17:45:34 : Elapsed Time: 7s 17:45:35 : Elapsed Time: 8s 17:45:36 : Elapsed Time: 9s 17:45:37 : Elapsed Time: 10s 17:45:37 : 17:45:37 : ================================================ 17:45:37 : Basic Phone Information 17:45:37 : ================================================ 17:46:45 : 17:46:45 : 17:46:45 : ================================================ 17:46:45 : ATF SOFTWARE IS NOT ACTIVATED ON THIS PC 17:46:45 : Please Activate your ATF Software 17:46:45 : ================================================ 17:46:45 : 17:46:45 : * Follow these Instructions 17:46:45 : 1. Connect this PC to the INTERNET 17:46:45 : 2. Restart ATF Software |
03-17-2017, 11:22 | #435 (permalink) |
Junior Member Join Date: Dec 2013 Location: Sarajevo
Member: 2092531 Status: Offline Thanks Meter: 0 | please help urgent Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : CD44083AA46EA3DBCDF721D3 Box Status : NOT ACTIVATED ================================================ Please Activate your Box ================================================ * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Fill in the Required Information 5. Click "Activate Box" button ================================================ Box Successfully Initialized box activation problems????? |
Box activation problems, please post here | trieubk | BB5BOX | 421 | 02-25-2010 10:51 |
UFS/TWISTER Old and New Activations Key Here | Paki Mobile | UFS2 + UFS3-Tornadoflasher | 605 | 08-05-2005 22:01 |
Netmonitor Activation Software **HERE*** | chipi | x1x to x45/x50 | 29 | 09-10-2002 01:31 |
