05-28-2015, 14:02 | #32 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | No, after you have read correct all "User Data partition stop selecting from Disk Mounted, loock all "User Data" partition and from this you Copy/paste what is of you interess... Loock the Video for Lumia and understal more good this copy/paste or Post screen when have read "User Data" partition. Not forgot of try always as Admin...i've seen you not use this... BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
05-28-2015, 14:12 | #33 (permalink) | |
Banned Join Date: Nov 2012 Location: unknown
Member: 1837438 Status: Offline Sonork: unknown Thanks Meter: 659 | Quote:
The Following User Says Thank You to habeebkambrath For This Useful Post: |
05-28-2015, 14:27 | #34 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | DRIVE run as admin...you here have issues... Anyway for me you not have watch good the video and Copy/paste method after have read "USER DATA" partition...from you screen is very clear you have Mounted other time Disk and done Full Dump.... for read DATA...read carefully Why you do it..only if want play with .bin file but you have need USER DATA so not mount other time Disk DRIVE and first of another operaction DISMOUNT always Virtual Disk... BR allumts |
07-03-2015, 10:23 | #37 (permalink) | |
08-01-2015, 13:43 | #41 (permalink) |
Insane Poster Join Date: Sep 2012
Member: 1813698 Status: Offline Thanks Meter: 8 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 15010056545530304DF169D87C996FE9 CSD : D02701320F5903FFF6DBFFFF8E40406D Selected Drive Letter: G Mounting Drive... Failed! ERROR: Cannot Connect to eMMC! but it recognize emmc in atf software ... also i run it as admin |
08-12-2015, 10:45 | #43 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Find by yourself from this link: http://forum.gsmhosting.com/vbb/f609...orial-1908984/ when have find all pinout just use ATF D.R.I.V.E free sw add-on for Read "User Data" .txt file, get one eye in Sticky threads...please no more pm have all here explained Step by Step...only a little of goodwill BR allumts |
