07-22-2016, 11:10 | #1 (permalink) |
Freak Poster Join Date: Feb 2016 Location: karnataka, mysore
Member: 2528503 Status: Offline Sonork: 1670792 Thanks Meter: 70 | nokia windows 610 network unlock done with atf jtag wow,..... 1. Make sure JTAG Connection is 100% OK 2. DO NOT Connect a USB Cable to the phone 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect Phone BATTERY and POWER ON the Phone 5. Wait until WP7 OS is FULLY LOADED showing Main Menu 6. Check that Phone IMEI is valid via *#06# 7. If IMEI is valid, Click READ CODES button then wait... ---------------------------------------------------------- Initializing Connection Connected 1 device(s)! Halting Core... Halted Device 0x106210E1 Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN LEVEL 1: 44621311 - LOCKED PUK LEVEL 1: 19513304 - LOCKED PIN LEVEL 2: 14981534 PUK LEVEL 2: 83746145 PIN LEVEL 3: 63233438 PUK LEVEL 3: 26481049 PIN LEVEL 4: 99958631 PUK LEVEL 4: 64697847 PIN LEVEL 5: 68853818 PUK LEVEL 5: 30943690 ========================= Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== All Done! yeah .... |
