03-03-2017, 07:35 | #1 (permalink) |
Freak Poster Join Date: Feb 2016
Member: 2528233 Status: Offline Thanks Meter: 20 | Atf box error Server busy Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.60 AdvanceBox SN : D57699DCA2901DEAE8E57052 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done plz hlp |
03-04-2017, 04:53 | #2 (permalink) | |
Insane Poster Join Date: Jul 2006 Location: globaltechno45.wordpress.com
Member: 307235 Status: Offline Thanks Meter: 10 | Quote:
03-04-2017, 12:20 | #4 (permalink) |
Crazy Poster Join Date: Apr 2008
Member: 743306 Status: Offline Thanks Meter: 21 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : F40D4943E602777CBDDA6856 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software my ip 103.76.211.89 |
The Following User Says Thank You to rajajls1 For This Useful Post: |
03-10-2017, 06:26 | #6 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1406341 Status: Offline Thanks Meter: 1 | atf Server Probmen solve 10/3/2017 Library Version : 00030210 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.10 Software Version : v12.40 AdvanceBox SN : E303A509F75C91F1B5D39BAC Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= Please Update Important Files Goto "Product Support" tab then Click "Update Files" tab then Click "UPDATE IMPORTANT FILES" button ATF team thank you so much |
07-11-2020, 08:17 | #8 (permalink) |
Junior Member Join Date: Nov 2015 Location: Lahore
Member: 2485337 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020828 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : 6463D17C7BA821F54C823065 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done plz help win7 and win8.1 same problem |
08-26-2020, 20:56 | #10 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2381415 Status: Offline Thanks Meter: 1 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : AEBD2C60AF127427EA72DA62 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
08-26-2020, 21:08 | #11 (permalink) |
Member: 2381415 Status: Offline Thanks Meter: 1 | plz help ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : AEBD2C60AF127427EA72DA62 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
The Following User Says Thank You to akhlak ansari For This Useful Post: |
03-23-2021, 16:03 | #15 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1550235 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020828 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : AA59E63FEB84C5D0D6BC862C ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
