ATF The Flashing Problems Today I have purchased and use ATF 1- 3110 alive but dead with Atf 2- 7210c alive but dead with Atf DCT4 a lot of problems. both of phones i have flashed with all setting i.e. with or without vpp. with or without turbo but no sucess. So I used cyclone box and made these phones alive again. ATF gives error during flashing and phone becomes dead. ATF Team must rectify this problem. |
If you have problem like you said you should have post logs here so that the team could figure the problem out. ATF is working Perfectly alright with all others as you can see the posts in forum. Br |
in my side..working perfectly... |
Ok I will try more phones and also post logs |
@Kethey You can check our logs as well, we flash those 2 phones without problems. Next time post some logs so we can see what is the problem. |
Hahaha The same person says bad words about one product while on the other side the same person says Thank YOu to the person that makes objection to his words.:D:D:D |
Hahaha The same person says bad words about one product while on the other side the same person says Thank YOu to the person that makes objection to his words.:D:D:D Quote:
All phones that I flashed with ATF were alive, not even one dead |
i flash this fone after read this post working 100% ok Code: Processing Image File : D:\flash files\3110\rm237__07.21.mcusw |
if you need some step by step info about how to flash with ATF or about any settings please contact us on any messengers |
Atf is best flashing box for new nokia. First learn how it work then play with atf . Then u know whats atf power. I FLASHED OVER 75 MOBILE ALL OK WORKING FINE. AFTER 2 DAYES I POST HOW TO FLASH IN ATF VIDEO MANUAL. FOR NEW USER HELP THIS TO FLASH MOBILE. |
