02-27-2014, 15:16 | #49 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @gaugal It means phone model was NOT DETECTED with the files you provided. Possible reason --> Because your FILES do not contain BOOTLOADER. Try other flash files files and make sure they are complete with BOOTLOADER |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
02-27-2014, 15:38 | #50 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | |
The Following User Says Thank You to Advance-Box For This Useful Post: |
02-27-2014, 15:49 | #51 (permalink) | |
Freak Poster Join Date: Aug 2013 Location: Kepler22 Age: 46
Member: 2014892 Status: Offline Sonork: 100.1646397 Thanks Meter: 5 | Quote:
02-27-2014, 15:56 | #52 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ZardozX In ATF Plus ---> eMMC Tool... click "Scan eMMC" It will show you info like this: Code: Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D344731464203821D107D CSD : D02701320F5903FFF6DBFFE78A404057 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 2560 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 3904897024 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M4G1FB Product Rev : 0.3 Product SN : 821D107D Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D344731464203821D107D_58163966.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
02-27-2014, 15:56 | #53 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ZardozX And here is I9300 eMMC. See what version it is Code: Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 15010056545530304DF1A57F509D CSD : D02701320F5903FFF6DBFFFF8E40406D eMMC Boot Information Revision 1.6 (for MMC v4.5) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : VTU00M Product Rev : 15.1 Product SN : A57F509D Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 15010056545530304DF1A57F509D_8F3CB875.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
02-27-2014, 15:58 | #54 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @gaugal I am downloading I9192 4.2.2 files for you... I will make SDC when ready and I will put them in 4shared here: SAMSUNG SDC FILES by d18.builder - 4shared |
02-27-2014, 16:28 | #55 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
You don't need MMC Adapter to create SDC File. You need MMC Adapter to write SDC file to Micro SD Card... Anyway, here is Android 4.2.2 SDC for I9505 GT-I9505_4.2.2 - Download - 4shared | |
02-27-2014, 16:36 | #56 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Quote:
We need emmc erase rebuild extra info, how to do this, shell we need test points, jigs or something else, please clarify me, i ready to activate my atf nitro with emmc activation, I have gpg emmc also but no emmc factory erase or rebuild emmc option, so please tell me ASAP I am waiting for ur response. If possible create one video for this. BR, Srinivas Reddy. | |
02-27-2014, 16:43 | #57 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,047 | Quote:
thanks in advance | |
02-27-2014, 16:50 | #58 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @swechacnu Ummm man,, eMMC Tool from ATF is 100% free for all ATF Box users... NO NEED ACTIVATION. |
The Following 3 Users Say Thank You to Advance-Box For This Useful Post: |
02-27-2014, 17:08 | #60 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Now is giving this error This means you don't have enough RAM in your PC to load all flash files... I suspect maybe you have 4GB of RAM? If so, uncheck the BIGGEST File and perform Create SDC File... Also, SDC for I9505 on Android 4.2.2 is already available here: http://www.4shared.com/file/IjPo-icm...I9505_422.html This is 100% tested file made by one ATF End User from Turkey... B.R. |
