Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 11-26-2012, 11:35   #1 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
ATF First In The World Lumia 920 WinPhone 8 Full Flashing!
Also check out other Lumia WinPhone 8 Phones Flashed by ATF:
http://forum.gsmhosting.com/vbb/f609...shing-1680792/
http://forum.gsmhosting.com/vbb/f609...shing-1680806/
http://forum.gsmhosting.com/vbb/f609...shing-1705355/
http://forum.gsmhosting.com/vbb/f609...shing-1680803/
http://forum.gsmhosting.com/vbb/f609...shing-1575683/
http://forum.gsmhosting.com/vbb/f609...shing-1576227/
http://forum.gsmhosting.com/vbb/f609...shing-1576622/
http://forum.gsmhosting.com/vbb/f609...shing-1573787/
http://forum.gsmhosting.com/vbb/f609...shing-1680813/
http://forum.gsmhosting.com/vbb/f609...shing-1689895/
First as Always... and more Lumia Test Phones coming in a few days
Here is the Screenshot:
Here is the Flashing Logs:
Windows Phone 8 Flashing Started
            Windows Phone 8 Lumia Flasher
If the Phone is ALIVE
  1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
  1. Connect Phone to the USB Port
  2. Press and Hold the VOLUME DOWN and POWER Buttons
  3. Wait until the Phone Vibrates Shortly...
  4. Stop Pressing the Buttons...
             Basic Phone Information
SW Version             : 1232.2109.1242.1001
IMEI Plain               : 353680050278169
HW Version            : 6000
Phone Type            : RM-820
Product Code         : 059N5T3
Module Code          : 0205138
PSN Number           : CFQ427726
Manufacturer ID    : RM-820_nam_att_100
Operator Name      : ATT-US
Phone Version        : BuildDate : Oct  1 2012 , BuildType : Draft , HelloString : NCSd for WP8 , Version : 1.18
Security Mode        : Restricted
Variant Information: NAM ATT US V1 White
            Extended Phone Information
Public ID              : 7CE5F6B1FC9A9277D123CB90A06854C74628FA58
Wireless Lan 0 ID: 34:C8:03:1A:A8:14
Wireless Lan 1 ID: 34:C8:03:1A:A8:15
Wireless Lan 2 ID: 34:C8:03:1A:A8:16
Wireless Lan 3 ID: 34:C8:03:1A:A8:17
Bluetooth ID        : 34:C8:03:1A:3B:4C
               Simlock Information
NETWORK NAME  : AT&T;United States [GSM]
PROVIDER KEY     : 3101700000000000
SIMLOCK STATE   : Locked
Booting Flash Mode Initiated...
Please wait upto 15 Seconds for HW Reset
Boot Flash Mode Successful...
Phone Info Query Start...
Blocks Returned: 0x07 Blocks
Block ID 0x01 : 00241000
Block ID 0x02 : 00240000
Block ID 0x03 : 03A3E000
Block ID 0x05 : Nokia.MSM8960.P4301_ATT.3.2.1
Block ID 0x0D : 0001
Block ID 0x0F : 0301010100000101FF
Block ID 0x10 : 0100030000
Checking SD Card Size...
Card Size: 0x00000000
Checking Platform Security Status...
Platform Secure Boot Status: Active
Secure FFU EFUSE Status: Active
Debug Status: Not Active
RDC Status: Not Active
Authentication Status: Active
UEFI Secure Boot Status: Active
Checking Secure FFU Mode...
FFU Status : 010003000000
Query Flash App Information...
Flash App Information: 020107010C00
UEFI App: 0x02
Flash App Protocol Version: 1.7
Flash App Implementation Version: 1.12
Query ROOT KEY HASH...
ROOT_KEY_HASH: 00E9427DF118D9E27D098D13BECB6C6C89CE59F4ECCF5549C49BC0DB952A6BB4
Initializing XFP Data Mode...
XFP Data Mode OK!
Sending Image Signatures...
Image Signatures Accepted!
Preparing Buffers for DATA LOOP...
Allocating System RAM OK!
Start Sending DATA BLOCKS...
Finished Sending all DATA BLOCKS!
Exiting FLASH Mode via REBOOT...
Exit FLASH Mode Successful!
Flashing Done!
Total Flashing Time : 00:01:45
Here is the Test Phone:
Trust ATF...
X-Shadow
The Following 24 Users Say Thank You to Advance-Box For This Useful Post:
Old 12-04-2012, 17:29   #2 (permalink)
Member: 1848373
I have some friends here in brazil and we'll buy the nokia 920, and thinking about share one atf. With it I can unlock Lumia 920 At&t ? Thank you
Old 12-07-2012, 10:08   #3 (permalink)
Member: 147678
Thanks Meter: 5
Hi - and what's about lumia 920 unlocking ? is it possible in the near future by ATF ??
Jac.
Old 12-07-2012, 15:34   #4 (permalink)
Member: 147678
Thanks Meter: 5
where to fing bootmgr drivers ? for rm-821
Old 12-08-2012, 04:51   #5 (permalink)
Member: 651945
@sharkygsm
1. Install (FULL INSTALL) 9.20 and you will get the latest WinUSB Drivers and
Nokia Connectivity Drivers that will support all Lumia Win8 phones...
Drivers will be here after FULL INSTALL:
C:\AdvanceBox Turbo Flasher\Driver\Lumia Phone Drivers\
Old 12-08-2012, 16:11   #6 (permalink)
Member: 147678
Thanks Meter: 5
I've done it - but still problem ... hmm.... I have lumia 920 after factory reset from menu - phone only display "nokia" - and don't turn on - soft reset and hard reset not help
I think only write flash can do it - but - I have tryed on the Xp and win7 - and there is a problem with drivers ... it can't be installed
Old 12-08-2012, 19:41   #7 (permalink)
Burebista's Avatar
Member: 235325
Sonork: 100.1593552
Thanks Meter: 523
Install latest version of Nokia Care Suite and the problem with the drivers will be solved. Even without NCS the drivers should be OK. I've got the same problem with my own NL920 and I flash it by NCS because it gave me eror every time with ATF. When I'll be at office I'll post the logs if is need.
The Following User Says Thank You to Burebista For This Useful Post:
Old 12-08-2012, 20:34   #8 (permalink)
Member: 651945
@sharkygsm
Is your phone appearing in device manager as
a New Device with yellow exclamation point when
you connect it to the usb port?
Is it detected by Windows "New Hardware Found"
ding dong when the usb cable is connected?
NCS uses same drivers as what I already instructed
in post #16. You don't need to install NCS, you just
need to install the new WinUSB driver from ATF 9.20
full installer and Nokia Connectivity Driver ftom ATF
9.20 full installer as well.
If you just used "Update Important Files", it will not work.
Old 12-09-2012, 11:08   #9 (permalink)
Member: 147678
Thanks Meter: 5
ok - I have solved the problem
- first problem - on the official site of ATF - when you click download newest version - you are downloading 8.70 ?? (something like that). When you click form the rpgram udate software and files - it does something buy not all.
to the site adimns - please correct it - beacuse I'm the new one user of ATF - and this was first stage of my foult
- As you mentioned - installing full version of the 9.20 SOLVED THE PROBLEM - drivers are installed automaticly
and remembser - updates files from the program not work exactly as it should (don't download newest one lumia drivers and software) - but's ok
I have two other boxes , even three for nokis - ATF is the newest one I have bought ( I have MTBOX, JAF, MXKEY HTI) - but only ATF had repaired some my old phones software destroyed - like nokia c1-00 (double card phone) and nokia E90
I have flashed my LUMIA 920 and all is ok - THX
SHARKy
Old 12-29-2012, 19:35   #10 (permalink)
Member: 1860279
This version can unlock att lumia 920?
At present, I have not seen anyone feedback information,
Administrators can confirm that?
looking forward
Old 01-09-2013, 16:13   #11 (permalink)
Member: 1037864
Sonork: 2
Thanks Meter: 20
Very good.Lumia920 Full Flash OK By ATF.Tested.
Big Thank Advance-Box Team.!
Old 01-28-2013, 23:51   #12 (permalink)
Member: 1718734
does this confirm that the lumia 920 can be unlocked
Old 02-02-2013, 13:06   #13 (permalink)
Member: 79291
Thanks Meter: 9
hello
where to find flashing files ?
Old 02-04-2013, 00:04   #14 (permalink)
Member: 1718734
You can not unlock the lumia 920 from att yet my brother is a software engineer for att and nokia locked down the unlock server till may. and if you are using the ATF box or anyother unlocking box prove that you can because frankly it getting really old with people saying they can unlock it and can't not one person has shown a screen shoot of the lumia 920 from att (USA) unlocked the closest is ATF and i hope it happens soon.
prove me wrong and ill sell you one.
Old 02-23-2013, 08:45   #15 (permalink)
Member: 695543
Sonork: 100.1602536
Thanks Meter: 149
help please
Loading Flash Files Please Wait...
Debug Status: Active
Authentication Status: Not Active
Secure FFU Mode : SYNC + ASYNC
UEFI App: FLASH APP
ROOT_KEY_HASH: 00E9427DF118D9E27D098D13BECB6C6C89CE59F4ECCF5549C4 9BC0DB952A6BB4
Erasing Data Partition...
ERROR: Erasing Data Partition FAILED!
ERROR: Flashing Failed!
Page generated in 0.26429 seconds with 8 queries
