09-25-2013, 04:58 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | INFO: eMMC ADAPTER (Direct Connection) New Feature in ATF 10.20 is an option in ATF Plus --> eMMC Tool 2.0 that allows you to READ/WRITE eMMC Chips that are not connected to the Phone's PCB. Here is an example of such setup. My Taiwan Made "no soldering" emmc socket programming Cherry Mobile S100 eMMC and Samsung S3 and Note2 eMMC. *Samsung S3 eMMC Inside Socket Here is the eMMC detected in the ATF Software. This is a BLANK BRAND NEW EMMC so as you can see, boot partitions and boot mode is not yet defined. As you can see from the pictures, you don't need to build or buy voltage regulators. Proper programming voltage is already generated by the ATF Box! So all you need are wires and some generic eMMC Socket which you can buy in taobao... Here are some examples: Good Quality (250 U$D) emmc socket_ÌÔ±¦ËÑË÷ Not So Good Quality (65 U$D) eMMC169 153²âÊÔ×ù ÀÏ»¯×ùOTʽ£¬´ø²âÊ԰壬¼æÈݸ÷Öֳߴç-ÌÔ±¦Íø No Return No Exchange (40 U$D) ¶«ÕðEMMC ¼«ËÙÐÞשÒÇÆ÷º¸½Ó+²ð×Ö¿â±à³Ì(Åä¼þEMMC sokcet)-ÌÔ±¦Íø Or you can just solder wires directly to the eMMC Chip Like This: (PICTURE COURTESY OF lalitjsraks) For ATF Nitro, you need some small modification to give Power to eMMC socket via RJ-45 PIN 2 (the pin beside VBATT PIN 1). Needless to say, if you modify your Nitro Box, you will loose warranty. So just decide for yourself if you need to modify or you want to buy external power supply instead. Anyway, here is modification needed, just look at light blue encircled area... you will see a very thin wire connected to PIN 2 of RJ-45. For ATF Big Chrome Box (Modified or Normal PCB), you do not need any modifications. RJ-45 PIN 2 is already connected to an Adjustable voltage output. B.R. |
The Following 26 Users Say Thank You to Advance-Box For This Useful Post: |
09-25-2013, 06:21 | #2 (permalink) |
No Life Poster Join Date: Mar 2004 Location: jamshedpur Age: 38
Member: 59185 Status: Offline Sonork: 100.1593175 Thanks Meter: 4,911 | here is EMMC data sheet who can solder wires directly to EMMC |
The Following 8 Users Say Thank You to lalitjsraks For This Useful Post: |
09-25-2013, 14:41 | #7 (permalink) |
Member: 59185 Status: Offline Sonork: 100.1593175 Thanks Meter: 4,911 | hi , here is pinout for atf fbus refer to tp pix for details . pin 2- 2.8v vddf pin 5-blue cmd pin 6-red clk pin 7-brown gnd pin 8-green data0 i will make pic and post tomorrow . |
The Following 6 Users Say Thank You to lalitjsraks For This Useful Post: |
09-25-2013, 15:53 | #10 (permalink) |
Member: 59185 Status: Offline Sonork: 100.1593175 Thanks Meter: 4,911 | @ remark you dont need vdd , just need vddf (2.8v) from pin 2 in atf . when eMMC is not on PCB, you dont need 1.8 and 2.8 |
09-25-2013, 16:06 | #11 (permalink) |
No Life Poster Join Date: Oct 2007 Location: VIZAG,A.P, INDIA
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | What is eMMC? The term eMMC is short for "embedded Multi-Media Controller" and refers to a package consisting of both flash memory and a flash memory controller integrated on the same silicon die. The eMMC solution consists of at least three components - the MMC (multimedia card) interface, the flash memory, and the flash memory controller - and is offered in an industry-standard BGA package. Today’s embedded applications such as digital cameras, smart phones, and tablets almost always store their content on flash memory. In the past, this has required a dedicated controller to manage the reading and writing of data, driven by the application CPU. However, as semiconductor technology has evolved to allow vastly increased storage density, it has become inefficient for the controller to manage these functions from outside the flash memory die. Hence, eMMC was developed as a standardized method for bundling the controller into the flash die. As eMMC has improved, the standard has also provisioned for features such as secure erase and trim and high-priority interrupt to meet the demand for high performance and security. So while the eMMC standard was created to improve data rates and throughputs for high-density chips designed to store high-resolution video, newer generations are doing more for more applications, and each generation of the standard will include additional new features for a richer end-user experience. The widely accepted standard for eMMC is v4.5 as defined in JESD84-A441: Embedded MultiMediaCard (e•MMC) Product Standard v4.5 published by JEDEC in June 2011. Recently, JEDEC has also published the JESD84-B45: Embedded MultiMediaCard (e•MMC), Electrical Standard (Version 4.5 Device) for eMMC v4.5 in June 2011. Where is eMMC used? eMMC is suitable for high performance applications such as portable consumer electronic products for e.g. smartphones, digital tablets, multi-media players, PDAs, navigational systems and digital cameras. eMMC can thus be used for mobile devices, enhanced storage solutions and as replacement for traditional storage media (i.e., HDDs). What are the benefits of eMMC? The eMMC architecture integrating the flash memory controller in the same package simplifies the application interface design and frees the host processor from low-level flash memory management. This benefits product developers by simplifying the non-volatile memory interface design and qualification process – resulting in a reduction in time-to-market as well as facilitating support for future flash device offerings. In other words, eMMC hides the complexities of flash memory technology in a convenient "plug-and-play" package. Obviously, this reduces time and effort for developers. Secondly, eMMC eliminates the need to develop interface software for all types of NAND memory by integrating the embedded controller into the memory chip and providing an easy-to-use memory solutions package for high-speed data transmissions by devices, such as mobile phones. It also eliminates the need for a memory expansion slot by stacking several memory functions vertically, resulting in a very small footprint for the memory devices. Further, this design makes it possible to select suppliers for subcomponents from a wider base, which results in increased revenues with lower time-to-market. What is the required software support for eMMC? The eMMC v4.41 standard provides performance, security and reliability features such as high-priority interrupt and secure erase. These features, such as secure erase and secure trim, require software support from the file system beyond the driver, without which, the application call will not reach the storage media via the file system. Any organization, planning to move to eMMC, would need to provision for such software support from internal or external sources. With the eMMC applications market forecasted to expand to over 700 million units in 2013, there is a need for flash drivers and file systems such as those made by Datalight to specifically support eMMC standards so as to fully utilize the security features offered by them. |
The Following 9 Users Say Thank You to cellcare prasad For This Useful Post: |
09-25-2013, 18:15 | #12 (permalink) |
Freak Poster Join Date: Sep 2005 Location: SPB Age: 45
Member: 182653 Status: Offline Thanks Meter: 115 | Advance-box, please, make more accurate photo for modification board of "nitro" - it is difficult to sort soldering places. After this modification all other function, working over RJ-45 will be ok? |
09-26-2013, 12:21 | #15 (permalink) |
Insane Poster Join Date: Apr 2004 Location: Russia Age: 60
Member: 61359 Status: Offline Thanks Meter: 24 | ATF Big Chrome Box. IC KMSJS000KM-B308 No external power supply is not working. The pin 2 no power. Works with external power supply 1.8 & 2.8V. Writing time 100MB - 33 min. I was hoping for best... Uncomfortable select of address. Blocks, but not HEX address. I hope the product will be developed. |
